Attention is currently required from: Angel Pons, Arthur Heymans, Jérémy Compostella, Karthik Ramasubramanian, Paul Menzel, Simon Glass, Stefan Reinauer.
Simon Glass has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/77712?usp=email )
Change subject: Post-build control of serial ......................................................................
Patch Set 6:
(18 comments)
File Documentation/technotes/ccb.md:
https://review.coreboot.org/c/coreboot/+/77712/comment/516cbd34_1bda7214 : PS5, Line 37: New flags can be added to `enum ccb_flags` as needed. Note that the default : value of the flag should be zero, i.e. the normal state of coreboot is to have : all flags be zero. Flags should be used to change that normal state. Be careful : not to introduce flags which requires a non-zero value for normal operation.
It would be nice if you could reword this section. […]
Done
https://review.coreboot.org/c/coreboot/+/77712/comment/3a3e6802_2a465b92 : PS5, Line 42: extended
nit: extend*ing*
Done
https://review.coreboot.org/c/coreboot/+/77712/comment/a1dc66e8_75effa33 : PS5, Line 43: ,
nit: Either continue the sentence after the comma, or replace it with a period.
Done
https://review.coreboot.org/c/coreboot/+/77712/comment/55154e65_4708f6c4 : PS5, Line 54: build
nit: buil*t*
Done
File src/arch/x86/postcar.c:
https://review.coreboot.org/c/coreboot/+/77712/comment/ae02335b_439b5c3f : PS5, Line 30: cbmem_initialize();
Looks like CBMEM init logs from postcar are no longer available. […]
That's right, which is why the current version can only work with ~SEPARATE_ROMSTAGE
I will see if I can deal with that
...done
File src/commonlib/include/commonlib/ccb.h:
https://review.coreboot.org/c/coreboot/+/77712/comment/cd5a63a7_774273eb : PS5, Line 26: #define CCB_MAGIC 0xc043b001
How does one guarantee that this magic appears exactly once? The docs don't describe it.
I added 'Searching for the CCB' to the docs
File src/console/Kconfig:
https://review.coreboot.org/c/coreboot/+/77712/comment/a2266662_8b29e4b7 : PS5, Line 440:
(e.g. […]
Done
File src/console/init.c:
https://review.coreboot.org/c/coreboot/+/77712/comment/3f638e27_cdfc30e4 : PS5, Line 45: return CONSOLE_LOG_FAST;
I wonder if this "silent" CCB flag could be hooked up to the "fast" console stuff
Could we leave that until later? Yes, I believe we could add something to control that too
File src/lib/Kconfig:
https://review.coreboot.org/c/coreboot/+/77712/comment/0c60d902_20636b49 : PS5, Line 100: #
nit: Stray `#`, please remove
Done
File src/lib/ccb.c:
https://review.coreboot.org/c/coreboot/+/77712/comment/b13184dd_9934a641 : PS3, Line 8: struct ccb ccb_static __attribute__((section(".init"))) = {
I think it's some compiler. […]
Not that I can see. The checkpath warning is applicable to Linux and U-Boot but I don't think it is correct for coreboot
If you can find something using it, please let me know
File src/lib/ccb.c:
https://review.coreboot.org/c/coreboot/+/77712/comment/d85c87c6_c9519d5c : PS5, Line 16: struct ccb *ccb_get(void)
Is the CCB meant to be modifiable at runtime?
Done
https://review.coreboot.org/c/coreboot/+/77712/comment/651009b7_7657d9b0 : PS5, Line 23: return ccb->flags;
When `!ENV_HOLDS_CCB`, this can result in a NULL dereference even when assuming that `ccb_init()` ha […]
Done
https://review.coreboot.org/c/coreboot/+/77712/comment/4d949de4_d7f8c903 : PS5, Line 32: sizeof(struct ccb)
nit: I'd prefer `sizeof(*ccb)` or `sizeof(*ptr)`.
I slightly prefer what I have, since sizeof(ccb) is error prone depending on whether ccb is a pointer, or not.
Anyway, I don't know coreboot style very well, so I have changed this
https://review.coreboot.org/c/coreboot/+/77712/comment/6f47b23c_e6e979fc : PS5, Line 26: static void add_ccb_to_cbmem(int is_recovery) : { : struct ccb *ptr; : : ccb = ccb_get(); : if (ccb) { : ptr = cbmem_add(CBMEM_ID_CCB, sizeof(struct ccb)); : if (ptr) { : printk(BIOS_DEBUG, "CCB: Adding to CBMEM\n"); : *ptr = *ccb; : } : } : }
This will never works as romstage does not get the setting from bootblock.
Yes, it does not work with a separate romstage. I will see what I can do about that.
...I have figured that out, so am updating this.
File src/lib/hardwaremain.c:
https://review.coreboot.org/c/coreboot/+/77712/comment/c3a6b1ab_600d1fcc : PS5, Line 452: /* console_init() MUST PRECEDE ALL printk()! Additionally, ensure
This is no longer the case, there's prints in the CCB code.
OK I deleted it
File src/lib/prog_loaders.c:
https://review.coreboot.org/c/coreboot/+/77712/comment/90b2af27_067eeffa : PS5, Line 5: #include <commonlib/ccb_api.h>
Why?
Done
File util/cbfstool/cbfstool.c:
https://review.coreboot.org/c/coreboot/+/77712/comment/12c8dd85_2692da0e : PS5, Line 747: serial
"serial" can be confused with "serial number". […]
Done
https://review.coreboot.org/c/coreboot/+/77712/comment/ae976479_313ab503 : PS5, Line 753: "normal"
I wouldn't use "normal" here, as logging is typically only needed when things don't work. […]
I am trying to express the normal state.
I'll go with 'loud' for now
