Attention is currently required from: Jason Glenesk, Marshall Dawson, Julius Werner, Karthik Ramasubramanian, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Marshall Dawson, Julius Werner, Karthik Ramasubramanian, Felix Held,
https://review.coreboot.org/c/coreboot/+/58707
Change subject: soc/amd/common/block/lpc: Set CBFS_CACHE_ALIGN to 64 when using SPI DMA ......................................................................
AMD platforms require the destination buffer to be 64 byte aligned when using the SPI DMA controller.
BUG=b:179699789 TEST=gdb -ex 'p cbfs_cache' /tmp/coreboot/guybrush/cbfs/fallback/ramstage.debug $1 = {buf = 0x0, size = 0, alignment = 64, last_alloc = 0x0, second_to_last_alloc = 0x0, free_offset = 0}
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I228372ff19f958c8e9cf5e51dcc3d37d9f92abec --- M src/soc/amd/common/block/lpc/Kconfig 1 file changed, 7 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/58707/5
