Attention is currently required from: Rob Barnes, Karthik Ramasubramanian, Felix Held. Hello build bot (Jenkins), Raul Rangel, Rob Barnes, Felix Held,
https://review.coreboot.org/c/coreboot/+/58705
Change subject: mb/google/guybrush: Define ACPI Power Resources for FPMCU ......................................................................
Currently all the power sequencing for FPMCU is done explicitly in different stages of coreboot. This can all be done by adding ACPI power resources for FPMCU and clean up the unused code.
BUG=None TEST=Build and boot to OS in Guybrush. Ensure that the FP is able to unlock the system after the first login attempt. Ensure that the FP is able to wakeup the system. Observed that the power resource is added correctly in the FPMCU ACPI object Name (_PR0, Package (0x01) // _PR0: Power Resources for D0 { PR01 }) Name (_PR3, Package (0x01) // _PR3: Power Resources for D3hot { PR01 }) PowerResource (PR01, 0x00, 0x0000) { Method (_STA, 0, NotSerialized) // _STA: Status { Return (0x01) }
Method (_ON, 0, Serialized) // _ON_: Power On { _SB.CTXS (0x0B) _SB.STXS (0x20) _SB.STXS (0x0B) }
Method (_OFF, 0, Serialized) // _OFF: Power Off { _SB.CTXS (0x0B) _SB.CTXS (0x20) } }
Change-Id: I52322eaecf6961ff9a196ca9ab2d58b7d4599d4f Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- M src/mainboard/google/guybrush/bootblock.c M src/mainboard/google/guybrush/mainboard.c M src/mainboard/google/guybrush/variants/baseboard/gpio.c M src/mainboard/google/guybrush/variants/baseboard/helpers.c M src/mainboard/google/guybrush/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/guybrush/variants/guybrush/gpio.c M src/mainboard/google/guybrush/variants/guybrush/overridetree.cb M src/mainboard/google/guybrush/variants/nipperkin/gpio.c M src/mainboard/google/guybrush/variants/nipperkin/overridetree.cb M src/mainboard/google/guybrush/variants/nipperkin/ramstage.c 10 files changed, 30 insertions(+), 175 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/05/58705/2
