David Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42274 )
Change subject: mb/google/volteer/var/terrador: Enable CA Mirror ......................................................................
BUG=b:156435028 BRANCH=none TEST=FW_NAME=terrador emerge-volteer coreboot chromeos-bootimage
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: I0db9fff0dddf35c99a6cb2a90d40886ed8e18686 --- M src/mainboard/google/volteer/variants/terrador/overridetree.cb M src/soc/intel/tigerlake/chip.h M src/soc/intel/tigerlake/romstage/fsp_params.c 3 files changed, 7 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/42274/1
diff --git a/src/mainboard/google/volteer/variants/terrador/overridetree.cb b/src/mainboard/google/volteer/variants/terrador/overridetree.cb index 75422d8..8236890 100644 --- a/src/mainboard/google/volteer/variants/terrador/overridetree.cb +++ b/src/mainboard/google/volteer/variants/terrador/overridetree.cb @@ -1,4 +1,5 @@ chip soc/intel/tigerlake + register "CmdMirror" = "0x00000033" device domain 0 on end end diff --git a/src/soc/intel/tigerlake/chip.h b/src/soc/intel/tigerlake/chip.h index e693699..2c7b604 100644 --- a/src/soc/intel/tigerlake/chip.h +++ b/src/soc/intel/tigerlake/chip.h @@ -83,6 +83,9 @@ /* Rank Margin Tool. 1:Enable, 0:Disable */ uint8_t RMT;
+ /* LPDDR4x Command Pins Mirrored */ + uint32_t CmdMirror; + /* USB related */ struct usb2_port_config usb2_ports[16]; struct usb3_port_config usb3_ports[10]; diff --git a/src/soc/intel/tigerlake/romstage/fsp_params.c b/src/soc/intel/tigerlake/romstage/fsp_params.c index f7956c8..b77bb66 100644 --- a/src/soc/intel/tigerlake/romstage/fsp_params.c +++ b/src/soc/intel/tigerlake/romstage/fsp_params.c @@ -196,6 +196,9 @@
/* Change VmxEnable UPD value according to ENABLE_VMX Kconfig */ m_cfg->VmxEnable = CONFIG(ENABLE_VMX); + + /* LPDDR4x Command Pins Mirrored */ + m_cfg->CmdMirror[0] = config->CmdMirror; }
void platform_fsp_memory_init_params_cb(FSPM_UPD *mupd, uint32_t version)
Hello Patrick Rudolph,
Change subject: mb/google/volteer/variants/terrador: Enable CA Mirror ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/42274/2
Kane Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Patch Set 2:
i think you need to split this to 2 commits. one for UPD and another one for the dev tree.
David Wu has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Patch Set 3:
Patch Set 2:
Done. Thanks
Paul Fagerburg has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Patch Set 3: Code-Review+1
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Patch Set 3:
(2 comments)
https://review.coreboot.org/c/coreboot/+/42274/3//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/42274/3//COMMIT_MSG@7 PS3, Line 7: CA Cmd?
https://review.coreboot.org/c/coreboot/+/42274/3//COMMIT_MSG@7 PS3, Line 7: mb/google/volteer/variants/terrador: Enable CA Mirror Please summarize, why CmdMirror is good to have, and what it improves.
Derek Huang has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Patch Set 3:
(2 comments)
Cmd?
There are different terms, let's use Cmd Mirror to align
Can you add below in commit message? Enable CmdMirror for Terrador to achieve optimum routing from SoC to DRAMs
Hello build bot (Jenkins), Furquan Shaikh, Tim Wawrzynczak, Paul Fagerburg, Nick Vaccaro, Derek Huang, Patrick Rudolph,
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: I0db9fff0dddf35c99a6cb2a90d40886ed8e18686 --- M src/mainboard/google/volteer/variants/terrador/overridetree.cb 1 file changed, 1 insertion(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/42274/4
Patch Set 4:
(2 comments)
Can you add below in commit message? […]
Done
Thanks.
Change subject: mb/google/volteer/variants/terrador: Enable Cmd Mirror ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/42274/5
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Patch Set 6: Code-Review+2
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Patch Set 6:
https://review.coreboot.org/c/coreboot/+/42274/6/src/mainboard/google/voltee... File src/mainboard/google/volteer/variants/terrador/overridetree.cb:
https://review.coreboot.org/c/coreboot/+/42274/6/src/mainboard/google/voltee... PS6, Line 2: 0x00000033 What does this value mean?
Patch Set 6:
Look in the description for the UPD. "BitMask where bits [3:0] are Controller 0 Channel [3:0] and bits [7:4] are Controller 1 Channel [3:0]."
Patch Set 6:
Look in the description for the UPD. […]
Can we add a comment here for the same?
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: I0db9fff0dddf35c99a6cb2a90d40886ed8e18686 --- M src/mainboard/google/volteer/variants/terrador/overridetree.cb 1 file changed, 3 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/42274/7
Patch Set 7:
Done
Patch Set 7:
https://review.coreboot.org/c/coreboot/+/42274/7/src/mainboard/google/voltee... File src/mainboard/google/volteer/variants/terrador/overridetree.cb:
https://review.coreboot.org/c/coreboot/+/42274/7/src/mainboard/google/voltee... PS7, Line 2: # BitMask where bits [3:0] are Controller 0 Channel [3:0] and : # bits [7:4] are Controller 1 Channel [3:0]. What about making this more specific to what the bits means here? e.g., "Enable command mirroring for controller 0 channel 3, and controller 1 channel 3" ?
Patch Set 7:
What about making this more specific to what the bits means here? e.g., […]
+1. channels 0 and 3, right?
Patch Set 7:
+1. […]
Oops, I can read bitmasks 😄
Patch Set 7:
Woops me too :P... Channel 0 and 1.
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: I0db9fff0dddf35c99a6cb2a90d40886ed8e18686 --- M src/mainboard/google/volteer/variants/terrador/overridetree.cb 1 file changed, 5 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/42274/8
Patch Set 8:
Thanks.
Done.
Patch Set 8: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42274 )
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: I0db9fff0dddf35c99a6cb2a90d40886ed8e18686 Reviewed-on: https://review.coreboot.org/c/coreboot/+/42274 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/volteer/variants/terrador/overridetree.cb 1 file changed, 5 insertions(+), 0 deletions(-)
diff --git a/src/mainboard/google/volteer/variants/terrador/overridetree.cb b/src/mainboard/google/volteer/variants/terrador/overridetree.cb index 4bff10d..81da6bd 100644 --- a/src/mainboard/google/volteer/variants/terrador/overridetree.cb +++ b/src/mainboard/google/volteer/variants/terrador/overridetree.cb @@ -1,4 +1,9 @@ chip soc/intel/tigerlake + # BitMask where bits [3:0] are Controller 0 Channel [3:0] and + # bits [7:4] are Controller 1 Channel [3:0]. + # Enable Command Mirroring for controller 0 channel 0 and 1, + # and controller 1 channel 0 and 1. + register "CmdMirror" = "0x00000033" device domain 0 on device pci 15.1 on chip drivers/i2c/hid
