Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11997
commit 18e7c5ec2538027bcbb22a11d3c0401e42943e62 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Sat Jun 20 21:31:15 2015 -0500
southbridge/amd/sb700: Do drive detection even in AHCI mode
SeaBIOS AHCI drive detection randomly fails for drives present on the secondary channel of each AHCI SATA BAR. Forcing native drive detection in AHCI mode resolves this issue.
Change-Id: I34eb1d5d3f2f8aefb749a4eeb911c1373d184938 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/southbridge/amd/sb700/sata.c | 99 +++++++++++++++++++++------------------- 1 file changed, 53 insertions(+), 46 deletions(-)
diff --git a/src/southbridge/amd/sb700/sata.c b/src/southbridge/amd/sb700/sata.c index c61fa01..ae44446 100644 --- a/src/southbridge/amd/sb700/sata.c +++ b/src/southbridge/amd/sb700/sata.c @@ -297,65 +297,72 @@ static void sata_init(struct device *dev) if (port_count > max_port_count) port_count = max_port_count;
- if (!sata_ahci_mode) { - /* RPR7.7 SATA drive detection. */ - /* Use BAR5+0x128,BAR0 for Primary Slave */ - /* Use BAR5+0x1A8,BAR0 for Primary Slave */ - /* Use BAR5+0x228,BAR2 for Secondary Master */ - /* Use BAR5+0x2A8,BAR2 for Secondary Slave */ - /* Use BAR5+0x328,PATA_BAR0/2 for Primary/Secondary Master emulation */ - /* Use BAR5+0x3A8,PATA_BAR0/2 for Primary/Secondary Slave emulation */ - for (i = 0; i < port_count; i++) { + /* RPR7.7 SATA drive detection. */ + /* Use BAR5+0x128,BAR0 for Primary Slave */ + /* Use BAR5+0x1A8,BAR0 for Primary Slave */ + /* Use BAR5+0x228,BAR2 for Secondary Master */ + /* Use BAR5+0x2A8,BAR2 for Secondary Slave */ + /* Use BAR5+0x328,PATA_BAR0/2 for Primary/Secondary Master emulation */ + /* Use BAR5+0x3A8,PATA_BAR0/2 for Primary/Secondary Slave emulation */ + for (i = 0; i < port_count; i++) { + byte = read8(sata_bar5 + 0x128 + 0x80 * i); + printk(BIOS_SPEW, "SATA port %i status = %x\n", i, byte); + byte &= 0xF; + if (byte == 0x1) { + /* If the drive status is 0x1 then we see it but we aren't talking to it. */ + /* Try to do something about it. */ + printk(BIOS_SPEW, "SATA device detected but not talking. Trying lower speed.\n"); + + /* Read in Port-N Serial ATA Control Register */ + byte = read8(sata_bar5 + 0x12C + 0x80 * i); + + /* Set Reset Bit and 1.5g bit */ + byte |= 0x11; + write8((sata_bar5 + 0x12C + 0x80 * i), byte); + + /* Wait 1ms */ + mdelay(1); + + /* Clear Reset Bit */ + byte &= ~0x01; + write8((sata_bar5 + 0x12C + 0x80 * i), byte); + + /* Wait 1ms */ + mdelay(1); + + /* Reread status */ byte = read8(sata_bar5 + 0x128 + 0x80 * i); printk(BIOS_SPEW, "SATA port %i status = %x\n", i, byte); byte &= 0xF; - if (byte == 0x1) { - /* If the drive status is 0x1 then we see it but we aren't talking to it. */ - /* Try to do something about it. */ - printk(BIOS_SPEW, "SATA device detected but not talking. Trying lower speed.\n"); - - /* Read in Port-N Serial ATA Control Register */ - byte = read8(sata_bar5 + 0x12C + 0x80 * i); - - /* Set Reset Bit and 1.5g bit */ - byte |= 0x11; - write8((sata_bar5 + 0x12C + 0x80 * i), byte); - - /* Wait 1ms */ - mdelay(1); - - /* Clear Reset Bit */ - byte &= ~0x01; - write8((sata_bar5 + 0x12C + 0x80 * i), byte); - - /* Wait 1ms */ - mdelay(1); + }
- /* Reread status */ - byte = read8(sata_bar5 + 0x128 + 0x80 * i); - printk(BIOS_SPEW, "SATA port %i status = %x\n", i, byte); - byte &= 0xF; + if (byte == 0x3) { + for (j = 0; j < 10; j++) { + if (i < 4) + current_bar = ((i / 2) == 0) ? sata_bar0 : sata_bar2; + else + current_bar = ide_bar0; + if (!sata_drive_detect(i, current_bar)) + break; } - - if (byte == 0x3) { - for (j = 0; j < 10; j++) { - if (i < 4) - current_bar = ((i / 2) == 0) ? sata_bar0 : sata_bar2; - else - current_bar = ide_bar0; - if (!sata_drive_detect(i, current_bar)) - break; - } + if (sata_ahci_mode) + printk(BIOS_DEBUG, "AHCI device %d is %sready after %i tries\n", + i, + (j == 10) ? "not " : "", + (j == 10) ? j : j + 1); + else printk(BIOS_DEBUG, "%s %s device is %sready after %i tries\n", (i / 2) ? "Secondary" : "Primary", (i % 2 ) ? "Slave" : "Master", (j == 10) ? "not " : "", (j == 10) ? j : j + 1); - } else { + } else { + if (sata_ahci_mode) + printk(BIOS_DEBUG, "No AHCI SATA drive on Slot%i\n", i); + else printk(BIOS_DEBUG, "No %s %s SATA drive on Slot%i\n", (i / 2) ? "Secondary" : "Primary", (i % 2 ) ? "Slave" : "Master", i); - } } }
