Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/51423 )
Change subject: mb/google/octopus/var/fleex: Add RTL5682 support ......................................................................
Fleex will use SSFC to support RTL5682.
BUG=b:178653122 TEST=abuild
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: Icb06eabe297c5562bd2171b52cc9671c342e6dfd Reviewed-on: https://review.coreboot.org/c/coreboot/+/51423 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Marco Chen marcochen@google.com --- M src/mainboard/google/octopus/Kconfig.name M src/mainboard/google/octopus/variants/fleex/gpio.c M src/mainboard/google/octopus/variants/fleex/overridetree.cb 3 files changed, 18 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Marco Chen: Looks good to me, approved
diff --git a/src/mainboard/google/octopus/Kconfig.name b/src/mainboard/google/octopus/Kconfig.name index 64f7649..b384a66 100644 --- a/src/mainboard/google/octopus/Kconfig.name +++ b/src/mainboard/google/octopus/Kconfig.name @@ -28,6 +28,7 @@ select BASEBOARD_OCTOPUS_LAPTOP select BOARD_GOOGLE_BASEBOARD_OCTOPUS select NHLT_DA7219 if INCLUDE_NHLT_BLOBS + select NHLT_RT5682 if INCLUDE_NHLT_BLOBS
config BOARD_GOOGLE_BOBBA bool "-> Bobba" diff --git a/src/mainboard/google/octopus/variants/fleex/gpio.c b/src/mainboard/google/octopus/variants/fleex/gpio.c index 6dbc74a..224e38d 100644 --- a/src/mainboard/google/octopus/variants/fleex/gpio.c +++ b/src/mainboard/google/octopus/variants/fleex/gpio.c @@ -14,13 +14,15 @@ /* PCIE_WAKE1_B -- FULL_CARD_POWER_OFF */ PAD_CFG_GPO(GPIO_117, 1, PWROK),
+ /* GPIO_137 -- HP_INT_ODL and would be amend by SSFC. */ + PAD_CFG_GPI_APIC_IOS(GPIO_137, NONE, DEEP, LEVEL, INVERT, HIZCRx1, DISPUPD), + PAD_NC(GPIO_143, UP_20K), PAD_NC(GPIO_144, UP_20K), PAD_NC(GPIO_145, UP_20K),
/* EN_PP3300_TOUCHSCREEN */ - PAD_CFG_GPO_IOSSTATE_IOSTERM(GPIO_146, 0, DEEP, NONE, Tx0RxDCRx0, - DISPUPD), + PAD_CFG_GPO_IOSSTATE_IOSTERM(GPIO_146, 0, DEEP, NONE, Tx0RxDCRx0, DISPUPD),
/* AVS_I2S1_MCLK -- PLT_RST_LTE_L */ PAD_CFG_GPO(GPIO_161, 1, DEEP), diff --git a/src/mainboard/google/octopus/variants/fleex/overridetree.cb b/src/mainboard/google/octopus/variants/fleex/overridetree.cb index 77cce86..1368834 100644 --- a/src/mainboard/google/octopus/variants/fleex/overridetree.cb +++ b/src/mainboard/google/octopus/variants/fleex/overridetree.cb @@ -122,6 +122,19 @@ register "mic_amp_in_sel" = ""diff"" device i2c 1a on end end + chip drivers/i2c/generic + register "hid" = ""10EC5682"" + register "name" = ""RT58"" + register "desc" = ""Realtek RT5682"" + register "irq" = "ACPI_IRQ_LEVEL_LOW(GPIO_137_IRQ)" + register "probed" = "1" + register "property_count" = "1" + # Set the jd_src to RT5668_JD1 for jack detection + register "property_list[0].type" = "ACPI_DP_TYPE_INTEGER" + register "property_list[0].name" = ""realtek,jd-src"" + register "property_list[0].integer" = "1" + device i2c 1a on end + end end # - I2C 5 device pci 17.2 on chip drivers/i2c/generic
