Hello build bot (Jenkins), Nico Huber, Furquan Shaikh, Subrata Banik, Aamir Bohra, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/45951
Change subject: soc/intel/{skl,cnl,icl,tgl,jsl,elh}: deduplicate ACPI timer emulation ......................................................................
The code for enabling ACPI timer emulation is the same for the socs above. Deduplicate it by moving it to common code.
Note: The ACPI timer emulation can only be used by SoCs with ucode supporting CTC (Common Timer Copy) / ACPI timer emulation.
Change-Id: Ied4b312b6d53e80e71c55f4d1ca78a8cb2799793 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/cannonlake/cpu.c M src/soc/intel/common/block/cpu/cpulib.c M src/soc/intel/common/block/include/intelblocks/cpulib.h M src/soc/intel/elkhartlake/cpu.c M src/soc/intel/icelake/cpu.c M src/soc/intel/jasperlake/cpu.c M src/soc/intel/skylake/cpu.c M src/soc/intel/tigerlake/cpu.c 8 files changed, 40 insertions(+), 128 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/51/45951/10
