Attention is currently required from: Vinod Polimera, Julius Werner. Hello Vinod Polimera, build bot (Jenkins), Douglas Anderson, Xuxin Xiong,
https://review.coreboot.org/c/coreboot/+/52959
Change subject: drivers/sn65dsi86: Switch EDID reading to use "indirect mode" ......................................................................
The SN65DSI86 eDP bridge supports two ways to read the EDID: for now we've been using "direct mode", which works by basically making the bridge I2C device listen to another chip address besides its own and proxy all requests received there directly to the eDP AUX channel. The great part about that mode is that it is super easy and hassle-free to use. The not so great part about it is that it doesn't work: for EDID extensions, the last byte (which happens to contain the checksum) is somehow always read as zero. We presume this is a hardware bug in the bridge part.
The other, much more annoying way is "indirect mode", where each byte transmitted over the AUX channel has to be manually set up in the I2C registers of the bridge, just like we're already doing with DPCD transactions. Thankfully, we can reuse most of the DPCD code for this so it's not a lot of extra code. It's a bit slower but not as much as you'd expect (26ms instead of 18ms on my board), and the difference is not very relevant compared to common total times for display init.
Also, some of the (previously unused) enum definitions for the AUX_CMD mode field of the bridge had just been plain wrong for some reason, and needed to be fixed to make this work.
Signed-off-by: Julius Werner jwerner@chromium.org Change-Id: I65f80193380d3c3841f9f5c26897ed672f45e15a --- M src/drivers/ti/sn65dsi86bridge/sn65dsi86bridge.c 1 file changed, 138 insertions(+), 75 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/52959/6
