Attention is currently required from: Shelley Chen, Paul Menzel.
Hello Julius Werner,
https://review.coreboot.org/c/coreboot/+/70164
Change subject: mb/google/herobrine: Mask out upper bits from sku_id() ......................................................................
When retrieving the SKU id value through the sku_id() function in mainboard_needs_pcie_init(), we only want the values in the lower 5 bits as we can only represent SKU id up to 27. Everything in the higher bits should be masked out because they are not needed.
BUG=b:254281839 BRANCH=None TEST=Make sure that NVMe is not initialized Tested on a herobrine board with SKU id 0
Change-Id: I0e786ec392b5e1484cb2ff6d83a8d4fdd698950c Signed-off-by: Shelley Chen shchen@google.com --- M src/mainboard/google/herobrine/mainboard.c 1 file changed, 26 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/64/70164/5
