Tim Wawrzynczak has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/56833 )
Change subject: drivers/spi/acpi: Update _S0W return value to D3hot ......................................................................
In order to support wake from D3cold, most devices require extra circuitry and possibly out-of-band communications to the host. Therefore, assume that most SPI peripherals that do have wake capabilities support wake from D3hot rather than D3cold.
This also allows coreboot to expose a power resource to perform power sequencing for a SPI peripheral that is intended to retain power in S3/S0ix.
If support for a device with d3cold wake support is needed, it could be added in later as an option.
BUG=b:187228954 TEST=compile
Change-Id: I1d739b49c1a43007eb0199fe39b3b7d7375e6577 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/drivers/spi/acpi/acpi.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/33/56833/1
diff --git a/src/drivers/spi/acpi/acpi.c b/src/drivers/spi/acpi/acpi.c index b23bc9d..abebd88 100644 --- a/src/drivers/spi/acpi/acpi.c +++ b/src/drivers/spi/acpi/acpi.c @@ -125,7 +125,7 @@
/* Wake capabilities */ if (config->wake) { - acpigen_write_name_integer("_S0W", 4); + acpigen_write_name_integer("_S0W", ACPI_DEVICE_SLEEP_D3_HOT); acpigen_write_PRW(config->wake, 3); };
