Tim Wawrzynczak has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/56832 )
Change subject: drivers/i2c/da7219: Update _S0W to D3hot ......................................................................
The DA7219 does not support wake from D3cold, therefore update the return value of _S0W from D3cold to D3hot.
BUG=b:187228954 TEST=compile
Change-Id: If03f83bb00ec90a2a6646d2c99d8bcc7e5533ac2 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/drivers/i2c/da7219/da7219.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/32/56832/1
diff --git a/src/drivers/i2c/da7219/da7219.c b/src/drivers/i2c/da7219/da7219.c index 0423460..80c5272 100644 --- a/src/drivers/i2c/da7219/da7219.c +++ b/src/drivers/i2c/da7219/da7219.c @@ -36,7 +36,7 @@ acpigen_write_name_string("_HID", DA7219_ACPI_HID); acpigen_write_name_integer("_UID", 1); acpigen_write_name_string("_DDN", dev->chip_ops->name); - acpigen_write_name_integer("_S0W", 4); + acpigen_write_name_integer("_S0W", ACPI_DEVICE_SLEEP_D3_HOT); acpigen_write_STA(acpi_device_status(dev));
/* Resources */
