Tim Wawrzynczak has submitted this change. ( https://review.coreboot.org/c/coreboot/+/59557 )
Change subject: mb/google/volteer/var/delbin: Add fw_config probe for ALC5682-VD & VS ......................................................................
ALC5682-VD/ALC5682I-VS load different kernel driver by different hid name. Update hid name depending on the AUDIO_CODEC_SOURCE field of fw_config. Define FW_CONFIG bits 41 - 43 (SSFC bits 9 - 11) for codec selection.
ALC5682-VD: _HID = "10EC5682" ALC5682I-VS: _HID = "RTL5682"
BUG=b:204523176 BRANCH=volteer TEST=ALC5682-VD/ALC5682I-VS audio codec can work
Signed-off-by: FrankChu frank_chu@pegatron.corp-partner.google.com Change-Id: Ieef638f78edd3428e572a76f06fb9c8757278971 Reviewed-on: https://review.coreboot.org/c/coreboot/+/59557 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-by: Nick Vaccaro nvaccaro@google.com --- M src/mainboard/google/volteer/Kconfig M src/mainboard/google/volteer/variants/delbin/Makefile.inc M src/mainboard/google/volteer/variants/delbin/overridetree.cb A src/mainboard/google/volteer/variants/delbin/variant.c 4 files changed, 45 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Nick Vaccaro: Looks good to me, approved Tim Wawrzynczak: Looks good to me, approved
diff --git a/src/mainboard/google/volteer/Kconfig b/src/mainboard/google/volteer/Kconfig index ced8d9d..c4d8e88 100644 --- a/src/mainboard/google/volteer/Kconfig +++ b/src/mainboard/google/volteer/Kconfig @@ -18,6 +18,7 @@ select DRIVERS_USB_ACPI select EC_GOOGLE_CHROMEEC select EC_GOOGLE_CHROMEEC_BOARDID + select EC_GOOGLE_CHROMEEC_INCLUDE_SSFC_IN_FW_CONFIG select EC_GOOGLE_CHROMEEC_LPC select EC_GOOGLE_CHROMEEC_SKUID select FW_CONFIG diff --git a/src/mainboard/google/volteer/variants/delbin/Makefile.inc b/src/mainboard/google/volteer/variants/delbin/Makefile.inc index 343c7db..2af91aa 100644 --- a/src/mainboard/google/volteer/variants/delbin/Makefile.inc +++ b/src/mainboard/google/volteer/variants/delbin/Makefile.inc @@ -5,3 +5,5 @@ bootblock-y += gpio.c
ramstage-y += gpio.c + +ramstage-y += variant.c diff --git a/src/mainboard/google/volteer/variants/delbin/overridetree.cb b/src/mainboard/google/volteer/variants/delbin/overridetree.cb index 378d4e2..3ff6bb2 100644 --- a/src/mainboard/google/volteer/variants/delbin/overridetree.cb +++ b/src/mainboard/google/volteer/variants/delbin/overridetree.cb @@ -1,3 +1,10 @@ +fw_config + field AUDIO_CODEC_SOURCE 41 43 + option AUDIO_CODEC_UNPROVISIONED 0 + option AUDIO_CODEC_ALC5682 1 + option AUDIO_CODEC_ALC5682I_VS 2 + end +end chip soc/intel/tigerlake register "DdiPort1Hpd" = "0" register "DdiPort2Hpd" = "0" @@ -129,7 +136,7 @@ end # DPTF 0x9A03 device ref i2c0 on chip drivers/i2c/generic - register "hid" = ""10EC5682"" + # register "hid" is set in variant.c because of FW_CONFIG register "name" = ""RT58"" register "desc" = ""Headset Codec"" register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_BOTH(GPP_F8)" diff --git a/src/mainboard/google/volteer/variants/delbin/variant.c b/src/mainboard/google/volteer/variants/delbin/variant.c new file mode 100644 index 0000000..f502a1a --- /dev/null +++ b/src/mainboard/google/volteer/variants/delbin/variant.c @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/variants.h> +#include <fw_config.h> +#include <drivers/i2c/generic/chip.h> +#include <soc/pci_devs.h> + +extern struct chip_operations drivers_i2c_generic_ops; +static void audio_codec_update(void) +{ + const struct device_path codec_path[] = { + {.type = DEVICE_PATH_PCI, .pci.devfn = PCH_DEVFN_I2C0}, + {.type = DEVICE_PATH_I2C, .i2c.device = 0x1a} + }; + const struct device *codec = + find_dev_nested_path(pci_root_bus(), codec_path, + ARRAY_SIZE(codec_path)); + struct drivers_i2c_generic_config *config; + + if (!codec || (codec->chip_ops != &drivers_i2c_generic_ops) || + !codec->chip_info) + return; + config = codec->chip_info; + + if (fw_config_probe(FW_CONFIG(AUDIO_CODEC_SOURCE, AUDIO_CODEC_ALC5682))) + config->hid = "10EC5682"; + else if (fw_config_probe(FW_CONFIG(AUDIO_CODEC_SOURCE, + AUDIO_CODEC_ALC5682I_VS))) + config->hid = "RTL5682"; +} +void variant_devtree_update(void) +{ + audio_codec_update(); +}
