Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11992
commit 1407bdb708fc7eefc94de163a8b38b5bf98ad8e8 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Fri Jun 12 20:10:58 2015 -0500
mainboard/asus/kgpe-d16: Properly configure SR5690 southbridge PIKE slot
Change-Id: I2f1373905ffd6460ac3c7c21738e2e2a9aa2e463 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kgpe-d16/devicetree.cb | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/src/mainboard/asus/kgpe-d16/devicetree.cb b/src/mainboard/asus/kgpe-d16/devicetree.cb index 9bff01e..05b975b 100644 --- a/src/mainboard/asus/kgpe-d16/devicetree.cb +++ b/src/mainboard/asus/kgpe-d16/devicetree.cb @@ -43,9 +43,9 @@ chip northbridge/amd/amdfam10/root_complex # Root complex end register "gpp1_configuration" = "0" # Configuration 16:0 default register "gpp2_configuration" = "1" # Configuration 8:8 - #register "gpp3a_configuration" = "2" # Configuration 4:1:1:0:0:0 - register "gpp3a_configuration" = "11" # Configuration 1:1:1:1:1:1 - register "port_enable" = "0x3ffc" # Enable all ports except 0 and 1 + register "gpp3a_configuration" = "2" # Configuration 4:1:1:0:0:0 + register "port_enable" = "0x3f1c" # Enable all ports except 0, 1, 5, 6, and 7 + register "pcie_settling_time" = "1000000" # Allow PIKE to be detected / configured end chip southbridge/amd/sb700 # Secondary southbridge device pci 11.0 on end # SATA
