Kevin Chiu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/46442 )
Change subject: mb/google/kukui: fix SKUID config for burnet/esche ......................................................................
ADCIN2 (LCM_ID) now was PD 200K but we might get incorrect voltage in different condition: developer mode ADC[2]: Raw value=232459 ID=1
recovery mode: ADC[2]: Raw value=36144 ID=0
in order to match sku definition of burnet/esche: burnet: 0x11 esche: 0x10
we'll need to bypass ADCIN2 to update SKUID accordingly.
BUG=b:170916885 BRANCH=master TEST=1. emerge-jacuzzi coreboot 2. check burnet/esche skuid correctly
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/boardid.c 1 file changed, 5 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/1
diff --git a/src/mainboard/google/kukui/boardid.c b/src/mainboard/google/kukui/boardid.c index 548f36b..71df979 100644 --- a/src/mainboard/google/kukui/boardid.c +++ b/src/mainboard/google/kukui/boardid.c @@ -96,6 +96,11 @@ } }
+ if (CONFIG(BOARD_GOOGLE_BURNET)) { + cached_sku_id = (0x10 | get_adc_index(SKU_ID_CHANNEL)); + return cached_sku_id; + } + /* * The SKU (later used for device tree matching) is combined from: * ADC2[4bit/H] = straps on LCD module (type of panel).
Hung-Te Lin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46442 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/46442/1/src/mainboard/google/kukui/... File src/mainboard/google/kukui/boardid.c:
https://review.coreboot.org/c/coreboot/+/46442/1/src/mainboard/google/kukui/... PS1, Line 99: if (CONFIG(BOARD_GOOGLE_BURNET)) { : cached_sku_id = (0x10 | get_adc_index(SKU_ID_CHANNEL)); : return cached_sku_id; : } : given Jacuzzi followers should not use need LCD module, I'd recommend changing this for all Jacuzzi:
uint32_t lcm_id = 0;
if (!CONFIG(BOARD_GOOGLE_JACUZZI_COMMON)) lcm_id = get_adc_index(LCM_ID_CHANNEL);
.... cached_sku_id = lcm_id << 4 | get_adc_index(SKU_ID_CHANNEL);
And please also change the burnet/esche model file to only do 0x0, 0x1 (not 0x10, 0x11).
Chen-Tsung Hsieh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46442 )
Patch Set 1:
given Jacuzzi followers should not use need LCD module, I'd recommend changing this for all Jacuzzi: […]
The LCM_ID HW strap of kappa & juniper are actually 1. Their sku-ids are 0x10 (not 0x0) now. I'm worried about changing the rule of sku-id for MP devices.
I'd recommend that we still focus on debuging the floating HW strap value of LCM_ID. Then, we don't have to patch anything.
Patch Set 1:
Yes but they don't have other SKUs (single SKU) so it's probably not a big deal - especially there is only one DTS for them.
In the meantime we can also hard-code LCMID to 1 for JACUZZI devices.
That's also true, but I was concerned maybe juniper and kappa have exactly the same issue (floating LCM_ID) and we didn't notice it (due to single SKU, no matching issue). In that sense hard-coding the LCM may also be a good idea for future.
Conclusion: I think we should keep debugging, and maybe also check shipped devices as well. And if that is a hardware issue that cannot be easily fixed, we should consider putting a hard-coded value to JACUZZI LCM_ID.
Kevin Chiu has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46442 )
Patch Set 1:
The LCM_ID HW strap of kappa & juniper are actually 1. […]
so we should hard-code LCM_ID to 1 for all JACUZZI device for now? and sure, we'll keep checking hardware in parallel. thanks.
Patch Set 1:
so we should hard-code LCM_ID to 1 for all JACUZZI device for now? and sure, we'll keep checking har […]
I agree to hard-code LCM_ID to 1 (even if we resolve the floating LCM_ID issue from HW). LCM_ID is marked as 'NOT USED IN JACUUZI' in schematic. Hard-coding it with config BOARD_GOOGLE_JACUZZI_COMMON is more consistent to that statement.
Hello Hung-Te Lin, build bot (Jenkins),
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/boardid.c 1 file changed, 6 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/2
Patch Set 2:
I agree to hard-code LCM_ID to 1 (even if we resolve the floating LCM_ID issue from HW). […]
Done
Patch Set 2: Code-Review+1
@yupingso, what do you think about this?
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/46442/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/46442/2//COMMIT_MSG@7 PS2, Line 7: mb/google/kukui: fix SKUID config for burnet/esche : : ADCIN2 (LCM_ID) now was PD 200K but we might get incorrect voltage in : different condition: : developer mode : ADC[2]: Raw value=232459 ID=1 : : recovery mode: : ADC[2]: Raw value=36144 ID=0 : : in order to match sku definition of burnet/esche: : burnet: 0x11 : esche: 0x10 : : we'll need to bypass ADCIN2 to update SKUID accordingly. mb/google/kukui: fix LCMID to be 0x01 for Jacuzzi followers
The LCM ID is not really used on Jacuzzi followers and the ADC may return unexpected value on some boards, so we want to change that to a fixed value for all Jacuzzi followers.
Hello Hung-Te Lin, build bot (Jenkins), Yu-Ping Wu,
Change subject: mb/google/kukui: fix LCMID to be 0x01 for Jacuzzi followers ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/3
Patch Set 3:
mb/google/kukui: fix LCMID to be 0x01 for Jacuzzi followers […]
Done
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/46442/3/src/mainboard/google/kukui/... File src/mainboard/google/kukui/boardid.c:
https://review.coreboot.org/c/coreboot/+/46442/3/src/mainboard/google/kukui/... PS3, Line 196: uint32_t lcm_id = 1; give we're not reusing this later, move this to inside the config block, e.g.:
if (CONFIG...) { uint32_t lcm_id = 1; /* LCM is unused on Jacuzzi followers */ cached_sku_id = (lcm_id << 4 | get_adc_index(SKU_ID_CHANNEL)); ...
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/4
Patch Set 4:
give we're not reusing this later, move this to inside the config block, e.g.: […]
Done
Patch Set 4:
(2 comments)
Really sorry but can we change the implementation again to minimize the duplication?
https://review.coreboot.org/c/coreboot/+/46442/4/src/mainboard/google/kukui/... File src/mainboard/google/kukui/boardid.c:
https://review.coreboot.org/c/coreboot/+/46442/4/src/mainboard/google/kukui/... PS4, Line 171: /* Returns the ID for LCD module (type of panel). */ static uint8_t lcm_id(void) { /* LCM is unused on Jacuzzi followers. */ if (CONFIG(BOARD_GOOGLE_JACUZZI_COMMON)) return 1;
get_adc_index(SKU_ID_CHANNEL)); }
https://review.coreboot.org/c/coreboot/+/46442/4/src/mainboard/google/kukui/... PS4, Line 209: get_adc_index(LCM_ID_CHANNEL) lcm_id()
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/boardid.c 1 file changed, 11 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/5
Patch Set 5:
(2 comments)
/* Returns the ID for LCD module (type of panel). */ […]
Done
lcm_id()
Done
Patch Set 5: Code-Review+2
Yu-Ping Wu has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46442 )
Patch Set 5:
https://review.coreboot.org/c/coreboot/+/46442/5/src/mainboard/google/kukui/... File src/mainboard/google/kukui/boardid.c:
https://review.coreboot.org/c/coreboot/+/46442/5/src/mainboard/google/kukui/... PS5, Line 173: Could you remove this blank line? Also it's nice to take the chance to fix the one before sku_id().
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/boardid.c 1 file changed, 10 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/6
Patch Set 6:
Done
Patch Set 6: Code-Review+2
Hung-Te Lin has uploaded a new patch set (#7) to the change originally created by Kevin Chiu. ( https://review.coreboot.org/c/coreboot/+/46442 )
Change subject: mb/google/kukui: change Jacuzzi followers LCMID to fixed value ......................................................................
The LCM ID is not really used on Jacuzzi followers and the reference design expects ADC to return 0. However, there were hardware design issues so the returned value became unexpected numbers.
- Juniper and Kappa returns 1. - Burnet and Esche returns 1 on normal boot, and 0 on recovery boot. - Cerise and Stern usually returns 0, and sometimes 1.
To fix that, we are changing LCM ID to fixed value for Jacuzzi followers.
BUG=b:170916885,b:171365301 BRANCH=kukui TEST=1. emerge-jacuzzi coreboot 2. check burnet/esche skuid correctly
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/boardid.c 1 file changed, 18 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/7
Hung-Te Lin has uploaded a new patch set (#8) to the change originally created by Kevin Chiu. ( https://review.coreboot.org/c/coreboot/+/46442 )
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/boardid.c 1 file changed, 23 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/8
Patch Set 8:
https://review.coreboot.org/c/coreboot/+/46442/8/src/mainboard/google/kukui/... File src/mainboard/google/kukui/boardid.c:
https://review.coreboot.org/c/coreboot/+/46442/8/src/mainboard/google/kukui/... PS8, Line 179: CONFIG(BOARD_GOOGLE_JUNIPER) || CONFIG(BOARD_GOOGLE_KAPPA) || : CONFIG(BOARD_GOOGLE_BURNET) || CONFIG(BOARD_GOOGLE_ESCHE) What do you think if we add a Kconfig option for this?
Hung-Te Lin has uploaded a new patch set (#9) to the change originally created by Kevin Chiu. ( https://review.coreboot.org/c/coreboot/+/46442 )
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/Kconfig M src/mainboard/google/kukui/boardid.c 2 files changed, 21 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/9
Patch Set 9:
Done
Patch Set 9: Code-Review+2
Hung-Te Lin has uploaded a new patch set (#10) to the change originally created by Kevin Chiu. ( https://review.coreboot.org/c/coreboot/+/46442 )
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/10
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/Kconfig M src/mainboard/google/kukui/boardid.c 2 files changed, 20 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/11
Patch Set 11:
https://review.coreboot.org/c/coreboot/+/46442/10/src/mainboard/google/kukui... File src/mainboard/google/kukui/Kconfig:
https://review.coreboot.org/c/coreboot/+/46442/10/src/mainboard/google/kukui... PS10, Line 82: default 0x1 if BOARD_GOOGLE_JUNIPER || BOARD_GOOGLE_KAPPA || BOARD_GOOGLE_DAMU || BOARD_GOOGLE_BURNET || BOARD_GOOGLE_ESCHE Sorry, but now this line seems to be too long. Can we wrap it?
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/12
Patch Set 12:
Sorry, but now this line seems to be too long. […]
Done
Hung-Te Lin has uploaded a new patch set (#13) to the change originally created by Kevin Chiu. ( https://review.coreboot.org/c/coreboot/+/46442 )
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com --- M src/mainboard/google/kukui/Kconfig M src/mainboard/google/kukui/boardid.c 2 files changed, 22 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/13
Patch Set 13:
(2 comments)
Done
https://review.coreboot.org/c/coreboot/+/46442/11/src/mainboard/google/kukui... File src/mainboard/google/kukui/boardid.c:
https://review.coreboot.org/c/coreboot/+/46442/11/src/mainboard/google/kukui... PS11, Line 186: / : ui I prefer to keep one blank line between this commend and sku_id, because this is NOT the function-comment for sku_id; it's explaining for functions below.
Patch Set 13:
I prefer to keep one blank line between this commend and sku_id, because this is NOT the function-co […]
got it, let me add it back, thanks.
Patch Set 13:
no no no, let's move it to top of this file to prevent confusion. please check my latest version.
Patch Set 13:
yes, just got your update there, thanks.
Patch Set 13:
Hi reviewers, could we merge this one if no other concern? thanks.
Patch Set 13:
https://review.coreboot.org/c/coreboot/+/46442/13/src/mainboard/google/kukui... File src/mainboard/google/kukui/boardid.c:
https://review.coreboot.org/c/coreboot/+/46442/13/src/mainboard/google/kukui... PS13, Line 15: /* : * The boardid.c should provide board_id, sku_id, and ram_code. : * board_id is provided by ec/google/chromeec/ec_boardid.c. : * sku_id and ram_code are defined in this file. : */ Put this right after license?
/* SPDX-License-Identifier: GPL-2.0-only */ <<<BLANK LINE>>> /* * The boardid.c... */ <<<BLANK LINE>>> #include <...>
to look at the new patch set (#14).
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/46442/14
Patch Set 14:
Put this right after license? […]
Done
Patch Set 14: Code-Review+2
Hung-Te Lin has submitted this change. ( https://review.coreboot.org/c/coreboot/+/46442 )
Change-Id: I3b43b9153315ec65e9168c4e84ea844dff14d446 Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/46442 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Hung-Te Lin hungte@chromium.org Reviewed-by: Yu-Ping Wu yupingso@google.com --- M src/mainboard/google/kukui/Kconfig M src/mainboard/google/kukui/boardid.c 2 files changed, 22 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Hung-Te Lin: Looks good to me, approved Yu-Ping Wu: Looks good to me, approved
diff --git a/src/mainboard/google/kukui/Kconfig b/src/mainboard/google/kukui/Kconfig index 2237efa..23a4169 100644 --- a/src/mainboard/google/kukui/Kconfig +++ b/src/mainboard/google/kukui/Kconfig @@ -77,4 +77,10 @@ default 0x10 if BOARD_GOOGLE_BURNET || BOARD_GOOGLE_ESCHE || BOARD_GOOGLE_FENNEL || BOARD_GOOGLE_CERISE || BOARD_GOOGLE_STERN default 0x0
+config BOARD_OVERRIDE_LCM_ID + hex + default 0x1 if BOARD_GOOGLE_JUNIPER || BOARD_GOOGLE_KAPPA || BOARD_GOOGLE_DAMU + default 0x1 if BOARD_GOOGLE_BURNET || BOARD_GOOGLE_ESCHE + default 0x0 + endif diff --git a/src/mainboard/google/kukui/boardid.c b/src/mainboard/google/kukui/boardid.c index 47b0d9b..6c7547c 100644 --- a/src/mainboard/google/kukui/boardid.c +++ b/src/mainboard/google/kukui/boardid.c @@ -1,5 +1,11 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+/* + * The boardid.c should provide board_id, sku_id, and ram_code. + * board_id is provided by ec/google/chromeec/ec_boardid.c. + * sku_id and ram_code are defined in this file. + */ + #include <assert.h> #include <boardid.h> #include <console/console.h> @@ -169,7 +175,15 @@ return 0; }
-/* board_id is provided by ec/google/chromeec/ec_boardid.c */ +/* Returns the ID for LCD module (type of panel). */ +static uint8_t lcm_id(void) +{ + /* LCM is unused on Jacuzzi followers. */ + if (CONFIG(BOARD_GOOGLE_JACUZZI_COMMON)) + return CONFIG_BOARD_OVERRIDE_LCM_ID; + + return get_adc_index(LCM_ID_CHANNEL); +}
uint32_t sku_id(void) { @@ -200,7 +214,7 @@ * ADC4[4bit/L] = SKU ID from board straps. */ cached_sku_id = (wfc_id() << 8 | - get_adc_index(LCM_ID_CHANNEL) << 4 | + lcm_id() << 4 | get_adc_index(SKU_ID_CHANNEL));
