Martin Roth (gaumless@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7497
commit 28e37e9f39cd43c45dec9740e2cddfc7fdc4345e Author: Martin Roth martin.roth@se-eng.com Date: Sun Nov 16 21:12:16 2014 -0700
fsp_baytrail: Allow selection of USB controller from Kconfig
Allow the selection of EHCI or XHCI from Kconfig instead of just from the devicetree.
This adds 3 choices: - Follow devicetree - expects only one of the two controllers to be enabled in the devicetree, and sets the controller to that mode. - Use XHCI controller - Selects the XHCI controller and disables the EHCI controller. The XHCI controller should be enabled in devicetree. It doesn't matter whether or not the EHCI controller is enabled in devicetree. - Use EHCI controller - Selects the EHCI controller and disables the XHCI controller. The EHCI controller should be enabled in devicetree. It doesn't matter whether or not the XHCI controller is enabled in devicetree.
If both EHCI and XHCI controllers are enabled in devicetree, one or the other should be selected here.
This can be overridden again in the mainboard using CMOS data if available on that particular platform.
Change-Id: I82d756d5f2ed61b06f936a3f5fcb7a23d43a8244 Signed-off-by: Martin Roth martin.roth@se-eng.com --- src/soc/intel/fsp_baytrail/fsp/Kconfig | 26 +++++++++++++++++++++++ src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c | 8 +++++-- 2 files changed, 32 insertions(+), 2 deletions(-)
diff --git a/src/soc/intel/fsp_baytrail/fsp/Kconfig b/src/soc/intel/fsp_baytrail/fsp/Kconfig index 73800d6..cc3c3d0 100644 --- a/src/soc/intel/fsp_baytrail/fsp/Kconfig +++ b/src/soc/intel/fsp_baytrail/fsp/Kconfig @@ -39,3 +39,29 @@ config FSP_LOC
The Bay Trail FSP is built with a preferred base address of 0xFFFC0000. + +choice + prompt "Select the USB Controller to use" + default BAYTRAIL_USB_DEVICETREE + help + This option allows you to select the USB Controller - EHCI or XHCI. + +config BAYTRAIL_USB_DEVICETREE + bool "Follow devicetree" + help + Sets the active controller to match the controller that's enabled in + the devicetree.cb file. + +config BAYTRAIL_USB_XHCI + bool "Use XHCI controller" + help + Sets the active controller to XHCI. The XHCI controller must be enabled + in devicetree. The EHCI controller will be ignored if it's enabled. + +config BAYTRAIL_USB_EHCI + bool "Use EHCI controller" + help + Sets the active controller to EHCI. The EHCI controller must be enabled + in devicetree. The XHCI controller will be ignored if it's enabled. +endchoice + diff --git a/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c b/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c index c6b5f9c..402e2f9 100644 --- a/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c +++ b/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c @@ -188,10 +188,14 @@ static void ConfigureDefaultUpdData(FSP_INFO_HEADER *FspInfo, UPD_DATA_REGION *U UpdData->PcdeMMCBootMode = EMMC_4_5 - EMMC_DISABLED; break; case XHCI_DEV_FUNC: - UpdData->PcdEnableXhci = dev->enabled; + if (CONFIG_BAYTRAIL_USB_XHCI || + (CONFIG_BAYTRAIL_USB_DEVICETREE && dev->enabled)) + UpdData->PcdEnableXhci = 1; break; case EHCI_DEV_FUNC: - UpdData->PcdEnableXhci = !(dev->enabled); + if (CONFIG_BAYTRAIL_USB_EHCI || + (CONFIG_BAYTRAIL_USB_DEVICETREE && dev->enabled)) + UpdData->PcdEnableXhci = 0; break;
case LPE_DEV_FUNC:
