Martin Roth (gaumless@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7498
commit 262a83743beec753a82d1647e0a6c5769e9afb8e Author: Martin Roth martin.roth@se-eng.com Date: Sun Nov 16 20:53:14 2014 -0700
fsp_baytrail: update for UPD_DEVICE_CHECK macro
- Update chipset_fsp_util.c to use the UPD_DEVICE_CHECK macro. This makes the code more standardized and easier to read. - Add some debug printing that was removed in the transition.
Change-Id: Iea24dd9ca53f39791bc6371291a3fa7a6fc5ed0f Signed-off-by: Martin Roth martin.roth@se-eng.com --- src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c | 184 ++++++---------------- 1 file changed, 52 insertions(+), 132 deletions(-)
diff --git a/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c b/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c index bec3c07..623a7ca 100644 --- a/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c +++ b/src/soc/intel/fsp_baytrail/fsp/chipset_fsp_util.c @@ -65,6 +65,19 @@ const PCH_AZALIA_CONFIG mAzaliaConfig = {
typedef struct soc_intel_fsp_baytrail_config config_t;
+static const char *acpi_pci_mode_strings[] = { + "Disabled", + "Enabled in PCI Mode", + "Enabled in ACPI Mode" +}; + +static const char *emmc_mode_strings[] = { + "Disabled", + "Auto", + "eMMC 4.1", + "eMMC 4.5" +}; + /** * Update the UPD data based on values from devicetree.cb * @@ -132,6 +145,25 @@ static void ConfigureDefaultUpdData(FSP_INFO_HEADER *FspInfo, UPD_DATA_REGION *U continue;
switch (dev->path.pci.devfn) { + UPD_DEVICE_CHECK(SDIO_DEV_FUNC, PcdEnableSdio, "Sdio:\t\t\t"); + UPD_DEVICE_CHECK(SD_DEV_FUNC, PcdEnableSdcard, "Sdcard:\t\t\t"); + UPD_DEVICE_CHECK(SIO_DMA1_DEV_FUNC, PcdEnableDma0, "SIO Dma 0:\t\t"); + UPD_DEVICE_CHECK(I2C1_DEV_FUNC, PcdEnableI2C0, "SIO I2C0:\t\t"); + UPD_DEVICE_CHECK(I2C2_DEV_FUNC, PcdEnableI2C1, "SIO I2C1:\t\t"); + UPD_DEVICE_CHECK(I2C3_DEV_FUNC, PcdEnableI2C2, "SIO I2C2:\t\t"); + UPD_DEVICE_CHECK(I2C4_DEV_FUNC, PcdEnableI2C3, "SIO I2C3:\t\t"); + UPD_DEVICE_CHECK(I2C5_DEV_FUNC, PcdEnableI2C4, "SIO I2C4:\t\t"); + UPD_DEVICE_CHECK(I2C6_DEV_FUNC, PcdEnableI2C5, "SIO I2C5:\t\t"); + UPD_DEVICE_CHECK(I2C7_DEV_FUNC, PcdEnableI2C6, "SIO I2C6:\t\t"); + UPD_DEVICE_CHECK(SIO_DMA2_DEV_FUNC, PcdEnableDma1, "SIO Dma1:\t\t"); + UPD_DEVICE_CHECK(PWM1_DEV_FUNC, PcdEnablePwm0, "Pwm0:\t\t\t"); + UPD_DEVICE_CHECK(PWM2_DEV_FUNC, PcdEnablePwm1, "Pwm1:\t\t\t"); + UPD_DEVICE_CHECK(HSUART1_DEV_FUNC, PcdEnableHsuart0, "Hsuart0:\t\t"); + UPD_DEVICE_CHECK(HSUART2_DEV_FUNC, PcdEnableHsuart1, "Hsuart1:\t\t"); + UPD_DEVICE_CHECK(SPI_DEV_FUNC, PcdEnableSpi, "Spi:\t\t\t"); + UPD_DEVICE_CHECK(SATA_DEV_FUNC, PcdEnableSata, "SATA:\t\t\t"); + UPD_DEVICE_CHECK(HDA_DEV_FUNC, PcdEnableAzalia, "Azalia:\t\t\t"); + case MIPI_DEV_FUNC: /* Camera / Image Signal Processing */ if (FspInfo->ImageRevision >= FSP_GOLD3_REV_ID) { UpdData->ISPEnable = dev->enabled; @@ -150,151 +182,39 @@ static void ConfigureDefaultUpdData(FSP_INFO_HEADER *FspInfo, UPD_DATA_REGION *U (config->PcdeMMCBootMode == EMMC_FOLLOWS_DEVICETREE)) UpdData->PcdeMMCBootMode = EMMC_4_1 - EMMC_DISABLED; break; - case SDIO_DEV_FUNC: - UpdData->PcdEnableSdio = dev->enabled; - printk(BIOS_DEBUG, "Sdio:\t\t\t%s\n", - UpdData->PcdEnableSdio?"Enabled":"Disabled"); - break; - case SD_DEV_FUNC: - UpdData->PcdEnableSdcard = dev->enabled; - printk(BIOS_DEBUG, "Sdcard:\t\t\t%s\n", - UpdData->PcdEnableSdcard?"Enabled":"Disabled"); - break; - case SATA_DEV_FUNC: - UpdData->PcdEnableSata = dev->enabled; - printk(BIOS_DEBUG, "Sata:\t\t\t%s\n", - UpdData->PcdEnableSata?"Enabled":"Disabled"); - if (UpdData->PcdEnableSata) - printk(BIOS_DEBUG, "SATA Mode:\t\t%s\n", - UpdData->PcdSataMode?"AHCI":"IDE"); - break; - case XHCI_DEV_FUNC: - UpdData->PcdEnableXhci = dev->enabled; - break; - case LPE_DEV_FUNC: - if (dev->enabled && config->LpeAcpiModeEnable == - LPE_ACPI_MODE_ENABLED) - UpdData->PcdEnableLpe = LPE_ACPI_MODE_ENABLED; - else - UpdData->PcdEnableLpe = dev->enabled; - printk(BIOS_DEBUG, "Lpe:\t\t\t%s\n", - UpdData->PcdEnableLpe?"Enabled":"Disabled"); - printk(BIOS_DEBUG, "Lpe mode:\t\t%s\n", - UpdData->PcdEnableLpe == LPE_ACPI_MODE_ENABLED? - "ACPI":"PCI"); - break; case MMC45_DEV_FUNC: /* MMC 4.5*/ if ((dev->enabled) && (config->PcdeMMCBootMode == EMMC_FOLLOWS_DEVICETREE)) UpdData->PcdeMMCBootMode = EMMC_4_5 - EMMC_DISABLED; break; - case SIO_DMA1_DEV_FUNC: - UpdData->PcdEnableDma0 = dev->enabled; - printk(BIOS_DEBUG, "SIO Dma 0:\t\t%s\n", - UpdData->PcdEnableDma0?"Enabled":"Disabled"); - break; - case I2C1_DEV_FUNC: - UpdData->PcdEnableI2C0 = dev->enabled; - printk(BIOS_DEBUG, "SIO I2C0:\t\t%s\n", - UpdData->PcdEnableI2C0?"Enabled":"Disabled"); - break; - case I2C2_DEV_FUNC: - UpdData->PcdEnableI2C1 = dev->enabled; - printk(BIOS_DEBUG, "SIO I2C1:\t\t%s\n", - UpdData->PcdEnableI2C1?"Enabled":"Disabled"); - break; - case I2C3_DEV_FUNC: - UpdData->PcdEnableI2C2 = dev->enabled; - printk(BIOS_DEBUG, "SIO I2C2:\t\t%s\n", - UpdData->PcdEnableI2C2?"Enabled":"Disabled"); - break; - case I2C4_DEV_FUNC: - UpdData->PcdEnableI2C3 = dev->enabled; - printk(BIOS_DEBUG, "SIO I2C3:\t\t%s\n", - UpdData->PcdEnableI2C3?"Enabled":"Disabled"); - break; - case I2C5_DEV_FUNC: - UpdData->PcdEnableI2C4 = dev->enabled; - printk(BIOS_DEBUG, "SIO I2C4:\t\t%s\n", - UpdData->PcdEnableI2C4?"Enabled":"Disabled"); - break; - case I2C6_DEV_FUNC: - UpdData->PcdEnableI2C5 = dev->enabled; - printk(BIOS_DEBUG, "SIO I2C5:\t\t%s\n", - UpdData->PcdEnableI2C5?"Enabled":"Disabled"); - break; - case I2C7_DEV_FUNC: - UpdData->PcdEnableI2C6 = dev->enabled; - printk(BIOS_DEBUG, "SIO I2C6:\t\t%s\n", - UpdData->PcdEnableI2C6?"Enabled":"Disabled"); - break; - case TXE_DEV_FUNC: /* TXE */ - break; - case HDA_DEV_FUNC: - if (config->AzaliaAutoEnable) { - UpdData->PcdEnableAzalia = 2; - printk(BIOS_DEBUG, "Azalia:\t\t\tAuto\n"); - } else { - UpdData->PcdEnableAzalia = dev->enabled; - printk(BIOS_DEBUG, "Azalia:\t\t\t%s\n", - UpdData->PcdEnableAzalia?"Enabled":"Disabled"); - } - break; - case PCIE_PORT1_DEV_FUNC: - case PCIE_PORT2_DEV_FUNC: - case PCIE_PORT3_DEV_FUNC: - case PCIE_PORT4_DEV_FUNC: + case XHCI_DEV_FUNC: + UpdData->PcdEnableXhci = dev->enabled; break; case EHCI_DEV_FUNC: UpdData->PcdEnableXhci = !(dev->enabled); break; - case SIO_DMA2_DEV_FUNC: - UpdData->PcdEnableDma1 = dev->enabled; - printk(BIOS_DEBUG, "SIO Dma1:\t\t%s\n", - UpdData->PcdEnableDma1?"Enabled":"Disabled"); - break; - case PWM1_DEV_FUNC: - UpdData->PcdEnablePwm0 = dev->enabled; - printk(BIOS_DEBUG, "Pwm0\t\t\t%s\n", - UpdData->PcdEnablePwm0?"Enabled":"Disabled"); - break; - case PWM2_DEV_FUNC: - UpdData->PcdEnablePwm1 = dev->enabled; - printk(BIOS_DEBUG, "Pwm1:\t\t\t%s\n", - UpdData->PcdEnablePwm1?"Enabled":"Disabled"); - break; - case HSUART1_DEV_FUNC: - UpdData->PcdEnableHsuart0 = dev->enabled; - printk(BIOS_DEBUG, "Hsuart0:\t\t%s\n", - UpdData->PcdEnableHsuart0?"Enabled":"Disabled"); - break; - case HSUART2_DEV_FUNC: - UpdData->PcdEnableHsuart1 = dev->enabled; - printk(BIOS_DEBUG, "Hsuart1:\t\t%s\n", - UpdData->PcdEnableHsuart1?"Enabled":"Disabled"); - break; - case SPI_DEV_FUNC: - UpdData->PcdEnableSpi = dev->enabled; - printk(BIOS_DEBUG, "Spi:\t\t\t%s\n", - UpdData->PcdEnableSpi?"Enabled":"Disabled"); - break; - case LPC_DEV_FUNC: /* LPC */ - break; - case SMBUS_DEV_FUNC: + + case LPE_DEV_FUNC: + if (dev->enabled) + UpdData->PcdEnableLpe = config->LpeAcpiModeEnable; + else + UpdData->PcdEnableLpe = 0; break; } }
- if(UpdData->PcdeMMCBootMode == EMMC_AUTO - EMMC_DISABLED) { - printk(BIOS_DEBUG, "eMMC Mode:\t\tAuto"); - } else { - printk(BIOS_DEBUG, "eMMC 4.1:\t\t%s\n", - UpdData->PcdeMMCBootMode == EMMC_4_1 - EMMC_DISABLED? - "Enabled":"Disabled"); - printk(BIOS_DEBUG, "eMMC 4.5:\t\t%s\n", - UpdData->PcdeMMCBootMode == EMMC_4_5 - EMMC_DISABLED? - "Enabled":"Disabled"); - } + if (UpdData->PcdEnableLpe < sizeof(acpi_pci_mode_strings) / sizeof (char *)) + printk(BIOS_DEBUG, "Lpe:\t\t\t%s\n", + acpi_pci_mode_strings[UpdData->PcdEnableLpe]); + + if (UpdData->PcdeMMCBootMode < sizeof(emmc_mode_strings) / sizeof (char *)) + printk(BIOS_DEBUG, "eMMC Mode:\t\t%s", + emmc_mode_strings[UpdData->PcdeMMCBootMode]); + + if (UpdData->PcdEnableSata) + printk(BIOS_DEBUG, "SATA Mode:\t\t%s\n", + UpdData->PcdSataMode?"AHCI":"IDE"); + printk(BIOS_DEBUG, "Xhci:\t\t\t%s\n", UpdData->PcdEnableXhci?"Enabled":"Disabled");
