Attention is currently required from: Joel Bueno, Philipp Hug, ron minnich.
Hello Maximilian Brune, Philipp Hug, build bot (Jenkins), ron minnich,
https://review.coreboot.org/c/coreboot/+/86588?usp=email
Change subject: soc/riscv/ucb: Switch to FDT parsing to get memory size ......................................................................
Currently, coreboot tries to manually probe the memory for the Spike target as part of the SOC_UCB_RISCV target.
However, Spike already passes a pointer to the device tree, so use it instead to get the memory size (like qemu-riscv does).
TEST=Compile for SPIKE-RISCV and run (cmdline: spike -m1024 build/coreboot.elf)
Change-Id: I5c826ab5e4896e07a78632d5d594377a3d6a7a43 Signed-off-by: joel.bueno joel.bueno@openchip.com --- M src/soc/ucb/riscv/Kconfig M src/soc/ucb/riscv/cbmem.c 2 files changed, 10 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/86588/3
