Michael Niewöhner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/47543 )
Change subject: soc/intel/{icl,tgl,jsl,ehl}: enable ACPI CPPC entries ......................................................................
Enable CPPC entries generation, needed for Intel SpeedShift.
This can be tested by checking sysfs in Linux: $ grep . /sys/devices/system/cpu/cpu?/acpi_cppc/*perf
The output should look like this, while the values may differ:
/sys/devices/system/cpu/cpu0/acpi_cppc/highest_perf:28 /sys/devices/system/cpu/cpu0/acpi_cppc/lowest_nonlinear_perf:5 /sys/devices/system/cpu/cpu0/acpi_cppc/lowest_perf:1 /sys/devices/system/cpu/cpu0/acpi_cppc/nominal_perf:24 /sys/devices/system/cpu/cpu1/acpi_cppc/highest_perf:28 /sys/devices/system/cpu/cpu1/acpi_cppc/lowest_nonlinear_perf:5 ...
Change-Id: I910b4e17d4044f1bf1ecfa0643ac62fc7a8cb51b Signed-off-by: Michael Niewöhner foss@mniewoehner.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/47543 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Lance Zhao Reviewed-by: Felix Singer felixsinger@posteo.net Reviewed-by: Sheng Lean Tan sheng.tan@9elements.com --- M src/soc/intel/elkhartlake/Kconfig M src/soc/intel/icelake/Kconfig M src/soc/intel/jasperlake/Kconfig M src/soc/intel/tigerlake/Kconfig 4 files changed, 4 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Lance Zhao: Looks good to me, approved Felix Singer: Looks good to me, but someone else must approve Sheng Lean Tan: Looks good to me, but someone else must approve
diff --git a/src/soc/intel/elkhartlake/Kconfig b/src/soc/intel/elkhartlake/Kconfig index 12b0416..fce2f90 100644 --- a/src/soc/intel/elkhartlake/Kconfig +++ b/src/soc/intel/elkhartlake/Kconfig @@ -34,6 +34,7 @@ select SOC_INTEL_COMMON_ACPI_WAKE_SOURCE select SOC_INTEL_COMMON_BLOCK select SOC_INTEL_COMMON_BLOCK_ACPI + select SOC_INTEL_COMMON_BLOCK_ACPI_CPPC select SOC_INTEL_COMMON_BLOCK_ACPI_GPIO select SOC_INTEL_COMMON_BLOCK_ACPI_LPIT select SOC_INTEL_COMMON_BLOCK_ACPI_PEP diff --git a/src/soc/intel/icelake/Kconfig b/src/soc/intel/icelake/Kconfig index 999bc9d..0a22549 100644 --- a/src/soc/intel/icelake/Kconfig +++ b/src/soc/intel/icelake/Kconfig @@ -36,6 +36,7 @@ select SOC_INTEL_COMMON_ACPI_WAKE_SOURCE select SOC_INTEL_COMMON_BLOCK select SOC_INTEL_COMMON_BLOCK_ACPI + select SOC_INTEL_COMMON_BLOCK_ACPI_CPPC select SOC_INTEL_COMMON_BLOCK_ACPI_LPIT select SOC_INTEL_COMMON_BLOCK_ACPI_GPIO select SOC_INTEL_COMMON_BLOCK_CAR diff --git a/src/soc/intel/jasperlake/Kconfig b/src/soc/intel/jasperlake/Kconfig index 26aa397..556b2f2 100644 --- a/src/soc/intel/jasperlake/Kconfig +++ b/src/soc/intel/jasperlake/Kconfig @@ -35,6 +35,7 @@ select SOC_INTEL_COMMON_ACPI_WAKE_SOURCE select SOC_INTEL_COMMON_BLOCK select SOC_INTEL_COMMON_BLOCK_ACPI + select SOC_INTEL_COMMON_BLOCK_ACPI_CPPC select SOC_INTEL_COMMON_BLOCK_ACPI_GPIO select SOC_INTEL_COMMON_BLOCK_ACPI_LPIT select SOC_INTEL_COMMON_BLOCK_ACPI_PEP diff --git a/src/soc/intel/tigerlake/Kconfig b/src/soc/intel/tigerlake/Kconfig index cf59b60..3ef1005 100644 --- a/src/soc/intel/tigerlake/Kconfig +++ b/src/soc/intel/tigerlake/Kconfig @@ -44,6 +44,7 @@ select SOC_INTEL_COMMON_ACPI_WAKE_SOURCE select SOC_INTEL_COMMON_BLOCK select SOC_INTEL_COMMON_BLOCK_ACPI + select SOC_INTEL_COMMON_BLOCK_ACPI_CPPC select SOC_INTEL_COMMON_BLOCK_ACPI_GPIO select SOC_INTEL_COMMON_BLOCK_ACPI_LPIT select SOC_INTEL_COMMON_BLOCK_ACPI_PEP
