Attention is currently required from: Kyösti Mälkki, Sergii Dmytruk.
Krystian Hebel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/70106 )
Change subject: commonlib/helpers.h: use unsigned literals in definitions
Patch Set 3:
Patchset:
PS3:
Does this force all arithmetic involving KiB to use 64bit arithmetic? For i386 builds too?
Not all, only those that would eventually end up in 64bit variable. Compilers are allowed to use smaller width if it doesn't change the result, and even skip multiplication entirely or change the multiplier if it can be calculated at the time of compilation.
Nevertheless, result of multiplication on i386 is returned in `%edx:%eax`, so it already is 64bit wide.
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: Ie60a6ee82db80328e44639175272cc8097f36c3b
Gerrit-Change-Number: 70106
Gerrit-PatchSet: 3
Gerrit-Owner: Krystian Hebel
krystian.hebel@3mdeb.com
Gerrit-Reviewer: Michał Żygowski
michal.zygowski@3mdeb.com
no-reply@coreboot.org
Gerrit-CC: Kyösti Mälkki
kyosti.malkki@gmail.com
Gerrit-CC: Sergii Dmytruk
sergii.dmytruk@3mdeb.com
Gerrit-Attention: Kyösti Mälkki
Gerrit-Attention: Sergii Dmytruk
Gerrit-Comment-Date: Mon, 05 Dec 2022 14:19:03 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Kyösti Mälkki
Gerrit-MessageType: comment
