Hal Martin has uploaded this change for review. ( https://review.coreboot.org/22737
Change subject: mainboard/compulab: enable SuperIO UART ......................................................................
Enable the UART via SMSC SIO1007 SuperIO, this allows you to see boot messages from coreboot over the integrated RS-232 port (requires use of included dongle).
Also changed devicetree to use the correct CPU socket.
Change-Id: I11a4c532ed73a0cf27d6e7bef6e04035c3942567 Signed-off-by: Hal Martin hal.martin@gmail.com --- M src/mainboard/compulab/intense_pc/Kconfig M src/mainboard/compulab/intense_pc/devicetree.cb M src/mainboard/compulab/intense_pc/romstage.c 3 files changed, 60 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/22737/1
diff --git a/src/mainboard/compulab/intense_pc/Kconfig b/src/mainboard/compulab/intense_pc/Kconfig index 283d63a..6375495 100644 --- a/src/mainboard/compulab/intense_pc/Kconfig +++ b/src/mainboard/compulab/intense_pc/Kconfig @@ -14,6 +14,7 @@ select SOUTHBRIDGE_INTEL_C216 select SYSTEM_TYPE_LAPTOP select USE_NATIVE_RAMINIT + select SUPERIO_SMSC_SIO1007
config HAVE_IFD_BIN bool diff --git a/src/mainboard/compulab/intense_pc/devicetree.cb b/src/mainboard/compulab/intense_pc/devicetree.cb index 8b1deb3..6d01892 100644 --- a/src/mainboard/compulab/intense_pc/devicetree.cb +++ b/src/mainboard/compulab/intense_pc/devicetree.cb @@ -28,7 +28,7 @@ register "gpu_panel_power_up_delay" = "0" register "gpu_pch_backlight" = "0x00000000" device cpu_cluster 0x0 on - chip cpu/intel/socket_rPGA989 + chip cpu/intel/socket_FCBGA1023 device lapic 0x0 on end end diff --git a/src/mainboard/compulab/intense_pc/romstage.c b/src/mainboard/compulab/intense_pc/romstage.c index 8ef3f3e..1df8495 100644 --- a/src/mainboard/compulab/intense_pc/romstage.c +++ b/src/mainboard/compulab/intense_pc/romstage.c @@ -17,7 +17,9 @@ #include <lib.h> #include <arch/io.h> #include "northbridge/intel/sandybridge/raminit_native.h" +#include <superio/smsc/sio1007/chip.h>
+/* void pch_enable_lpc(void) { pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x82, 0x3f0f); @@ -27,6 +29,33 @@ pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x90, 0x000c06a1); pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x80, 0x0010); pci_write_config32(PCI_DEV(0, 0x1f, 0), 0xac, 0x00010000); +} +*/ + +#define SIO_PORT 0x164e + +void pch_enable_lpc(void) +{ + device_t dev = PCH_LPC_DEV; + + /* Set COM1/COM2 decode range */ + pci_write_config16(dev, LPC_IO_DEC, 0x0010); + + /* Enable SuperIO + PS/2 Keyboard/Mouse */ + u16 lpc_config = CNF1_LPC_EN | CNF2_LPC_EN | KBC_LPC_EN; + pci_write_config16(dev, LPC_EN, lpc_config); + + /* Map 256 bytes at 0x1600 to the LPC bus. */ + pci_write_config32(dev, LPC_GEN1_DEC, 0xfc1601); + + /* Map a range for the runtime_port registers to the LPC bus. */ + pci_write_config32(dev, LPC_GEN2_DEC, 0xc0181); + + /* Enable COM1 */ + if (sio1007_enable_uart_at(SIO_PORT)) { + pci_write_config16(dev, LPC_EN, + lpc_config | COMA_LPC_EN); + } }
void rcba_config(void) @@ -59,6 +88,35 @@
void mainboard_config_superio(void) { + const u16 port = SIO_PORT; + const u16 runtime_port = 0x180; + + /* Turn on configuration mode. */ + outb(0x55, port); + + /* Set the GPIO direction, polarity, and type. */ + sio1007_setreg(port, 0x31, 1 << 0, 1 << 0); + sio1007_setreg(port, 0x32, 0 << 0, 1 << 0); + sio1007_setreg(port, 0x33, 0 << 0, 1 << 0); + + /* Set the base address for the runtime register block. */ + sio1007_setreg(port, 0x30, runtime_port >> 4, 0xff); + sio1007_setreg(port, 0x21, runtime_port >> 12, 0xff); + + /* Turn on address decoding for it. */ + sio1007_setreg(port, 0x3a, 1 << 1, 1 << 1); + + /* Set the value of GPIO 10 by changing GP1, bit 0. */ + u8 byte; + byte = inb(runtime_port + 0xc); + byte |= (1 << 0); + outb(byte, runtime_port + 0xc); + + /* Turn off address decoding for it. */ + sio1007_setreg(port, 0x3a, 0 << 1, 1 << 1); + + /* Turn off configuration mode. */ + outb(0xaa, port); }
void mainboard_get_spd(spd_raw_data *spd, bool id_only)
