Attention is currently required from: Furquan Shaikh, Angel Pons, Patrick Rudolph, EricR Lai. Hello build bot (Jenkins), Furquan Shaikh, Tim Wawrzynczak, Angel Pons, Patrick Rudolph, EricR Lai,
https://review.coreboot.org/c/coreboot/+/51683
Change subject: soc/intel/alderlake: Add provision to override Rcomp settings ......................................................................
Add function to allow overriding the RcompResistor and RcompTarget UPDs from mainboard if required.
Mainboard users can pass required rcomp from memory.c file.
Refactor ddr_config structure to take out rcomp related variable outside for all memory type to override if required.
BUG=b:182772421 TEST=Able to override the default RcompResistor and RcompTarget values.
Change-Id: Ie8528bbf0517728534d47f9adaabfc9a2c469609 Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/mainboard/intel/adlrvp/memory.c M src/soc/intel/alderlake/include/soc/meminit.h M src/soc/intel/alderlake/meminit.c 3 files changed, 42 insertions(+), 23 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/51683/12
