Attention is currently required from: Martin L Roth, Paul Menzel, Tim Crawford.
Hello Jeremy Soller, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/82788?usp=email
Change subject: mb/system76/mtl: Add Lemur Pro 13 ......................................................................
The Lemur Pro 13 (lemp13) is an Intel Meteor Lake-U based board.
There are 2 variants to differentiate which keyboard design the unit uses, as they require different EC firmware.
Change-Id: Icac8c7dafd6371881622d797f399f8ddbe13cbce Signed-off-by: Jeremy Soller jeremy@system76.com Signed-off-by: Tim Crawford tcrawford@system76.com --- M src/mainboard/system76/mtl/Kconfig M src/mainboard/system76/mtl/Kconfig.name M src/mainboard/system76/mtl/Makefile.mk A src/mainboard/system76/mtl/spd/samsung-M425R1GB4BB0-CQKOD.spd.hex A src/mainboard/system76/mtl/spd/samsung-M425R1GB4PB0-CWMOD.spd.hex A src/mainboard/system76/mtl/variants/lemp13/board.fmd A src/mainboard/system76/mtl/variants/lemp13/board_info.txt A src/mainboard/system76/mtl/variants/lemp13/data.vbt A src/mainboard/system76/mtl/variants/lemp13/gpio.c A src/mainboard/system76/mtl/variants/lemp13/gpio_early.c A src/mainboard/system76/mtl/variants/lemp13/hda_verb.c A src/mainboard/system76/mtl/variants/lemp13/overridetree.cb A src/mainboard/system76/mtl/variants/lemp13/ramstage.c A src/mainboard/system76/mtl/variants/lemp13/romstage.c A src/mainboard/system76/mtl/variants/lemp13/tas5825m.c 15 files changed, 1,680 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/82788/7
