Felix Held has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/74197 )
Change subject: cpu/x86/64bit/Makefile: use all_x86 make target ......................................................................
Use the newly introduced all_x86 make target to add the mode_switch.S compilation unit to all stages that run on the x86 cores, but not to verstage on PSP.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I8950375d31557d9a38169869c1d250417261c31c --- M src/cpu/x86/64bit/Makefile.inc 1 file changed, 15 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/74197/1
diff --git a/src/cpu/x86/64bit/Makefile.inc b/src/cpu/x86/64bit/Makefile.inc index 526291a..36c69b9 100644 --- a/src/cpu/x86/64bit/Makefile.inc +++ b/src/cpu/x86/64bit/Makefile.inc @@ -1,8 +1,4 @@ -bootblock-y += mode_switch.S -verstage_x86-y += mode_switch.S -romstage-y += mode_switch.S -postcar-y += mode_switch.S -ramstage-y += mode_switch.S +all_x86-y += mode_switch.S
# Add --defsym=_start=0 to suppress a linker warning. $(objcbfs)/pt: $(dir)/pt.S $(obj)/config.h
