Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12274
commit 47090321660ffb016cc00cb93ecff8e0cf7d57ff Author: Patrick Georgi pgeorgi@chromium.org Date: Fri Oct 30 23:05:56 2015 +0100
abuild: remove ancient, unused test submission feature
Change-Id: Ib76814d31b571456d950d45f45912036b6fa82d1 Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- util/abuild/abuild | 46 ++-------------------------------------------- 1 file changed, 2 insertions(+), 44 deletions(-)
diff --git a/util/abuild/abuild b/util/abuild/abuild index 9dc533e..942698b 100755 --- a/util/abuild/abuild +++ b/util/abuild/abuild @@ -42,8 +42,6 @@ fi # Lines of error context to be printed in FAILURE case CONTEXT=6
-TESTSUBMISSION="http://qa.coreboot.org/deployment/send.php" - # Configure-only mode configureonly=0
@@ -320,43 +318,6 @@ function build_target junit "</testcase>" }
-function test_target -{ - VENDOR=$1 - MAINBOARD=$2 - - if [ "$hwtest" != "true" ]; then - return 0 - fi - - # image does not exist. we silently skip the patch. - if [ ! -r "$TARGET/${VENDOR}_${MAINBOARD}/coreboot.rom" ]; then - return 0 - fi - - which curl &> /dev/null - if [ $? != 0 ]; then - printf "curl is not installed but required for test submission. skipping test.\n\n" - return 0 - fi - - CURR=`pwd` - if [ -r "$TARGET/${VENDOR}_${MAINBOARD}/tested" ]; then - printf "Testing image for board $VENDOR $MAINBOARD skipped (previously submitted).\n\n" - return 0 - fi - # touch $TARGET/${VENDOR}_${MAINBOARD}/tested - - printf "Submitting image for board $VENDOR $MAINBOARD to test system...\n" - - curl -f -F "romfile=@$TARGET/${VENDOR}_${MAINBOARD}/coreboot.rom" \ - -F "mode=abuild" -F "mainboard=${VENDOR}_${MAINBOARD}" -F "submit=Upload" \ - "http://qa.coreboot.org/deployment/send.php" - - printf "\n" - return 0 -} - function remove_target { if [ "$remove" != "true" ]; then @@ -455,11 +416,11 @@ cmdline="$* -c 1" getoptbrand="`getopt -V`" if [ "${getoptbrand:0:6}" == "getopt" ]; then # Detected GNU getopt that supports long options. - args=`getopt -l version,verbose,quiet,help,all,target:,payloads:,test,cpus:,silent,junit,config,loglevel:,remove,prefix:,update,scan-build,ccache,blobs,clang,clean,outdir:,chromeos,xmlfile: -o Vvqhat:p:Tc:sJCl:rP:uyBLzo:xX: -- "$@"` || exit 1 + args=`getopt -l version,verbose,quiet,help,all,target:,payloads:,cpus:,silent,junit,config,loglevel:,remove,prefix:,update,scan-build,ccache,blobs,clang,clean,outdir:,chromeos,xmlfile: -o Vvqhat:p:c:sJCl:rP:uyBLzo:xX: -- "$@"` || exit 1 eval set -- $args else # Detected non-GNU getopt - args=`getopt Vvqhat:p:Tc:sJCl:rP:uyBLzo:xX: $*` + args=`getopt Vvqhat:p:c:sJCl:rP:uyBLzo:xX: $*` set -- $args fi
@@ -485,7 +446,6 @@ while true ; do -V|--version) shift; myversion; exit 0;; -h|--help) shift; myversion; myhelp; exit 0;; -p|--payloads) shift; payloads="$1"; shift;; - -T|--test) shift; hwtest=true;; -c|--cpus) shift export MAKEFLAGS="-j $1" cpus=$1 @@ -576,7 +536,6 @@ build_all_targets() for VENDOR in $( vendors ); do for MAINBOARD in $( mainboards $VENDOR ); do build_target $VENDOR $MAINBOARD - test_target $VENDOR $MAINBOARD remove_target $VENDOR $MAINBOARD done done @@ -651,7 +610,6 @@ if [ "$target" != "" ]; then failed=1 else build_target $VENDOR $MAINBOARD - test_target $VENDOR $MAINBOARD remove_target $VENDOR $MAINBOARD test "$mode" != "text" && \ test -f $TARGET/abuild/${VENDOR}_${MAINBOARD}.xml && \
