Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12273
commit af6607a6d586e851bcba164e8593c9e1d32a52f9 Author: Patrick Georgi pgeorgi@chromium.org Date: Fri Oct 30 22:59:30 2015 +0100
abuild: drop the ability to specify a configuration
If you already have a configuration, there's no need to run it through abuild.
Change-Id: I4dde9a7b96bb0c08ec5c91426a4dd3aa15e74edf Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- util/abuild/abuild | 51 +++++++++++++++++++++------------------------------ 1 file changed, 21 insertions(+), 30 deletions(-)
diff --git a/util/abuild/abuild b/util/abuild/abuild index 51eb1c3..9dc533e 100755 --- a/util/abuild/abuild +++ b/util/abuild/abuild @@ -134,7 +134,6 @@ function create_config { VENDOR=$1 MAINBOARD=$2 - CONFIG=$3
build_dir=$TARGET/${VENDOR}_${MAINBOARD}
@@ -158,31 +157,26 @@ function create_config mkdir -p ${build_dir} mkdir -p $TARGET/sharedutils
- if [ "$CONFIG" != "" ]; then - printf " Using existing configuration $CONFIG ... " - cp src/mainboard/$VENDOR/$MAINBOARD/$CONFIG ${build_dir}/config.build - else - if [ "$quiet" == "false" ]; then printf " Creating config file for $VENDOR/$MAINBOARD... \n"; fi - grep "if[\t ]*VENDOR" src/mainboard/$VENDOR/$MAINBOARD/../Kconfig | \ - sed "s,^.*(VENDOR_.*)[^A-Z0-9_]*,CONFIG_\1=y," > ${build_dir}/config.build - grep "if[\t ]*BOARD" src/mainboard/$VENDOR/$MAINBOARD/Kconfig | \ - sed "s,^.*(BOARD_.*)[^A-Z0-9_]*,CONFIG_\1=y," >> ${build_dir}/config.build - grep "select[\t ]*ARCH" src/mainboard/$VENDOR/$MAINBOARD/Kconfig | \ - sed "s,^.*(ARCH_.*)[^A-Z0-9_]*,CONFIG_\1=y," >> ${build_dir}/config.build - echo "CONFIG_MAINBOARD_DIR="$VENDOR/$MAINBOARD"" >> ${build_dir}/config.build - if [ "$PAYLOAD" = "none" ]; then - echo "CONFIG_PAYLOAD_NONE=y" >> ${build_dir}/config.build - elif [ "$PAYLOAD" != "/dev/null" ]; then - echo "# CONFIG_PAYLOAD_NONE is not set" >> ${build_dir}/config.build - echo "# CONFIG_PAYLOAD_SEABIOS is not set" >> ${build_dir}/config.build - echo "CONFIG_PAYLOAD_ELF=y" >> ${build_dir}/config.build - echo "CONFIG_PAYLOAD_FILE="$PAYLOAD"" >> ${build_dir}/config.build - fi - - if [ "$quiet" == "false" ]; then printf " $VENDOR/$MAINBOARD ($customizing)\n"; fi - printf "$configoptions" >> ${build_dir}/config.build + if [ "$quiet" == "false" ]; then printf " Creating config file for $VENDOR/$MAINBOARD... \n"; fi + grep "if[\t ]*VENDOR" src/mainboard/$VENDOR/$MAINBOARD/../Kconfig | \ + sed "s,^.*(VENDOR_.*)[^A-Z0-9_]*,CONFIG_\1=y," > ${build_dir}/config.build + grep "if[\t ]*BOARD" src/mainboard/$VENDOR/$MAINBOARD/Kconfig | \ + sed "s,^.*(BOARD_.*)[^A-Z0-9_]*,CONFIG_\1=y," >> ${build_dir}/config.build + grep "select[\t ]*ARCH" src/mainboard/$VENDOR/$MAINBOARD/Kconfig | \ + sed "s,^.*(ARCH_.*)[^A-Z0-9_]*,CONFIG_\1=y," >> ${build_dir}/config.build + echo "CONFIG_MAINBOARD_DIR="$VENDOR/$MAINBOARD"" >> ${build_dir}/config.build + if [ "$PAYLOAD" = "none" ]; then + echo "CONFIG_PAYLOAD_NONE=y" >> ${build_dir}/config.build + elif [ "$PAYLOAD" != "/dev/null" ]; then + echo "# CONFIG_PAYLOAD_NONE is not set" >> ${build_dir}/config.build + echo "# CONFIG_PAYLOAD_SEABIOS is not set" >> ${build_dir}/config.build + echo "CONFIG_PAYLOAD_ELF=y" >> ${build_dir}/config.build + echo "CONFIG_PAYLOAD_FILE="$PAYLOAD"" >> ${build_dir}/config.build fi
+ if [ "$quiet" == "false" ]; then printf " $VENDOR/$MAINBOARD ($customizing)\n"; fi + printf "$configoptions" >> ${build_dir}/config.build + yes "" 2>/dev/null | $MAKE oldconfig $silent DOTCONFIG=${build_dir}/config.build obj=${build_dir} objutil=$TARGET/sharedutils &> ${build_dir}/config.log ret=$? if [ $ret -eq 0 ]; then @@ -200,9 +194,8 @@ function create_buildenv { VENDOR=$1 MAINBOARD=$2 - CONFIG=$3
- create_config $VENDOR $MAINBOARD $CONFIG + create_config $VENDOR $MAINBOARD ret=$?
# Allow simple "make" in the target directory @@ -270,7 +263,6 @@ function build_target { VENDOR=$1 MAINBOARD=$2 - CONFIG=$3
if [ "`cat $TARGET/${VENDOR}_${MAINBOARD}/compile.status 2>/dev/null`" = "ok" -a \ "$buildall" = "false" ]; then @@ -298,7 +290,7 @@ function build_target
stime=`perl -e 'print time();' 2>/dev/null || date +%s` - create_buildenv $VENDOR $MAINBOARD $CONFIG + create_buildenv $VENDOR $MAINBOARD
required_arches=`egrep "^CONFIG_ARCH_(BOOTBLOCK|R.MSTAGE|VERSTAGE)" $TARGET/${VENDOR}_${MAINBOARD}/config.build | \ sed "s,^CONFIG_ARCH_[^_]*_([^=]*)=.*$,\1," |sort -u |tr 'A-Z\n\r' 'a-z '` @@ -654,12 +646,11 @@ if [ "$target" != "" ]; then # build a single board VENDOR=`printf $target|cut -f1 -d/` MAINBOARD=`printf $target|cut -f2 -d/` - CONFIG=`printf $target|cut -f3 -d/` if [ ! -r $ROOT/src/mainboard/$target ]; then printf "No such target: $target\n" failed=1 else - build_target $VENDOR $MAINBOARD $CONFIG + build_target $VENDOR $MAINBOARD test_target $VENDOR $MAINBOARD remove_target $VENDOR $MAINBOARD test "$mode" != "text" && \
