Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/69858 )
Change subject: soc/mediatek: Add error handling for dptx_get_edid() ......................................................................
Skip eDP initialization when we failed to get EDID. This prevents the PLL assertion in dp_intf_config() if the display could not be initialized properly.
BUG=b:233720142 TEST=boot to depthcharge on MT8188 EVB.
Change-Id: I0fd672b175feb9b813c1d9ec4140e4273079ff07 Signed-off-by: Liju-Clr Chen liju-clr.chen@mediatek.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/69858 Reviewed-by: Rex-BC Chen rex-bc.chen@mediatek.com Reviewed-by: Yidi Lin yidilin@google.com Reviewed-by: Yu-Ping Wu yupingso@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/mediatek/common/dp/dptx.c 1 file changed, 26 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Yu-Ping Wu: Looks good to me, approved Yidi Lin: Looks good to me, but someone else must approve Rex-BC Chen: Looks good to me, but someone else must approve
diff --git a/src/soc/mediatek/common/dp/dptx.c b/src/soc/mediatek/common/dp/dptx.c index f2c0905..08d288a 100644 --- a/src/soc/mediatek/common/dp/dptx.c +++ b/src/soc/mediatek/common/dp/dptx.c @@ -1111,7 +1111,10 @@
dptx_check_sinkcap(&mtk_edp);
- dptx_get_edid(&mtk_edp, edid); + if (dptx_get_edid(&mtk_edp, edid) != 0) { + printk(BIOS_ERR, "Failed to get EDID\n"); + return -1; + }
dptx_set_trainingstart(&mtk_edp); dp_intf_config(edid);
