Youness Alaoui has uploaded a new change for review. ( https://review.coreboot.org/19901 )
Change subject: pciexp_device: Remove useless write on a read-only register ......................................................................
The Role-Based Error Reporting is not a configurable field, it's a read only field in the Device Capability register. This code was old and comes from commit f6eb88ad but evidently is not useful in any way. The PCIe Specification [1] states that it's read-only and must always be set to 1.
I have also done tests on purism/librem13 hardware, trying to change that value, without any success.
[1]: PCI Express Base Specification Revision 3.0 Page 612
Change-Id: I729617a5c6f4f52dfc4c422df78379b309066399 Signed-off-by: Youness Alaoui youness.alaoui@puri.sm --- M src/device/pciexp_device.c 1 file changed, 0 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/01/19901/1
diff --git a/src/device/pciexp_device.c b/src/device/pciexp_device.c index fb2a284..bb9f9e3 100644 --- a/src/device/pciexp_device.c +++ b/src/device/pciexp_device.c @@ -362,11 +362,6 @@ lnkctl = pci_read_config16(endp, endp_cap + PCI_EXP_LNKCTL); lnkctl |= apmc; pci_write_config16(endp, endp_cap + PCI_EXP_LNKCTL, lnkctl); - - /* Enable ASPM role based error reporting. */ - devcap = pci_read_config32(endp, endp_cap + PCI_EXP_DEVCAP); - devcap |= PCI_EXP_DEVCAP_RBER; - pci_write_config32(endp, endp_cap + PCI_EXP_DEVCAP, devcap); }
printk(BIOS_INFO, "ASPM: Enabled %s\n", aspm_type_str[apmc]);
