Shelley Chen has submitted this change. ( https://review.coreboot.org/c/coreboot/+/70162 )
Change subject: mb/google/herobrine: Only retrieve sku_id from EC once ......................................................................
Currently, we are getting the sku id from the EC every time we call the sku_id() function. However, this will never change so we only need to retrieve it once. Inserting exit condition if sku id is already set, then don't get it from the EC again.
Also, removing the ram_code function, which does nothing right now. There is already a weak stub_function for this in src/lib/coreboot_table.c that already does the same thing.
BUG=b:260740438,b:182963902 BRANCH=None TEST=make sure image still boots to login on herobrine device
Change-Id: Ia787968100baf58a41ccce0cf95ed3ec9ce1758a Signed-off-by: Shelley Chen shchen@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/70162 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Doug Anderson dianders@chromium.org --- M src/mainboard/google/herobrine/boardid.c 1 file changed, 38 insertions(+), 14 deletions(-)
Approvals: build bot (Jenkins): Verified Doug Anderson: Looks good to me, approved
diff --git a/src/mainboard/google/herobrine/boardid.c b/src/mainboard/google/herobrine/boardid.c index fc058e2..1f0c88f 100644 --- a/src/mainboard/google/herobrine/boardid.c +++ b/src/mainboard/google/herobrine/boardid.c @@ -11,6 +11,9 @@ uint32_t board_id(void) { static uint32_t id = UNDEFINED_STRAPPING_ID; + if (id != UNDEFINED_STRAPPING_ID) + return id; + gpio_t pins[3] = { 0 }; if (CONFIG(BOARD_GOOGLE_HEROBRINE_REV0)) { pins[2] = GPIO(75); @@ -22,20 +25,7 @@ pins[0] = GPIO(48); }
- if (id == UNDEFINED_STRAPPING_ID) - id = gpio_base3_value(pins, ARRAY_SIZE(pins)); - - printk(BIOS_INFO, "BoardID :%d - " - "Machine model: " - "Qualcomm Technologies, Inc. " - "sc7280 platform\n", id); - - return id; -} - -uint32_t ram_code(void) -{ - static uint32_t id = UNDEFINED_STRAPPING_ID; + id = gpio_base3_value(pins, ARRAY_SIZE(pins));
return id; } @@ -44,6 +34,14 @@ { static uint32_t id = UNDEFINED_STRAPPING_ID;
+ /* + * This means that we already retrieved the sku id from the EC once + * during this boot, so no need to do it again as we'll get the same + * value again. + */ + if (id != UNDEFINED_STRAPPING_ID) + return id; + /* Update modem status in 9th bit of sku id */ uint32_t mask = 1 << 9; id = google_chromeec_get_board_sku();
