Attention is currently required from: Martin Roth. Furquan Shaikh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49242 )
Change subject: util/sconfig: Change __pci*|__pnp* device pointers to const ......................................................................
This change updates the device pointers exposed in static_devices.h to const instead of DEVTREE_CONST. The pointer itself doesn't really need to be DEVTREE_CONST.
Change-Id: I061b05d994fc5c4156ee8bddabadf940f0aeeac3 Signed-off-by: Furquan Shaikh furquan@google.com --- M util/sconfig/main.c 1 file changed, 4 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/49242/1
diff --git a/util/sconfig/main.c b/util/sconfig/main.c index 175b926..1af55ac 100644 --- a/util/sconfig/main.c +++ b/util/sconfig/main.c @@ -1211,16 +1211,16 @@ { /* Only devices on root bus here. */ if (ptr->bustype == PCI && ptr->parent->dev->bustype == DOMAIN) { - fprintf(head, "extern DEVTREE_CONST struct device *DEVTREE_CONST __pci_0_%02x_%d;\n", + fprintf(head, "extern DEVTREE_CONST struct device *const __pci_0_%02x_%d;\n", ptr->path_a, ptr->path_b); - fprintf(fil, "DEVTREE_CONST struct device *DEVTREE_CONST __pci_0_%02x_%d = &%s;\n", + fprintf(fil, "DEVTREE_CONST struct device *const __pci_0_%02x_%d = &%s;\n", ptr->path_a, ptr->path_b, ptr->name); }
if (ptr->bustype == PNP) { - fprintf(head, "extern DEVTREE_CONST struct device *DEVTREE_CONST __pnp_%04x_%02x;\n", + fprintf(head, "extern DEVTREE_CONST struct device *const __pnp_%04x_%02x;\n", ptr->path_a, ptr->path_b); - fprintf(fil, "DEVTREE_CONST struct device *DEVTREE_CONST __pnp_%04x_%02x = &%s;\n", + fprintf(fil, "DEVTREE_CONST struct device *const __pnp_%04x_%02x = &%s;\n", ptr->path_a, ptr->path_b, ptr->name); } }
