Felix Singer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/47754 )
Change subject: vc/intel/fsp2/denverton: Remove unused files ......................................................................
The Denverton SoC uses the header files from the git repository. Therefore, remove these from coreboot source.
Change-Id: Ib22d3f5e5ce83eb83bf589ea8bba7b55ebe44ea8 Signed-off-by: Felix Singer felixsinger@posteo.net --- M MAINTAINERS D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspUpd.h D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspmUpd.h D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspsUpd.h D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FsptUpd.h 5 files changed, 0 insertions(+), 1,157 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/54/47754/1
diff --git a/MAINTAINERS b/MAINTAINERS index 1f4df52..6a1f500 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -511,7 +511,6 @@ S: Odd Fixes F: src/mainboard/intel/harcuvar/ F: src/soc/intel/denverton_ns/ -F: src/vendorcode/intel/fsp/fsp2_0/denverton_ns/
INTEL FSP 1.1 M: Lee Leahy leroy.p.leahy@intel.com diff --git a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspUpd.h b/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspUpd.h deleted file mode 100644 index 1aa46a0..0000000 --- a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspUpd.h +++ /dev/null @@ -1,48 +0,0 @@ -/** @file - -Copyright (c) 2017, Intel Corporation. All rights reserved.<BR> - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - - This file is automatically generated. Please do NOT modify !!! - -**/ - -#ifndef __FSPUPD_H__ -#define __FSPUPD_H__ - -#include <FspEas.h> - -#pragma pack(1) - -#define FSPT_UPD_SIGNATURE 0x545F445055564E44 /* 'DNVUPD_T' */ - -#define FSPM_UPD_SIGNATURE 0x4D5F445055564E44 /* 'DNVUPD_M' */ - -#define FSPS_UPD_SIGNATURE 0x535F445055564E44 /* 'DNVUPD_S' */ - -#pragma pack() - -#endif diff --git a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspmUpd.h b/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspmUpd.h deleted file mode 100644 index 3aa74a0f..0000000 --- a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspmUpd.h +++ /dev/null @@ -1,710 +0,0 @@ -/** @file - -Copyright (c) 2017, Intel Corporation. All rights reserved.<BR> - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - - This file is automatically generated. Please do NOT modify !!! - -**/ - -#ifndef __FSPMUPD_H__ -#define __FSPMUPD_H__ - -#include <FspUpd.h> - -#pragma pack(1) - -#define MAX_CH 2 /* Maximum Number of Memory Channels */ -#define MAX_DIMM 2 /* Maximum Number of DIMMs PER Memory Channel */ -#define MAX_SPD_BYTES 512 /* Maximum Number of SPD bytes */ - -/* - * Memory Down structures. - */ -typedef enum { - STATE_MEMORY_SLOT = 0, /* No memory down and a physical memory slot. */ - STATE_MEMORY_DOWN = 1, /* Memory down and not a physical memory slot. */ -} MemorySlotState; - -typedef struct { - MemorySlotState SlotState[MAX_CH][MAX_DIMM]; /* Memory Down state of - each DIMM in each - Channel */ - UINT16 SpdDataLen; /* Length in Bytes of a single DIMM's SPD Data */ - UINT8 *SpdDataPtr[MAX_CH][MAX_DIMM]; /* Pointer to SPD Data for each - DIMM in each Channel */ -} MEMORY_DOWN_CONFIG; - -/* -* SMBIOS Memory Info structures. -*/ -typedef struct { - UINT8 DimmId; - UINT32 SizeInMb; - UINT16 MfgId; - UINT8 - ModulePartNum[20]; /* Module part number for DDR3 is 18 bytes - however for DRR4 20 bytes as per JEDEC Spec, - so reserving 20 bytes */ -} DIMM_INFO; - -typedef struct { - UINT8 ChannelId; - UINT8 DimmCount; - DIMM_INFO DimmInfo[MAX_DIMM]; -} CHANNEL_INFO; - -typedef struct { - UINT8 Revision; - UINT16 DataWidth; - /** As defined in SMBIOS 3.0 spec - Section 7.18.2 and Table 75 - **/ - UINT8 MemoryType; - UINT16 MemoryFrequencyInMHz; - /** As defined in SMBIOS 3.0 spec - Section 7.17.3 and Table 72 - **/ - UINT8 ErrorCorrectionType; - UINT8 ChannelCount; - CHANNEL_INFO ChannelInfo[MAX_CH]; -} FSP_SMBIOS_MEMORY_INFO; - -/* -* GBE PCD supported states. -*/ -typedef enum { - BL_GBE0_GBE1_DISABLED, - BL_GBE0_GBE1_ENABLED, - BL_GBE1_DISABLED, -} BL_GBE_PCD_STATE; - -/* -* FIA MUX configuration structures. -*/ - -#define BL_ME_FIA_MUX_LANE_NUM_MAX 20 -#define BL_ME_FIA_MUX_LANE_NUM_MIN 1 -#define BL_ME_FIA_MUX_LANE_MUX_SEL_WIDTH 2 -#define BL_ME_FIA_MUX_LANE_MUX_SEL_MASK 0x3 -#define BL_ME_FIA_MUX_LANE_XHCI_ONLY 0xFF00000000 - -typedef enum { - BL_FIA_LANE00 = 0, - BL_FIA_LANE01, - BL_FIA_LANE02, - BL_FIA_LANE03, - BL_FIA_LANE04, - BL_FIA_LANE05, - BL_FIA_LANE06, - BL_FIA_LANE07, - BL_FIA_LANE08, - BL_FIA_LANE09, - BL_FIA_LANE10, - BL_FIA_LANE11, - BL_FIA_LANE12, - BL_FIA_LANE13, - BL_FIA_LANE14, - BL_FIA_LANE15, - BL_FIA_LANE16, - BL_FIA_LANE17, - BL_FIA_LANE18, - BL_FIA_LANE19, -} BL_ME_FIA_MUX_LANE_ORDER; - -#define BL_ME_FIA_MUX_LANE_SATA0_BEGING BL_FIA_LANE04 -#define BL_ME_FIA_MUX_LANE_SATA1_BEGING BL_FIA_LANE12 - -#define BL_FIA_LANE_CONFIG(Config, Lane) \ - ((UINT64)((UINT64)(Config) \ - << ((UINT64)(Lane) * (BL_ME_FIA_MUX_LANE_MUX_SEL_WIDTH)))) - -typedef union _BL_ME_FIA_MUX_CONFIG { - UINT64 MeFiaMuxLaneConfig; - struct { - UINT64 Lane00MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE - UINT64 Lane01MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE - UINT64 Lane02MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE - UINT64 Lane03MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE - UINT64 Lane04MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane05MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane06MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane07MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane08MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane09MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane10MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane11MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane12MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane13MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane14MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane15MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or PCIE or - // SATA - UINT64 Lane16MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or XHCI or - // SATA - UINT64 Lane17MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or XHCI or - // SATA - UINT64 Lane18MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or XHCI or - // SATA - UINT64 Lane19MuxSel : 2; // ME_FIA_MUX_LANE_DISABLED or XHCI or - // SATA - UINT64 Reserved : 24; - } BL_MeFiaMuxLaneMuxSel; -} BL_ME_FIA_MUX_CONFIG; - -typedef enum { - BL_ME_FIA_MUX_LANE_DISCONNECTED, - BL_ME_FIA_MUX_LANE_PCIE, - BL_ME_FIA_MUX_LANE_SATA, - BL_ME_FIA_MUX_LANE_XHCI, -} BL_ME_FIA_MUX_LANE_CONFIG; - -#define BL_ME_FIA_SATA_LANE_SEL_WIDTH 2 -#define BL_ME_FIA_SATA_LANE_XHCI_ONLY 0x55000000 - -typedef enum { - BL_FIA_SATA_LANE04 = 0, - BL_FIA_SATA_LANE05, - BL_FIA_SATA_LANE06, - BL_FIA_SATA_LANE07, - BL_FIA_SATA_LANE08, - BL_FIA_SATA_LANE09, - BL_FIA_SATA_LANE10, - BL_FIA_SATA_LANE11, - BL_FIA_SATA_LANE12, - BL_FIA_SATA_LANE13, - BL_FIA_SATA_LANE14, - BL_FIA_SATA_LANE15, - BL_FIA_SATA_LANE16, - BL_FIA_SATA_LANE17, - BL_FIA_SATA_LANE18, - BL_FIA_SATA_LANE19 -} BL_ME_FIA_SATA_LANE_ORDER; - -#define BL_FIA_SATA_LANE_CONFIG(Config, Lane) \ - ((UINT32)((UINT32)(Config) \ - << ((UINT32)(Lane) * (BL_ME_FIA_SATA_LANE_SEL_WIDTH)))) - -typedef union _BL_ME_FIA_SATA_CONFIG { - UINT64 MeFiaSataLaneConfig; - struct { - UINT64 Lane04SataSel : 2; - UINT64 Lane05SataSel : 2; - UINT64 Lane06SataSel : 2; - UINT64 Lane07SataSel : 2; - UINT64 Lane08SataSel : 2; - UINT64 Lane09SataSel : 2; - UINT64 Lane10SataSel : 2; - UINT64 Lane11SataSel : 2; - UINT64 Lane12SataSel : 2; - UINT64 Lane13SataSel : 2; - UINT64 Lane14SataSel : 2; - UINT64 Lane15SataSel : 2; - UINT64 Lane16SataSel : 2; - UINT64 Lane17SataSel : 2; - UINT64 Lane18SataSel : 2; - UINT64 Lane19SataSel : 2; - UINT64 Reserved : 32; - } BL_MeFiaSataLaneSataSel; -} BL_ME_FIA_SATA_CONFIG; - -typedef enum { - BL_ME_FIA_SATA_CONTROLLER_LANE_ASSIGNED = 0, - BL_ME_FIA_SATA_CONTROLLER_LANE_NOT_ASSIGNED = 1, - BL_ME_FIA_SATA_CONTROLLER_LANE_SS_AND_GPIO_ASSIGNED = 3 -} BL_ME_FIA_SATA_LANE_CONFIG; - -#define BL_ME_FIA_PCIE_ROOT_PORT_LINK_WIDTH_SEL_WIDTH 4 -#define BL_ME_FIA_PCIE_ROOT_PORTS_STATE_WIDTH 8 -#define BL_ME_FIA_PCIE_ROOT_CONFIG_XHCI_ONLY 0x0 - -typedef enum { - BL_FIA_PCIE_ROOT_PORT_0 = 0, - BL_FIA_PCIE_ROOT_PORT_1, - BL_FIA_PCIE_ROOT_PORT_2, - BL_FIA_PCIE_ROOT_PORT_3, - BL_FIA_PCIE_ROOT_PORT_4, - BL_FIA_PCIE_ROOT_PORT_5, - BL_FIA_PCIE_ROOT_PORT_6, - BL_FIA_PCIE_ROOT_PORT_7 -} BL_ME_FIA_PCIE_ROOT_PORT_ORDER; - -#define BL_FIA_PCIE_ROOT_PORT_CONFIG(Type, Config, PcieRootPort) \ - (((Type) == BL_ME_FIA_PCIE_ROOT_PORT_STATE) \ - ? ((UINT64)((UINT64)(Config) << (UINT64)(PcieRootPort))) \ - : ((UINT64)( \ - (UINT64)(Config) << (UINT64)( \ - ((UINT64)(PcieRootPort) * \ - (BL_ME_FIA_PCIE_ROOT_PORT_LINK_WIDTH_SEL_WIDTH)) + \ - BL_ME_FIA_PCIE_ROOT_PORTS_STATE_WIDTH)))) - -typedef union _BL_ME_FIA_PCIE_ROOT_PORTS_CONFIG { - UINT64 MeFiaPcieRootPortsConfig; - struct { - UINT64 PcieRp0En : 1; - UINT64 PcieRp1En : 1; - UINT64 PcieRp2En : 1; - UINT64 PcieRp3En : 1; - UINT64 PcieRp4En : 1; - UINT64 PcieRp5En : 1; - UINT64 PcieRp6En : 1; - UINT64 PcieRp7En : 1; - UINT64 PcieRp0LinkWidth : 4; - UINT64 PcieRp1LinkWidth : 4; - UINT64 PcieRp2LinkWidth : 4; - UINT64 PcieRp3LinkWidth : 4; - UINT64 PcieRp4LinkWidth : 4; - UINT64 PcieRp5LinkWidth : 4; - UINT64 PcieRp6LinkWidth : 4; - UINT64 PcieRp7LinkWidth : 4; - UINT64 Reserved : 24; - } BL_MeFiaPcieRpConfig; -} BL_ME_FIA_PCIE_ROOT_PORTS_CONFIG; - -typedef enum { - BL_ME_FIA_PCIE_ROOT_PORT_STATE, - BL_ME_FIA_PCIE_ROOT_PORT_LINK_WIDTH -} BL_ME_FIA_PCIE_ROOT_PORT_CONFIG_TYPE; - -typedef enum { - BL_ME_FIA_PCIE_ROOT_PORT_DISABLED, - BL_ME_FIA_PCIE_ROOT_PORT_ENABLED -} BL_ME_FIA_PCIE_ROOT_PORT_STATE_CONFIG; - -typedef enum { - BL_ME_FIA_PCIE_ROOT_PORT_LINK_WIDTH_BICTRL = 0, - BL_ME_FIA_PCIE_ROOT_PORT_LINK_X1 = 0xF -} BL_ME_FIA_PCIE_ROOT_PORT_LINK_CONFIG; - -typedef struct _BL_ME_FIA_CONFIG { - BL_ME_FIA_MUX_CONFIG MuxConfiguration; - BL_ME_FIA_SATA_CONFIG SataLaneConfiguration; - BL_ME_FIA_PCIE_ROOT_PORTS_CONFIG PcieRootPortsConfiguration; -} BL_ME_FIA_CONFIG; - -/* - * The FIA_MUX_CONFIG block describes the expected configuration of - * FIA MUX configuration. - */ -typedef struct { - UINT32 SkuNumLanesAllowed; // Platform view of Num Lanes allowed - BL_ME_FIA_CONFIG FiaMuxConfig; // Current Platform FIA MUX Configuration - BL_ME_FIA_CONFIG FiaMuxConfigRequest; // FIA MUX Configuration Requested -} BL_FIA_MUX_CONFIG; - -/* - * The FIA_MUX_CONFIG_STATUS describes the status of configuring - * FIA MUX configuration. -*/ -typedef struct { - UINT64 FiaMuxConfigGetStatus; // Status returned from FiaMuxConfigGet, - // if not EFI_SUCCESS, then error occurred - // and user can decide on next steps - UINT64 FiaMuxConfigSetStatus; // Status returned from FiaMuxConfigSet, - // if not EFI_SUCCESS, then error occurred - // and user can decide on next steps - BOOLEAN FiaMuxConfigSetRequired; // Boolean: true - a FiaMuxConfigSet - // was required, false otherwise -} BL_FIA_MUX_CONFIG_STATUS; - -/* -* FIA MUX Config HOB structure -*/ -typedef struct { - BL_FIA_MUX_CONFIG FiaMuxConfig; - BL_FIA_MUX_CONFIG_STATUS FiaMuxConfigStatus; -} BL_FIA_MUX_CONFIG_HOB; - -/* PCIe port bifurcation codes - matches setup option values */ -#define PCIE_BIF_CTRL_x2x2x2x2 0 -#define PCIE_BIF_CTRL_x2x2x4 1 -#define PCIE_BIF_CTRL_x4x2x2 2 -#define PCIE_BIF_CTRL_x4x4 3 -#define PCIE_BIF_CTRL_x8 4 - -#define BL_MAX_PCIE_CTRL 2 - -/* - * HSIO INFORMATION structure - */ -typedef enum { - BL_SKU_HSIO_06 = 6, - BL_SKU_HSIO_08 = 8, - BL_SKU_HSIO_10 = 10, - BL_SKU_HSIO_12 = 12, - BL_SKU_HSIO_20 = 20, -} BL_SKU_HSIO_LANE_NUMBER; - -typedef struct { - UINT16 NumLanesSupported; - UINT8 PcieBifCtr[BL_MAX_PCIE_CTRL]; - BL_ME_FIA_CONFIG FiaConfig; -} BL_HSIO_INFORMATION; - -/* - * eMMC DLL structure for EMMC DLL registers settings - */ -typedef struct { - UINT32 TxCmdCntl; - UINT32 TxDataCntl1; - UINT32 TxDataCntl2; - UINT32 RxCmdDataCntl1; - UINT32 RxStrobeCntl; - UINT32 RxCmdDataCntl2; - UINT32 MasterSwCntl; -} BL_EMMC_DLL_CONFIG; - -typedef struct { - UINT16 Signature; - BL_EMMC_DLL_CONFIG eMMCDLLConfig; -} BL_EMMC_INFORMATION; - -typedef enum { - BL_FAST_BOOT_CHECKER_NORMAL = 0, - BL_FAST_BOOT_CHECKER_WARNING, - BL_FAST_BOOT_CHECKER_CRITICAL -} BL_FAST_BOOT_CHECKER; - -#define BL_MAX_SCRUB_SEGMENTS 5 - -typedef struct { - UINT16 Start; // Determines the low range for a memory segment (in MB) - UINT16 End; // Determines the high range for a memory segment (in MB) -} BL_SCRUB_SEGMENT; - -typedef struct { - UINT8 NumberOfSegments; - UINT8 Reserved; - BL_SCRUB_SEGMENT ScrubSegment[BL_MAX_SCRUB_SEGMENTS]; -} BL_MEMORY_SCRUB_SEGMENTS; - -/** Fsp M Configuration -**/ -typedef struct { - - /** Offset 0x0040 - Tseg Size - Size of SMRAM memory reserved. - 2:2 MB, 4:4 MB, 8:8 MB, 16:16 MB - **/ - UINT8 PcdSmmTsegSize; - - /** Offset 0x0041 - FSP Debug Print Level - Select the FSP debug message print level. - 0:NO DEBUG, 1:MIN DEBUG, 2:MED DEBUG, 3:VERBOSE DEBUG - **/ - UINT8 PcdFspDebugPrintErrorLevel; - - /** Offset 0x0042 - Channel 0 DIMM 0 SPD SMBus Address - SPD SMBus Address of each DIMM slot. - **/ - UINT8 PcdSpdSmbusAddress_0_0; - - /** Offset 0x0043 - Channel 0 DIMM 1 SPD SMBus Address - SPD SMBus Address of each DIMM slot. - **/ - UINT8 PcdSpdSmbusAddress_0_1; - - /** Offset 0x0044 - Channel 1 DIMM 0 SPD SMBus Address - SPD SMBus Address of each DIMM slot. - **/ - UINT8 PcdSpdSmbusAddress_1_0; - - /** Offset 0x0045 - Channel 1 DIMM 1 SPD SMBus Address - SPD SMBus Address of each DIMM slot. - **/ - UINT8 PcdSpdSmbusAddress_1_1; - - /** Offset 0x0046 - Enable Rank Margin Tool - Enable/disable Rank Margin Tool. - $EN_DIS - **/ - UINT8 PcdMrcRmtSupport; - - /** Offset 0x0047 - RMT CPGC exp_loop_cnt - Set the CPGC exp_loop_cnt field for RMT execution 2^(exp_loop_cnt -1). - 1:1, 2:2, 3:3, 4:4, 5:5, 6:6, 7:7, 8:8, 9:9, 10:10, 11:11, 12:12, - 13:13, 14:14, 15:15 - **/ - UINT8 PcdMrcRmtCpgcExpLoopCntValue; - - /** Offset 0x0048 - RMT CPGC num_bursts - Set the CPGC num_bursts field for RMT execution 2^(num_bursts -1). - 1:1, 2:2, 3:3, 4:4, 5:5, 6:6, 7:7, 8:8, 9:9, 10:10, 11:11, 12:12, - 13:13, 14:14, 15:15 - **/ - UINT8 PcdMrcRmtCpgcNumBursts; - - /** Offset 0x0049 - Preserve Memory Across Reset - Enable/disable memory preservation across reset. - $EN_DIS - **/ - UINT8 PcdMemoryPreservation; - - /** Offset 0x004A - Fast Boot - Enable/disable Fast Boot function. Once enabled, all following boots - will use the - presaved MRC data to improve the boot performance. - $EN_DIS - **/ - UINT8 PcdFastBoot; - - /** Offset 0x004B - ECC Support - Enable/disable ECC Support. - $EN_DIS - **/ - UINT8 PcdEccSupport; - - /** Offset 0x004C - HSUART Device - Select the PCI High Speed UART Device for Serial Port. - 0:HSUART0, 1:HSUART1, 2:HSUART2 - **/ - UINT8 PcdHsuartDevice; - - /** Offset 0x004D - Memory Down - Enable/disable Memory Down function. - $EN_DIS - **/ - UINT8 PcdMemoryDown; - - /** Offset 0x004E - **/ - UINT32 PcdMemoryDownConfigPtr; - - /** Offset 0x0052 - SATA Controller 0 - Enable/disable SATA Controller 0. - $EN_DIS - **/ - UINT8 PcdEnableSATA0; - - /** Offset 0x0053 - SATA Controller 1 - Enable/disable SATA Controller 1. - $EN_DIS - **/ - UINT8 PcdEnableSATA1; - - /** Offset 0x0054 - Intel Quick Assist Technology - Enable/disable Intel Quick Assist Technology. - $EN_DIS - **/ - UINT8 PcdEnableIQAT; - - /** Offset 0x0055 - SPD Write Disable - Select SMBus SPD Write Enable State (Default: 0 = [FORCE_ENABLE], 1 = - [FORCE_DISABLE]) - 0:Force Enable, 1:Force Disable - **/ - UINT8 PcdSmbusSpdWriteDisable; - - /** Offset 0x0056 - ME_SHUTDOWN Message - Enable/Disable sending ME_SHUTDOWN message to ME, refer to FSP - Integration Guide - for details. - $EN_DIS - **/ - UINT8 PcdEnableMeShutdown; - - /** Offset 0x0057 - XHCI Controller - Enable / Disable XHCI controller - $EN_DIS - **/ - UINT8 PcdEnableXhci; - - /** Offset 0x0058 - Memory Frequency - Set DDR Memory Frequency, refer to FSP Integration Guide for details. - 15:Auto, 3:1600, 4:1866, 5:2133, 6:2400 - **/ - UINT8 PcdDdrFreq; - - /** Offset 0x0059 - MMIO Size - Set memory mapped IO space size - 0:2048M, 1:1024M, 2:3072M - **/ - UINT8 PcdMmioSize; - - /** Offset 0x005A - ME HECI Communication - Enable/Disable ME HECI communication - $EN_DIS - **/ - UINT8 PcdMeHeciCommunication; - - /** Offset 0x005B - HSIO Lanes Number - HSIO lanes number of SKU - 6:6, 8:8, 10:10, 12:12, 20:20 - **/ - UINT8 PcdHsioLanesNumber; - - /** Offset 0x005C - **/ - UINT32 PcdFiaMuxConfigPtr; - - /** Offset 0x0060 - Customer Revision - The Customer can set this revision string for their own purpose. - **/ - UINT8 PcdCustomerRevision[32]; - - /** Offset 0x0080 - 32-Bit bus mode - Enable/Disable 32-Bit bus memory mode. - $EN_DIS - **/ - UINT8 PcdHalfWidthEnable; - - /** Offset 0x0081 - TCL Performance - Enable/Disable Tcl timing for performance. - $EN_DIS - **/ - UINT8 PcdTclIdle; - - /** Offset 0x0082 - Interleave Mode - Select Interleave Mode - 0:DISABLED, 1:MODE0, 2:MODE1, 3:MODE2 - **/ - UINT8 PcdInterleaveMode; - - /** Offset 0x0083 - Memory Thermal Throttling - Enable/disable Memory Thermal Throttling management mode - $EN_DIS - **/ - UINT8 PcdMemoryThermalThrottling; - - /** Offset 0x0084 - Memory Test - Enable / Disable Memory Test, refer to FSP Integration Guide for - details. - $EN_DIS - **/ - UINT8 PcdSkipMemoryTest; - - /** Offset 0x0085 - **/ - BL_MEMORY_SCRUB_SEGMENTS *PcdScrubSegmentPtr; - - /** Offset 0x0089 - USB2 Port 1 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb2Port1Pin; - - /** Offset 0x008A - USB2 Port 2 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb2Port2Pin; - - /** Offset 0x008B - USB2 Port 3 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb2Port3Pin; - - /** Offset 0x008C - USB2 Port 4 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb2Port4Pin; - - /** Offset 0x008D - USB3 Port 1 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb3Port1Pin; - - /** Offset 0x008E - USB3 Port 2 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb3Port2Pin; - - /** Offset 0x008F - USB3 Port 3 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb3Port3Pin; - - /** Offset 0x0090 - USB3 Port 4 OC Pin - Map selected OC pin to the port - 0:OC Pin 0, 8:No pin mapped - **/ - UINT8 PcdUsb3Port4Pin; - - /** Offset 0x0091 - IOxAPIC 0-199 - Enable/disable IOxAPIC 24-119 entries - $EN_DIS - **/ - UINT8 PcdIOxAPIC0_199; - - /** Offset 0x0092 - DMAP_X16 - Enable/Disable DMAP_X16 dynamic MRC field indicating memory device - width is x16 or not - $EN_DIS - **/ - UINT8 PcdDmapX16; - - /** Offset 0x0093 - **/ - UINT8 UnusedUpdSpace0[333]; - - /** Offset 0x01E0 - **/ - UINT8 ReservedMemoryInitUpd[16]; -} FSP_M_CONFIG; - -/** Fsp M UPD Configuration -**/ -typedef struct { - - /** Offset 0x0000 - **/ - FSP_UPD_HEADER FspUpdHeader; - - /** Offset 0x0020 - **/ - FSPM_ARCH_UPD FspmArchUpd; - - /** Offset 0x0040 - **/ - FSP_M_CONFIG FspmConfig; - - /** Offset 0x01F0 - **/ - UINT8 UnusedUpdSpace1[14]; - - /** Offset 0x01FE - **/ - UINT16 UpdTerminator; -} FSPM_UPD; - -#pragma pack() - -#endif diff --git a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspsUpd.h b/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspsUpd.h deleted file mode 100644 index f76f1a5..0000000 --- a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspsUpd.h +++ /dev/null @@ -1,289 +0,0 @@ -/** @file - -Copyright (c) 2017, Intel Corporation. All rights reserved.<BR> - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - - This file is automatically generated. Please do NOT modify !!! - -**/ - -#ifndef __FSPSUPD_H__ -#define __FSPSUPD_H__ - -#include <FspUpd.h> - -#pragma pack(1) - -/** Fsp S Configuration -**/ -typedef struct { - - /** Offset 0x0020 - PCIe Controller 0 Bifurcation - Configure PCI Express controller 0 bifurcation. - 0:X2X2X2X2, 1:X2X2X4, 2:X4X2X2, 3:X4X4, 4:X8 - **/ - UINT8 PcdBifurcationPcie0; - - /** Offset 0x0021 - PCIe Controller 1 Bifurcation - Configure PCI Express controller 1 bifurcation. - 0:X2X2X2X2, 1:X2X2X4, 2:X4X2X2, 3:X4X4, 4:X8 - **/ - UINT8 PcdBifurcationPcie1; - - /** Offset 0x0022 - Active Core Count - Select # of Active Cores (Default: 0, 0:ALL, 1..15 = 1..15 Cores) - 0:ALL, 1:1, 2:2, 3:3, 4:4, 5:5, 6:6, 7:7, 8:8, 9:9, 10:10, 11:11, - 12:12, 13:13, - 14:14, 15:15 - **/ - UINT8 PcdActiveCoreCount; - - /** Offset 0x0023 - **/ - UINT32 PcdCpuMicrocodePatchBase; - - /** Offset 0x0027 - **/ - UINT32 PcdCpuMicrocodePatchSize; - - /** Offset 0x002B - PCIe Controller 0 - Enable / Disable PCI Express controller 0 - $EN_DIS - **/ - UINT8 PcdEnablePcie0; - - /** Offset 0x002C - PCIe Controller 1 - Enable / Disable PCI Express controller 1 - $EN_DIS - **/ - UINT8 PcdEnablePcie1; - - /** Offset 0x002D - Embedded Multi-Media Controller (eMMC) - Enable / Disable Embedded Multi-Media controller - $EN_DIS - **/ - UINT8 PcdEnableEmmc; - - /** Offset 0x002E - LAN Controllers - Enable / Disable LAN controllers, refer to FSP Integration Guide for - details. - 0:Disable LAN 0 & LAN 1, 1:Enable LAN 0 & LAN 1, 2:Disable LAN 1 only - **/ - UINT8 PcdEnableGbE; - - /** Offset 0x002F - **/ - UINT32 PcdFiaMuxConfigRequestPtr; - - /** Offset 0x0033 - **/ - UINT8 UnusedUpdSpace0[4]; - - /** Offset 0x0037 - PCIe Root Port 0 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort0DeEmphasis; - - /** Offset 0x0038 - PCIe Root Port 1 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort1DeEmphasis; - - /** Offset 0x0039 - PCIe Root Port 2 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort2DeEmphasis; - - /** Offset 0x003A - PCIe Root Port 3 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort3DeEmphasis; - - /** Offset 0x003B - PCIe Root Port 4 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort4DeEmphasis; - - /** Offset 0x003C - PCIe Root Port 5 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort5DeEmphasis; - - /** Offset 0x003D - PCIe Root Port 6 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort6DeEmphasis; - - /** Offset 0x003E - PCIe Root Port 7 DeEmphasis - Desired DeEmphasis level for PCIE root port - 0:6dB, 1:3.5dB - **/ - UINT8 PcdPcieRootPort7DeEmphasis; - - /** Offset 0x003F - **/ - UINT8 UnusedUpdSpace1; - - /** Offset 0x0040 - **/ - UINT32 PcdEMMCDLLConfigPtr; - - /** Offset 0x0044 - PCIe Root Port 0 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort0LinkSpeed; - - /** Offset 0x0045 - PCIe Root Port 1 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort1LinkSpeed; - - /** Offset 0x0046 - PCIe Root Port 2 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort2LinkSpeed; - - /** Offset 0x0047 - PCIe Root Port 3 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort3LinkSpeed; - - /** Offset 0x0048 - PCIe Root Port 4 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort4LinkSpeed; - - /** Offset 0x0049 - PCIe Root Port 5 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort5LinkSpeed; - - /** Offset 0x004A - PCIe Root Port 6 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort6LinkSpeed; - - /** Offset 0x004B - PCIe Root Port 7 Link Speed - Upper limit on link operational speed for PCI Express RootPort - 1:GEN1, 2:GEN2, 3:GEN3 - **/ - UINT8 PcdPcieRootPort7LinkSpeed; - - /** Offset 0x004C - PCIe Root Port 0 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort0Aspm; - - /** Offset 0x004D - PCIe Root Port 1 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort1Aspm; - - /** Offset 0x004E - PCIe Root Port 2 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort2Aspm; - - /** Offset 0x004F - PCIe Root Port 3 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort3Aspm; - - /** Offset 0x0050 - PCIe Root Port 4 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort4Aspm; - - /** Offset 0x0051 - PCIe Root Port 5 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort5Aspm; - - /** Offset 0x0052 - PCIe Root Port 6 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort6Aspm; - - /** Offset 0x0053 - PCIe Root Port 7 ASPM - Enable PCI Express Active State Power Management settings - 0:Disabled, 2:L1 - **/ - UINT8 PcdPcieRootPort7Aspm; - - /** Offset 0x0054 - **/ - UINT8 UnusedUpdSpace2[140]; - - /** Offset 0x00E0 - **/ - UINT8 ReservedSiliconInitUpd[16]; -} FSP_S_CONFIG; - -/** Fsp S UPD Configuration -**/ -typedef struct { - - /** Offset 0x0000 - **/ - FSP_UPD_HEADER FspUpdHeader; - - /** Offset 0x0020 - **/ - FSP_S_CONFIG FspsConfig; - - /** Offset 0x00F0 - **/ - UINT8 UnusedUpdSpace3[14]; - - /** Offset 0x00FE - **/ - UINT16 UpdTerminator; -} FSPS_UPD; - -#pragma pack() - -#endif diff --git a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FsptUpd.h b/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FsptUpd.h deleted file mode 100644 index f06f72bd..0000000 --- a/src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FsptUpd.h +++ /dev/null @@ -1,109 +0,0 @@ -/** @file - -Copyright (c) 2017, Intel Corporation. All rights reserved.<BR> - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - - This file is automatically generated. Please do NOT modify !!! - -**/ - -#ifndef __FSPTUPD_H__ -#define __FSPTUPD_H__ - -#include <FspUpd.h> - -#pragma pack(1) - -/** Fsp T Core UPD -**/ -typedef struct { - - /** Offset 0x0020 - **/ - UINT32 MicrocodeRegionBase; - - /** Offset 0x0024 - **/ - UINT32 MicrocodeRegionLength; - - /** Offset 0x0028 - **/ - UINT32 CodeRegionBase; - - /** Offset 0x002C - **/ - UINT32 CodeRegionLength; - - /** Offset 0x0030 - **/ - UINT8 Reserved1[16]; -} FSPT_CORE_UPD; - -/** Fsp T Configuration -**/ -typedef struct { - - /** Offset 0x0040 - Disable Port80 output in FSP-T - Select Port80 Control in FSP-T (0:VPD-Style, 1:Enable Port80 Output, - 2:Disable Port80 - Output, refer to FSP Integration Guide for details - 0:VPD-Style, 1:Enable Port80 Output[Default], 2:Disable Port80 Output - **/ - UINT8 PcdFsptPort80RouteDisable; - - /** Offset 0x0041 - **/ - UINT8 ReservedTempRamInitUpd[31]; -} FSPT_CONFIG; - -/** Fsp T UPD Configuration -**/ -typedef struct { - - /** Offset 0x0000 - **/ - FSP_UPD_HEADER FspUpdHeader; - - /** Offset 0x0020 - **/ - FSPT_CORE_UPD FsptCoreUpd; - - /** Offset 0x0040 - **/ - FSPT_CONFIG FsptConfig; - - /** Offset 0x0060 - **/ - UINT8 UnusedUpdSpace0[30]; - - /** Offset 0x007E - **/ - UINT16 UpdTerminator; -} FSPT_UPD; - -#pragma pack() - -#endif
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47754 )
Patch Set 1: Code-Review+2
Patch Set 1:
(3 comments)
https://review.coreboot.org/c/coreboot/+/47754/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/47754/1//COMMIT_MSG@7 PS1, Line 7: denverton denverton_ns
https://review.coreboot.org/c/coreboot/+/47754/1//COMMIT_MSG@9 PS1, Line 9: Denverton SoC Denverton-NS SoC
https://review.coreboot.org/c/coreboot/+/47754/1//COMMIT_MSG@9 PS1, Line 9: git repository from the FSP git repository
Hello build bot (Jenkins), David Guckian, Vanessa Eusebio, Michael Niewöhner, Patrick Rudolph,
Change subject: vc/intel/fsp2/denverton_ns: Remove unused files ......................................................................
The Denverton-NS SoC uses the header files from the FSP git repository. Therefore, remove these from coreboot source.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/54/47754/2
Felix Singer has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47754 )
Patch Set 2:
(3 comments)
denverton_ns
Done
Denverton-NS SoC
Done
Done
Mariusz Szafrański has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47754 )
Patch Set 2: Code-Review+2
Patch Set 2:
FSP headers should be in sync with FSP binary so using headers from FSP repo is the best methods to keep them in sync.
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47754 )
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47754 )
Michael Niewöhner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/47754 )
Change-Id: Ib22d3f5e5ce83eb83bf589ea8bba7b55ebe44ea8 Signed-off-by: Felix Singer felixsinger@posteo.net Reviewed-on: https://review.coreboot.org/c/coreboot/+/47754 Reviewed-by: Mariusz Szafrański mariuszx.szafranski@intel.com Reviewed-by: Arthur Heymans arthur@aheymans.xyz Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Michael Niewöhner foss@mniewoehner.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M MAINTAINERS D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspUpd.h D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspmUpd.h D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FspsUpd.h D src/vendorcode/intel/fsp/fsp2_0/denverton_ns/FsptUpd.h 5 files changed, 0 insertions(+), 1,157 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved Mariusz Szafrański: Looks good to me, approved Angel Pons: Looks good to me, approved Michael Niewöhner: Looks good to me, approved
