Hello Richard Spiegel, Martin Roth, Furquan Shaikh,
https://review.coreboot.org/c/coreboot/+/32644
Change subject: soc/amd/stoneyridge: Rewrite smbus_read/write, add asf ......................................................................
Convert smbus_read8() and smbus_write8() functions to use the same arguments as the other AcpiMmio blocks, and add 16 and 32 bit versions. Add matching functions for the ASF controller.
Change-Id: I3b0ecf21f20472245da98ab5e711a54e99dca93a Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com --- M src/soc/amd/stoneyridge/include/soc/southbridge.h M src/soc/amd/stoneyridge/sb_util.c M src/soc/amd/stoneyridge/smbus.c M src/soc/amd/stoneyridge/southbridge.c 4 files changed, 102 insertions(+), 34 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/32644/1
diff --git a/src/soc/amd/stoneyridge/include/soc/southbridge.h b/src/soc/amd/stoneyridge/include/soc/southbridge.h index 9fa93c8..aed3288 100644 --- a/src/soc/amd/stoneyridge/include/soc/southbridge.h +++ b/src/soc/amd/stoneyridge/include/soc/southbridge.h @@ -525,8 +525,14 @@ uint16_t xhci_pm_read16(uint8_t reg); void xhci_pm_write32(uint8_t reg, uint32_t value); uint32_t xhci_pm_read32(uint8_t reg); -void smbus_write8(uint32_t mmio, uint8_t reg, uint8_t value); -uint8_t smbus_read8(uint32_t mmio, uint8_t reg); +uint8_t asf_read8(uint8_t offset); +uint16_t asf_read16(uint8_t offset); +void asf_write8(uint8_t offset, uint8_t value); +void asf_write16(uint8_t offset, uint16_t value); +uint8_t smbus_read8(uint8_t offset); +uint16_t smbus_read16(uint8_t offset); +void smbus_write8(uint8_t offset, uint8_t value); +void smbus_write16(uint8_t offset, uint16_t value); void bootblock_fch_early_init(void); void bootblock_fch_init(void); /** diff --git a/src/soc/amd/stoneyridge/sb_util.c b/src/soc/amd/stoneyridge/sb_util.c index b777b1a..4bffdbc 100644 --- a/src/soc/amd/stoneyridge/sb_util.c +++ b/src/soc/amd/stoneyridge/sb_util.c @@ -167,16 +167,48 @@ write32((void *)(ACPIMMIO_ACPI_BASE + reg), value); }
-/* smbus read/write - access registers at 0xfed80a00 and ASF at 0xfed80900 */ +/* asf read/write - access registers at 0xfed80900 - not currently used */
-void smbus_write8(uint32_t mmio, uint8_t reg, uint8_t value) +u8 asf_read8(u8 reg) { - write8((void *)(mmio + reg), value); + return read8((void *)(ACPIMMIO_ASF_BASE + reg)); }
-uint8_t smbus_read8(uint32_t mmio, uint8_t reg) +u16 asf_read16(u8 reg) { - return read8((void *)(mmio + reg)); + return read16((void *)(ACPIMMIO_ASF_BASE + reg)); +} + +void asf_write8(u8 reg, u8 value) +{ + write8((void *)(ACPIMMIO_ASF_BASE + reg), value); +} + +void asf_write16(u8 reg, u16 value) +{ + write16((void *)(ACPIMMIO_ASF_BASE + reg), value); +} + +/* smbus read/write - access registers at 0xfed80a00 and ASF at 0xfed80900 */ + +u8 smbus_read8(u8 reg) +{ + return read8((void *)(ACPIMMIO_SMBUS_BASE + reg)); +} + +u16 smbus_read16(u8 reg) +{ + return read16((void *)(ACPIMMIO_SMBUS_BASE + reg)); +} + +void smbus_write8(u8 reg, u8 value) +{ + write8((void *)(ACPIMMIO_SMBUS_BASE + reg), value); +} + +void smbus_write16(u8 reg, u16 value) +{ + write16((void *)(ACPIMMIO_SMBUS_BASE + reg), value); }
/* wdt read/write - access registers at 0xfed80b00 - not currently used */ diff --git a/src/soc/amd/stoneyridge/smbus.c b/src/soc/amd/stoneyridge/smbus.c index c4a022a..6285d79 100644 --- a/src/soc/amd/stoneyridge/smbus.c +++ b/src/soc/amd/stoneyridge/smbus.c @@ -15,21 +15,51 @@
#include <arch/io.h> #include <stdint.h> +#include <console/console.h> #include <soc/smbus.h> #include <soc/southbridge.h>
+static u8 controller_read8(u32 base, u8 reg) +{ + switch (base) { + case ACPIMMIO_SMBUS_BASE: + return smbus_read8(reg); + case ACPIMMIO_ASF_BASE: + return asf_read8(reg); + default: + printk(BIOS_ERR, "Error attempting to read SMBus at address 0x%x\n", + base); + } + return 0xff; +} + +static void controller_write8(u32 base, u8 reg, u8 val) +{ + switch (base) { + case ACPIMMIO_SMBUS_BASE: + smbus_write8(reg, val); + break; + case ACPIMMIO_ASF_BASE: + asf_write8(reg, val); + break; + default: + printk(BIOS_ERR, "Error attempting to write SMBus at address 0x%x\n", + base); + } +} + static int smbus_wait_until_ready(u32 mmio) { u32 loops; loops = SMBUS_TIMEOUT; do { u8 val; - val = smbus_read8(mmio, SMBHSTSTAT); + val = controller_read8(mmio, SMBHSTSTAT); val &= SMBHST_STAT_VAL_BITS; if (val == 0) { /* ready now */ return 0; } - smbus_write8(mmio, SMBHSTSTAT, val); + controller_write8(mmio, SMBHSTSTAT, val); } while (--loops); return -2; /* time out */ } @@ -41,12 +71,12 @@ do { u8 val;
- val = smbus_read8(mmio, SMBHSTSTAT); + val = controller_read8(mmio, SMBHSTSTAT); val &= SMBHST_STAT_VAL_BITS; /* mask off reserved bits */ if (val & SMBHST_STAT_ERROR_BITS) return -5; /* error */ if (val == SMBHST_STAT_NOERROR) { - smbus_write8(mmio, SMBHSTSTAT, val); /* clear sts */ + controller_write8(mmio, SMBHSTSTAT, val); /* clr sts */ return 0; } } while (--loops); @@ -61,19 +91,19 @@ return -2; /* not ready */
/* set the device I'm talking to */ - smbus_write8(mmio, SMBHSTADDR, ((device & 0x7f) << 1) | 1); + controller_write8(mmio, SMBHSTADDR, ((device & 0x7f) << 1) | 1);
- byte = smbus_read8(mmio, SMBHSTCTRL); + byte = controller_read8(mmio, SMBHSTCTRL); byte &= ~SMBHST_CTRL_MODE_BITS; /* Clear [4:2] */ byte |= SMBHST_CTRL_STRT | SMBHST_CTRL_BTE_RW; /* set mode, start */ - smbus_write8(mmio, SMBHSTCTRL, byte); + controller_write8(mmio, SMBHSTCTRL, byte);
/* poll for transaction completion */ if (smbus_wait_until_done(mmio) < 0) return -3; /* timeout or error */
/* read results of transaction */ - byte = smbus_read8(mmio, SMBHSTDAT0); + byte = controller_read8(mmio, SMBHSTDAT0);
return byte; } @@ -86,15 +116,15 @@ return -2; /* not ready */
/* set the command... */ - smbus_write8(mmio, SMBHSTDAT0, val); + controller_write8(mmio, SMBHSTDAT0, val);
/* set the device I'm talking to */ - smbus_write8(mmio, SMBHSTADDR, ((device & 0x7f) << 1) | 0); + controller_write8(mmio, SMBHSTADDR, ((device & 0x7f) << 1) | 0);
/* poll for transaction completion */ if (smbus_wait_until_done(mmio) < 0) @@ -111,22 +141,22 @@ return -2; /* not ready */
/* set the command/address... */ - smbus_write8(mmio, SMBHSTCMD, address & 0xff); + controller_write8(mmio, SMBHSTCMD, address & 0xff);
- byte = smbus_read8(mmio, SMBHSTCTRL); + byte = controller_read8(mmio, SMBHSTCTRL); byte &= ~SMBHST_CTRL_MODE_BITS; /* Clear [4:2] */ byte |= SMBHST_CTRL_STRT | SMBHST_CTRL_BDT_RW; /* set mode, start */ - smbus_write8(mmio, SMBHSTCTRL, byte); + controller_write8(mmio, SMBHSTCTRL, byte);
return byte; } @@ -139,18 +169,18 @@ return -2; /* not ready */
/* output value */ - smbus_write8(mmio, SMBHSTDAT0, val); + controller_write8(mmio, SMBHSTDAT0, val);
/* poll for transaction completion */ if (smbus_wait_until_done(mmio) < 0) diff --git a/src/soc/amd/stoneyridge/southbridge.c b/src/soc/amd/stoneyridge/southbridge.c index 4f9e8ef..66894a2 100644 --- a/src/soc/amd/stoneyridge/southbridge.c +++ b/src/soc/amd/stoneyridge/southbridge.c @@ -632,12 +632,12 @@ static void fch_smbus_init(void) { pm_write8(SMB_ASF_IO_BASE, SMB_BASE_ADDR >> 8); - smbus_write8(ACPIMMIO_SMBUS_BASE, SMBTIMING, SMB_SPEED_400KHZ); + smbus_write8(SMBTIMING, SMB_SPEED_400KHZ); /* Clear all SMBUS status bits */ - smbus_write8(ACPIMMIO_SMBUS_BASE, SMBHSTSTAT, SMBHST_STAT_CLEAR); - smbus_write8(ACPIMMIO_SMBUS_BASE, SMBSLVSTAT, SMBSLV_STAT_CLEAR); - smbus_write8(ACPIMMIO_ASF_BASE, SMBHSTSTAT, SMBHST_STAT_CLEAR); - smbus_write8(ACPIMMIO_ASF_BASE, SMBSLVSTAT, SMBSLV_STAT_CLEAR); + smbus_write8(SMBHSTSTAT, SMBHST_STAT_CLEAR); + smbus_write8(SMBSLVSTAT, SMBSLV_STAT_CLEAR); + asf_write8(SMBHSTSTAT, SMBHST_STAT_CLEAR); + asf_write8(SMBSLVSTAT, SMBSLV_STAT_CLEAR); }
/* Before console init */
Richard Spiegel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32644 )
Patch Set 1: Code-Review+2
Are you planing to move generic portion of SMBUS to common folder?
Martin Roth has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32644 )
Martin Roth has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/32644 )
Change-Id: I3b0ecf21f20472245da98ab5e711a54e99dca93a Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/32644 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Richard Spiegel richard.spiegel@silverbackltd.com Reviewed-by: Martin Roth martinroth@google.com --- M src/soc/amd/stoneyridge/include/soc/southbridge.h M src/soc/amd/stoneyridge/sb_util.c M src/soc/amd/stoneyridge/smbus.c M src/soc/amd/stoneyridge/southbridge.c 4 files changed, 102 insertions(+), 34 deletions(-)
Approvals: build bot (Jenkins): Verified Martin Roth: Looks good to me, approved Richard Spiegel: Looks good to me, approved
