Attention is currently required from: Anil Kumar K, Jérémy Compostella.
Hello Jérémy Compostella, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/77110?usp=email
The following approvals got outdated and were removed: Verified-1 by build bot (Jenkins)
Change subject: soc/intel/cmn/cse: Add support for BUP_COMMON_LOAD_EDP_PHY command ......................................................................
To enable graphics in pre-memory stage, eDP PHY firmware has to be explicitly loaded early enough on certain SOCs.
This patch adds support for BUP_COMMON_LOAD_EDP_PHY HECI command to inform CSE to load EDP PHY firmware.
Change-Id: Ia18b895b2b4247266140670024cc0d27852efe42 Signed-off-by: Anil Kumar anil.kumar.k@intel.com --- M src/soc/intel/common/block/cse/Kconfig M src/soc/intel/common/block/cse/cse_lite.c M src/soc/intel/common/block/include/intelblocks/cse.h 3 files changed, 64 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/10/77110/7
