Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/51015 )
Change subject: util/spd_tools: Add Cezanne support to lp4x/gen_spd.go ......................................................................
To supply memory information for Guybrush, the lpddr4x script for generating SPDs needs to be updated for Cezanne.
BUG=b:178722935 TEST=Add the part used on Majolica to the global lpddr4x json file and verify that the output is similar to the actual SPD used for Majolica.
Signed-off-by: Martin Roth martin@coreboot.org Change-Id: I1f522cb4a92b4fe4c26cad0689437c33ec44befe Reviewed-on: https://review.coreboot.org/c/coreboot/+/51015 Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M util/spd_tools/lp4x/gen_spd.go 1 file changed, 13 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Tim Wawrzynczak: Looks good to me, approved
diff --git a/util/spd_tools/lp4x/gen_spd.go b/util/spd_tools/lp4x/gen_spd.go index 2575b5d..6f4f895 100644 --- a/util/spd_tools/lp4x/gen_spd.go +++ b/util/spd_tools/lp4x/gen_spd.go @@ -29,12 +29,14 @@
PlatformTGLADL = 0 PlatformJSL = 1 + PlatformCZN = 2 )
var platformMap = map[string]int { "TGL": PlatformTGLADL, "JSL": PlatformJSL, "ADL": PlatformTGLADL, + "CZN": PlatformCZN, }
var currPlatform int @@ -217,7 +219,7 @@ * SPDIndexDensityBanks. Logical channel on TGL is an x16 channel. */ return memAttribs.DensityPerChannelGb * TGLLogicalChannelWidth / memAttribs.BitWidthPerChannel - } else if currPlatform == PlatformJSL { + } else if currPlatform == PlatformJSL || currPlatform == PlatformCZN { /* * Intel MRC on JSL expects density per die to be encoded in * SPDIndexDensityBanks. @@ -269,13 +271,16 @@ return temp << 7 }
+/* Per JESD209-4C Dies = ZQ balls on the package */ +/* Note that this can be different than the part's die count */ func encodeDiesPerPackage(memAttribs *memAttributes) byte { var dies int = 0 if currPlatform == PlatformTGLADL { /* Intel MRC expects logical dies to be encoded for TGL. */ dies = memAttribs.ChannelsPerDie * memAttribs.RanksPerChannel * memAttribs.BitWidthPerChannel / 16 - } else if currPlatform == PlatformJSL { + } else if currPlatform == PlatformJSL || currPlatform == PlatformCZN { /* Intel MRC expects physical dies to be encoded for JSL. */ + /* AMD PSP expects physical dies (ZQ balls) */ dies = memAttribs.DiesPerPackage }
@@ -333,7 +338,7 @@ func encodeBusWidth(memAttribs *memAttributes) byte { if currPlatform == PlatformTGLADL { return SPDValueBusWidthTGL - } else if currPlatform == PlatformJSL { + } else if currPlatform == PlatformJSL || currPlatform == PlatformCZN { return SPDValueBusWidthJSL } return 0 @@ -941,7 +946,11 @@ fmt.Printf(" where,\n") fmt.Printf(" spd_dir = Directory path containing SPD files and manifest generated by gen_spd.go\n") fmt.Printf(" mem_parts_list_json = JSON File containing list of memory parts and attributes\n") - fmt.Printf(" platform = SoC Platform for which the SPDs are being generated\n\n\n") + fmt.Printf(" platform = SoC Platform for which the SPDs are being generated\n") + fmt.Printf(" supported platforms: ") + keys := reflect.ValueOf(platformMap).MapKeys() + fmt.Println(keys) + fmt.Printf("\n\n\n") }
func main() {
