Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/45224 )
Change subject: mb/ocp/deltalake: Drop redundant `select FSP_CAR` ......................................................................
This is selected by Xeon SP Kconfig already.
Change-Id: If1ef7f86b27d7be74912c9ad1f9c1efbda6233e5 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/ocp/deltalake/Kconfig 1 file changed, 0 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/45224/1
diff --git a/src/mainboard/ocp/deltalake/Kconfig b/src/mainboard/ocp/deltalake/Kconfig index b229c94..9e5eed8 100644 --- a/src/mainboard/ocp/deltalake/Kconfig +++ b/src/mainboard/ocp/deltalake/Kconfig @@ -3,7 +3,6 @@ config BOARD_SPECIFIC_OPTIONS def_bool y select BOARD_ROMSIZE_KB_65536 - select FSP_CAR select HAVE_ACPI_TABLES select MAINBOARD_USES_FSP2_0 select SOC_INTEL_COOPERLAKE_SP
Jonathan Zhang has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45224 )
Patch Set 1: Code-Review+2
Christian Walter has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45224 )
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/45224 )
Change-Id: If1ef7f86b27d7be74912c9ad1f9c1efbda6233e5 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/45224 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Jonathan Zhang jonzhang@fb.com Reviewed-by: Christian Walter christian.walter@9elements.com --- M src/mainboard/ocp/deltalake/Kconfig 1 file changed, 0 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Jonathan Zhang: Looks good to me, approved Christian Walter: Looks good to me, approved
diff --git a/src/mainboard/ocp/deltalake/Kconfig b/src/mainboard/ocp/deltalake/Kconfig index adce988..9d9b259 100644 --- a/src/mainboard/ocp/deltalake/Kconfig +++ b/src/mainboard/ocp/deltalake/Kconfig @@ -3,7 +3,6 @@ config BOARD_SPECIFIC_OPTIONS def_bool y select BOARD_ROMSIZE_KB_65536 - select FSP_CAR select HAVE_ACPI_TABLES select MAINBOARD_USES_FSP2_0 select SOC_INTEL_COOPERLAKE_SP
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45224 )
Patch Set 2:
Automatic boot test returned (PASS/FAIL/TOTAL): 8/1/9 "QEMU x86 q35/ich9" (x86_32) using payload TianoCore : SUCCESS : https://lava.9esec.io/r/19121 "QEMU x86 q35/ich9" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/19120 "QEMU x86 i440fx/piix4" (x86_64) using payload SeaBIOS : FAIL : https://lava.9esec.io/r/19119 "QEMU x86 i440fx/piix4" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/19118 "QEMU AArch64" using payload LinuxBoot_u-root_kexec : SUCCESS : https://lava.9esec.io/r/19117 "HP Z220 SFF Workstation" (x86_32) using payload LinuxBoot_BusyBox_kexec : SUCCESS : https://lava.9esec.io/r/19125 "HP Z220 SFF Workstation" (x86_32) using payload LinuxBoot_BusyBox_kexec : SUCCESS : https://lava.9esec.io/r/19124 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload TianoCore : SUCCESS : https://lava.9esec.io/r/19123 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/19122
