Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10601
commit f524b45fc3cd0e1135238bfb5bf6201746a96e15 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Fri Jun 19 16:42:58 2015 -0700
cpu/amd: Fix cbtypes.h to match UINTN convention
UINTN maps to uintptr_t in UEFI land. Do the same here. Also switch the other UEFI types to map to fixed size types.
Change-Id: Ib46893c7cd5368eae43e9cda30eed7398867ac5b Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org Signed-off-by: Scott Duplichan scott@notabs.org --- src/include/cpu/amd/common/cbtypes.h | 22 +++++++++++++--------- 1 file changed, 13 insertions(+), 9 deletions(-)
diff --git a/src/include/cpu/amd/common/cbtypes.h b/src/include/cpu/amd/common/cbtypes.h index 346f1a3..6a47e00 100644 --- a/src/include/cpu/amd/common/cbtypes.h +++ b/src/include/cpu/amd/common/cbtypes.h @@ -20,16 +20,20 @@ #ifndef _CBTYPES_H_ #define _CBTYPES_H_
-typedef signed long long __int64; +/* Map coreboot stdint types to AGESA types. */ + +#include <stdint.h> + +typedef int64_t __int64; typedef void VOID; -typedef unsigned int UINTN; -typedef signed char CHAR8; -typedef unsigned char UINT8; -typedef unsigned short UINT16; -typedef unsigned int UINT32; -typedef signed int INT32; -typedef unsigned long long UINT64; -typedef unsigned char BOOLEAN; +typedef uintptr_t UINTN; +typedef int8_t CHAR8; +typedef uint8_t UINT8; +typedef uint16_t UINT16; +typedef uint32_t UINT32; +typedef int32_t INT32; +typedef uint64_t UINT64; +typedef uint8_t BOOLEAN;
#define DMSG_SB_TRACE 0x02 #define TRACE(Arguments)
