Tristan Hsieh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/32465
Change subject: medaitek: Add function to raise the CPU frequency ......................................................................
Implement mt_pll_raise_ca53_freq() in MT8183 to raise the CPU frequency. Move the function declaration to common header.
BUG=b:80501386 BRANCH=none Test=Boots correctly on Kukui
Change-Id: Ide8d767486d68177fa2bfbcc5b559879eca1bcda Signed-off-by: Tristan Shieh tristan.shieh@mediatek.com --- M src/soc/mediatek/common/include/soc/pll_common.h M src/soc/mediatek/mt8173/include/soc/pll.h M src/soc/mediatek/mt8183/Makefile.inc M src/soc/mediatek/mt8183/pll.c 4 files changed, 6 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/32465/1
diff --git a/src/soc/mediatek/common/include/soc/pll_common.h b/src/soc/mediatek/common/include/soc/pll_common.h index 480371b..d0ffa86c 100644 --- a/src/soc/mediatek/common/include/soc/pll_common.h +++ b/src/soc/mediatek/common/include/soc/pll_common.h @@ -69,5 +69,6 @@ void mux_set_sel(const struct mux *mux, u32 sel); int pll_set_rate(const struct pll *pll, u32 rate); void mt_pll_init(void); +void mt_pll_raise_ca53_freq(u32 freq);
#endif diff --git a/src/soc/mediatek/mt8173/include/soc/pll.h b/src/soc/mediatek/mt8173/include/soc/pll.h index 4106d2a..480ffbf 100644 --- a/src/soc/mediatek/mt8173/include/soc/pll.h +++ b/src/soc/mediatek/mt8173/include/soc/pll.h @@ -292,7 +292,6 @@ void mt_pll_post_init(void); void mt_pll_set_aud_div(u32 rate); void mt_pll_enable_ssusb_clk(void); -void mt_pll_raise_ca53_freq(u32 freq); void mt_mem_pll_set_clk_cfg(void); void mt_mem_pll_config_pre(const struct mt8173_sdram_params *sdram_params); void mt_mem_pll_config_post(void); diff --git a/src/soc/mediatek/mt8183/Makefile.inc b/src/soc/mediatek/mt8183/Makefile.inc index 3fce0a8..5392a9e 100644 --- a/src/soc/mediatek/mt8183/Makefile.inc +++ b/src/soc/mediatek/mt8183/Makefile.inc @@ -32,6 +32,7 @@ romstage-y += mt8183.c romstage-y += ../common/gpio.c gpio.c romstage-y += ../common/mmu_operations.c mmu_operations.c +romstage-y += ../common/pll.c pll.c romstage-y += ../common/pmic_wrap.c pmic_wrap.c mt6358.c romstage-y += ../common/rtc.c rtc.c romstage-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c diff --git a/src/soc/mediatek/mt8183/pll.c b/src/soc/mediatek/mt8183/pll.c index 61aa2de..c32e6bc 100644 --- a/src/soc/mediatek/mt8183/pll.c +++ b/src/soc/mediatek/mt8183/pll.c @@ -357,3 +357,7 @@ /* enable [14] dramc_pll104m_ck */ setbits_le32(&mtk_topckgen->clk_misc_cfg_0, 1 << 14); } + +void mt_pll_raise_ca53_freq(u32 freq) { + pll_set_rate(&plls[APMIXED_ARMPLL_LL], freq); +}
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32465 )
Patch Set 1:
https://review.coreboot.org/#/c/32465/1/src/soc/mediatek/mt8183/pll.c File src/soc/mediatek/mt8183/pll.c:
https://review.coreboot.org/#/c/32465/1/src/soc/mediatek/mt8183/pll.c@361 PS1, Line 361: void mt_pll_raise_ca53_freq(u32 freq) { open brace '{' following function definitions go on the next line
Patch Set 1:
Hello Julius Werner, You-Cheng Syu, Hung-Te Lin, build bot (Jenkins), Weiyi Lu, Patrick Georgi, Martin Roth,
Change-Id: Ide8d767486d68177fa2bfbcc5b559879eca1bcda Signed-off-by: Tristan Shieh tristan.shieh@mediatek.com --- M src/soc/mediatek/common/include/soc/pll_common.h M src/soc/mediatek/mt8173/include/soc/pll.h M src/soc/mediatek/mt8173/pll.c M src/soc/mediatek/mt8183/Makefile.inc M src/soc/mediatek/mt8183/pll.c 5 files changed, 9 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/32465/2
Hung-Te Lin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32465 )
Patch Set 2: Code-Review+1
Julius Werner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32465 )
Patch Set 2: Code-Review+2
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32465 )
Patch Set 2:
https://review.coreboot.org/#/c/32465/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/#/c/32465/2//COMMIT_MSG@7 PS2, Line 7: medaitek nit: mediatek
Change subject: mediatek: Add function to raise the CPU frequency ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/32465/3
Tristan Hsieh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32465 )
Patch Set 3:
(3 comments)
nit: mediatek
Done
Done
Done
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/32465 )
Change-Id: Ide8d767486d68177fa2bfbcc5b559879eca1bcda Signed-off-by: Tristan Shieh tristan.shieh@mediatek.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/32465 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Hung-Te Lin hungte@chromium.org Reviewed-by: Julius Werner jwerner@chromium.org --- M src/soc/mediatek/common/include/soc/pll_common.h M src/soc/mediatek/mt8173/include/soc/pll.h M src/soc/mediatek/mt8173/pll.c M src/soc/mediatek/mt8183/Makefile.inc M src/soc/mediatek/mt8183/pll.c 5 files changed, 9 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Julius Werner: Looks good to me, approved Hung-Te Lin: Looks good to me, but someone else must approve
#endif diff --git a/src/soc/mediatek/mt8173/include/soc/pll.h b/src/soc/mediatek/mt8173/include/soc/pll.h index 4106d2a..480ffbf 100644 --- a/src/soc/mediatek/mt8173/include/soc/pll.h +++ b/src/soc/mediatek/mt8173/include/soc/pll.h @@ -292,7 +292,6 @@ void mt_pll_post_init(void); void mt_pll_set_aud_div(u32 rate); void mt_pll_enable_ssusb_clk(void); -void mt_pll_raise_ca53_freq(u32 freq); void mt_mem_pll_set_clk_cfg(void); void mt_mem_pll_config_pre(const struct mt8173_sdram_params *sdram_params); void mt_mem_pll_config_post(void); diff --git a/src/soc/mediatek/mt8173/pll.c b/src/soc/mediatek/mt8173/pll.c index c59fa3f..7eb12b1 100644 --- a/src/soc/mediatek/mt8173/pll.c +++ b/src/soc/mediatek/mt8173/pll.c @@ -432,7 +432,8 @@ } }
-void mt_pll_raise_ca53_freq(u32 freq) { +void mt_pll_raise_ca53_freq(u32 freq) +{ pll_set_rate(&plls[APMIXED_ARMCA7PLL], freq); /* freq in Hz */ }
diff --git a/src/soc/mediatek/mt8183/Makefile.inc b/src/soc/mediatek/mt8183/Makefile.inc index 3fce0a8..5392a9e 100644 --- a/src/soc/mediatek/mt8183/Makefile.inc +++ b/src/soc/mediatek/mt8183/Makefile.inc @@ -32,6 +32,7 @@ romstage-y += mt8183.c romstage-y += ../common/gpio.c gpio.c romstage-y += ../common/mmu_operations.c mmu_operations.c +romstage-y += ../common/pll.c pll.c romstage-y += ../common/pmic_wrap.c pmic_wrap.c mt6358.c romstage-y += ../common/rtc.c rtc.c romstage-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c diff --git a/src/soc/mediatek/mt8183/pll.c b/src/soc/mediatek/mt8183/pll.c index 8608b4a..07ce660 100644 --- a/src/soc/mediatek/mt8183/pll.c +++ b/src/soc/mediatek/mt8183/pll.c @@ -369,3 +369,8 @@ /* enable mtkaif 26m clock */ setbits_le32(&mt8183_infracfg->module_sw_cg_2_clr, 1 << 4); } + +void mt_pll_raise_ca53_freq(u32 freq) +{ + pll_set_rate(&plls[APMIXED_ARMPLL_LL], freq); +}
