Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39012 )
Change subject: soc/amd/stoneyridge: Remove TODO for file extensions ......................................................................
The comment is no longer relevant. Perhaps the intention had been to modify the names of the files delivered from AMD in order to simplify Makefile.inc.
AMD firmware is distributed via the new amd_blobs repo and the filenames match the blobs as they are released. Multiple Family 15h devices are supported by this directory and their SMU Firmwares do not all follow identical naming convention.
Keep the existing functionality and reword the comment.
BUG=b:120118850
Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Change-Id: Ifbf8e2286f34bc37a6178c37f8c412ec51ee02c9 --- M src/soc/amd/stoneyridge/Makefile.inc 1 file changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/12/39012/1
diff --git a/src/soc/amd/stoneyridge/Makefile.inc b/src/soc/amd/stoneyridge/Makefile.inc index eb8af2d..0cc49c8 100644 --- a/src/soc/amd/stoneyridge/Makefile.inc +++ b/src/soc/amd/stoneyridge/Makefile.inc @@ -155,8 +155,8 @@ ###4 PSPNVRAM_FILE=$(top)/$(FIRMWARE_LOCATE)/PspNvram$(FIRMWARE_TYPE).bin
-###8 - Check for SMU firmware named either *.sbin or *.csbin -### TODO: Remove *.sbin section after the blobs repo is updated. +###8 - Check for SMU firmware named either *.sbin or *.csbin. Both "signed" and +### "compressed signed" are used by generations supported by this file. SMUFWM_FILE=$(top)/$(FIRMWARE_LOCATE)/SmuFirmware_$(FIRMWARE_TYPE).csbin SMUFWM_FN_FILE=$(top)/$(FIRMWARE_LOCATE)/SmuFirmware_$(FIRMWARE_TYPE)_FN.csbin ifeq ("$(wildcard $(SMUFWM_FILE))","")
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39012 )
Patch Set 1: Code-Review+2
Marshall Dawson has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39012 )
BUG=b:120118850
Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Change-Id: Ifbf8e2286f34bc37a6178c37f8c412ec51ee02c9 Reviewed-on: https://review.coreboot.org/c/coreboot/+/39012 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Georgi pgeorgi@google.com --- M src/soc/amd/stoneyridge/Makefile.inc 1 file changed, 2 insertions(+), 2 deletions(-)
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39012 )
Patch Set 2:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/718 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/717 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/716
