Youness Alaoui has uploaded a new change for review. ( https://review.coreboot.org/19935 )
Change subject: purism/librem13v2: Add memory init code ......................................................................
Adding code to setup the spd information from sodimm. Adapted from intel/kblrvp.
Change-Id: I0403f999dac1bdef0e9e1abe7c9c62407e223bb1 Signed-off-by: Youness Alaoui youness.alaoui@puri.sm --- M src/mainboard/purism/librem13v2/Kconfig M src/mainboard/purism/librem13v2/romstage.c 2 files changed, 40 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/35/19935/1
diff --git a/src/mainboard/purism/librem13v2/Kconfig b/src/mainboard/purism/librem13v2/Kconfig index f3cbffc..dd152ad 100644 --- a/src/mainboard/purism/librem13v2/Kconfig +++ b/src/mainboard/purism/librem13v2/Kconfig @@ -47,4 +47,13 @@ string default "8086,1916"
+config DIMM_MAX + int + default 1 + +config DIMM_SPD_SIZE + int + default 512 + + endif diff --git a/src/mainboard/purism/librem13v2/romstage.c b/src/mainboard/purism/librem13v2/romstage.c index da1c4c3..f713dec 100644 --- a/src/mainboard/purism/librem13v2/romstage.c +++ b/src/mainboard/purism/librem13v2/romstage.c @@ -20,6 +20,7 @@ #include <soc/pei_data.h> #include <soc/pei_wrapper.h> #include <soc/romstage.h> +#include <spd_bin.h>
void mainboard_romstage_entry(struct romstage_params *params) { @@ -28,3 +29,33 @@ /* Initliaze memory */ romstage_common(params); } + +void mainboard_memory_init_params(struct romstage_params *params, + MEMORY_INIT_UPD *memory_params) +{ + struct spd_block blk; + + memory_params->DqPinsInterleaved = 1; + get_spd_smbus(&blk); + dump_spd_info(&blk); + memory_params->MemorySpdDataLen = blk.len; + if (blk.spd_array[0][0] != 0) + memory_params->MemorySpdPtr00 = (u32)blk.spd_array[0]; + memory_params->MemorySpdPtr01 = 0; + memory_params->MemorySpdPtr10 = 0; + memory_params->MemorySpdPtr11 = 0; + + memcpy(memory_params->DqByteMapCh0, params->pei_data->dq_map[0], + sizeof(params->pei_data->dq_map[0])); + memcpy(memory_params->DqByteMapCh1, params->pei_data->dq_map[1], + sizeof(params->pei_data->dq_map[1])); + memcpy(memory_params->DqsMapCpu2DramCh0, params->pei_data->dqs_map[0], + sizeof(params->pei_data->dqs_map[0])); + memcpy(memory_params->DqsMapCpu2DramCh1, params->pei_data->dqs_map[1], + sizeof(params->pei_data->dqs_map[1])); + memcpy(memory_params->RcompResistor, params->pei_data->RcompResistor, + sizeof(params->pei_data->RcompResistor)); + memcpy(memory_params->RcompTarget, params->pei_data->RcompTarget, + sizeof(params->pei_data->RcompTarget)); + +}
