Attention is currently required from: Fred Reitberger, Jason Glenesk, Matt DeVillier, Raul Rangel.
Hello Fred Reitberger, Jason Glenesk, Matt DeVillier, Raul Rangel, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/74992?usp=email
Change subject: soc/amd/common/data_fabric/domain: write _BBN method in SSDT ......................................................................
Instead of having PCI0's _BBN method in the DSDT that always returns 0, use acpigen_write_BBN to generate the _BBN method that returns the first PCI bus number in the PCI domain/host bridge.
TEST=On mandolin the _BBN method in the _SB/PCI0 scope is now in the SSDT instead of the DSDT, but still returns 0.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I8badeb0064b498d3f18217ea24bff73676913b02 --- M src/soc/amd/common/block/data_fabric/domain.c M src/soc/amd/picasso/acpi/northbridge.asl 2 files changed, 3 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/74992/8
