Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80567?usp=email )
Change subject: soc/intel/mtl: Skip RW CBFS ucode update if RO is locked ......................................................................
This patch optimizes boot time by avoiding redundant microcode updates from RW CBFS when the RO descriptor is locked, indicating a fixed RO image.
1. The FIT loads the necessary microcode from the RO during reset. 2. Reloading microcode from RW CBFS impacts boot time (~60ms, core-dependent). 3. The kernel can still load microcode updates without affecting AP FW boot time.
ChromeOS devices leverage RO+RW-A/RW-B booting. The RO's microcode is sufficient for initial boot, and the kernel can apply updates later.
BUG=none TEST=Verified boot optimization; in-field devices skip RW-CBFS microcode loading when RO is locked.
Change-Id: Ia859809970406fca3fa14e6fa8e766ab16d94c8a Signed-off-by: Subrata Banik subratabanik@google.com --- M src/soc/intel/meteorlake/cpu.c 1 file changed, 22 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/67/80567/1
diff --git a/src/soc/intel/meteorlake/cpu.c b/src/soc/intel/meteorlake/cpu.c index 54217ea5..e990ae3 100644 --- a/src/soc/intel/meteorlake/cpu.c +++ b/src/soc/intel/meteorlake/cpu.c @@ -4,6 +4,7 @@ #include <console/console.h> #include <cpu/cpu.h> #include <cpu/intel/common/common.h> +#include <cpu/intel/microcode.h> #include <cpu/intel/smm_reloc.h> #include <cpu/intel/turbo.h> #include <cpu/x86/lapic.h> @@ -214,3 +215,24 @@ /* Thermal throttle activation offset */ configure_tcc_thermal_target(); } + +int soc_skip_ucode_update(u32 current_patch_id, u32 new_patch_id) +{ + if (!CONFIG(CHROMEOS)) + return 0; + /* + * Locked RO Descriptor Implications: + * + * - A locked descriptor signals the RO binary is fixed; the FIT will load the + * RO's microcode during system reset. + * - Attempts to load newer microcode from the RW CBFS will cause a boot-time + * delay (~60ms, core-dependent), as the microcode must be reloaded on BSP+APs. + * - The kernel can load microcode updates without impacting AP FW boot time. + * - Skipping RW CBFS microcode loading is low-risk when the RO is locked, + * prioritizing fast boot times. + */ + if (CONFIG(LOCK_MANAGEMENT_ENGINE) && current_patch_id) + return 1; + + return 0; +}
