Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43373 )
Change subject: sb/intel/bd82x6x: Move `acpi_fill_fadt` to fadt.c ......................................................................
Other Intel southbridges do this.
Change-Id: I6ae78696b0fa2d91dd2c6de0a3ef28e08d85e93b Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/southbridge/intel/bd82x6x/Makefile.inc A src/southbridge/intel/bd82x6x/fadt.c M src/southbridge/intel/bd82x6x/lpc.c 3 files changed, 137 insertions(+), 129 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/73/43373/1
diff --git a/src/southbridge/intel/bd82x6x/Makefile.inc b/src/southbridge/intel/bd82x6x/Makefile.inc index 9e34e96..1e80cf9 100644 --- a/src/southbridge/intel/bd82x6x/Makefile.inc +++ b/src/southbridge/intel/bd82x6x/Makefile.inc @@ -7,6 +7,7 @@
ramstage-y += pch.c ramstage-y += azalia.c +ramstage-y += fadt.c ramstage-y += lpc.c ramstage-y += pci.c ramstage-y += pcie.c diff --git a/src/southbridge/intel/bd82x6x/fadt.c b/src/southbridge/intel/bd82x6x/fadt.c new file mode 100644 index 0000000..5d76702 --- /dev/null +++ b/src/southbridge/intel/bd82x6x/fadt.c @@ -0,0 +1,136 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/pci_ops.h> +#include <acpi/acpi.h> +#include <cpu/x86/smm.h> +#include <southbridge/intel/common/pmutil.h> +#include "chip.h" + +void acpi_fill_fadt(acpi_fadt_t *fadt) +{ + struct device *dev = pcidev_on_root(0x1f, 0); + struct southbridge_intel_bd82x6x_config *chip = dev->chip_info; + u16 pmbase = pci_read_config16(dev, 0x40) & 0xfffe; + int c2_latency; + + + fadt->sci_int = 0x9; + + if (permanent_smi_handler()) { + fadt->smi_cmd = APM_CNT; + fadt->acpi_enable = APM_CNT_ACPI_ENABLE; + fadt->acpi_disable = APM_CNT_ACPI_DISABLE; + } + + fadt->pm1a_evt_blk = pmbase; + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + 0x4; + fadt->pm1b_cnt_blk = 0x0; + fadt->pm2_cnt_blk = pmbase + 0x50; + fadt->pm_tmr_blk = pmbase + 0x8; + fadt->gpe0_blk = pmbase + 0x20; + fadt->gpe1_blk = 0; + + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + fadt->pm2_cnt_len = 1; + fadt->pm_tmr_len = 4; + fadt->gpe0_blk_len = 16; + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + c2_latency = chip->c2_latency; + if (!c2_latency) { + c2_latency = 101; /* c2 unsupported */ + } + fadt->p_lvl2_lat = c2_latency; + fadt->p_lvl3_lat = 87; + /* flush_* is ignored if ACPI_FADT_WBINVD is set */ + fadt->flush_size = 0; + fadt->flush_stride = 0; + /* P_CNT not supported */ + fadt->duty_offset = 0; + fadt->duty_width = 0; + fadt->day_alrm = 0xd; + fadt->mon_alrm = 0x00; + fadt->century = 0x00; + fadt->iapc_boot_arch = ACPI_FADT_LEGACY_DEVICES | ACPI_FADT_8042; + + fadt->flags = ACPI_FADT_WBINVD | + ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_SLEEP_BUTTON | + ACPI_FADT_RESET_REGISTER | + ACPI_FADT_SEALED_CASE | + ACPI_FADT_S4_RTC_WAKE | + ACPI_FADT_PLATFORM_CLOCK; + if (chip->docking_supported) { + fadt->flags |= ACPI_FADT_DOCKING_SUPPORTED; + } + if (c2_latency < 100) { + fadt->flags |= ACPI_FADT_C2_MP_SUPPORTED; + } + + fadt->reset_reg.space_id = 1; + fadt->reset_reg.bit_width = 8; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->reset_reg.addrl = 0xcf9; + fadt->reset_reg.addrh = 0; + + fadt->reset_value = 6; + + fadt->x_pm1a_evt_blk.space_id = 1; + fadt->x_pm1a_evt_blk.bit_width = 32; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm1a_evt_blk.addrl = pmbase; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = 1; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.access_size = 0; + fadt->x_pm1b_evt_blk.addrl = 0x0; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + fadt->x_pm1a_cnt_blk.space_id = 1; + fadt->x_pm1a_cnt_blk.bit_width = 16; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; + fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = 1; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.access_size = 0; + fadt->x_pm1b_cnt_blk.addrl = 0x0; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + fadt->x_pm2_cnt_blk.space_id = 1; + fadt->x_pm2_cnt_blk.bit_width = 8; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->x_pm2_cnt_blk.addrl = pmbase + 0x50; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + fadt->x_pm_tmr_blk.space_id = 1; + fadt->x_pm_tmr_blk.bit_width = 32; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; + fadt->x_pm_tmr_blk.addrh = 0x0; + + fadt->x_gpe0_blk.space_id = 1; + fadt->x_gpe0_blk.bit_width = 128; + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->x_gpe0_blk.addrl = pmbase + 0x20; + fadt->x_gpe0_blk.addrh = 0x0; + + fadt->x_gpe1_blk.space_id = 1; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.access_size = 0; + fadt->x_gpe1_blk.addrl = 0x0; + fadt->x_gpe1_blk.addrh = 0x0; +} diff --git a/src/southbridge/intel/bd82x6x/lpc.c b/src/southbridge/intel/bd82x6x/lpc.c index 80d3a46..2efddd8 100644 --- a/src/southbridge/intel/bd82x6x/lpc.c +++ b/src/southbridge/intel/bd82x6x/lpc.c @@ -675,135 +675,6 @@ } }
-void acpi_fill_fadt(acpi_fadt_t *fadt) -{ - struct device *dev = pcidev_on_root(0x1f, 0); - config_t *chip = dev->chip_info; - u16 pmbase = pci_read_config16(dev, 0x40) & 0xfffe; - int c2_latency; - - - fadt->sci_int = 0x9; - - if (permanent_smi_handler()) { - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - } - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x50; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x20; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 16; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - c2_latency = chip->c2_latency; - if (!c2_latency) { - c2_latency = 101; /* c2 unsupported */ - } - fadt->p_lvl2_lat = c2_latency; - fadt->p_lvl3_lat = 87; - /* flush_* is ignored if ACPI_FADT_WBINVD is set */ - fadt->flush_size = 0; - fadt->flush_stride = 0; - /* P_CNT not supported */ - fadt->duty_offset = 0; - fadt->duty_width = 0; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x00; - fadt->iapc_boot_arch = ACPI_FADT_LEGACY_DEVICES | ACPI_FADT_8042; - - fadt->flags = ACPI_FADT_WBINVD | - ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | - ACPI_FADT_RESET_REGISTER | - ACPI_FADT_SEALED_CASE | - ACPI_FADT_S4_RTC_WAKE | - ACPI_FADT_PLATFORM_CLOCK; - if (chip->docking_supported) { - fadt->flags |= ACPI_FADT_DOCKING_SUPPORTED; - } - if (c2_latency < 100) { - fadt->flags |= ACPI_FADT_C2_MP_SUPPORTED; - } - - fadt->reset_reg.space_id = 1; - fadt->reset_reg.bit_width = 8; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->reset_reg.addrl = 0xcf9; - fadt->reset_reg.addrh = 0; - - fadt->reset_value = 6; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 1; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.access_size = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 1; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.access_size = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x50; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 128; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->x_gpe0_blk.addrl = pmbase + 0x20; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 1; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.access_size = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; -} - static const char *lpc_acpi_name(const struct device *dev) { return "LPCB";
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43373 )
Patch Set 1:
(3 comments)
https://review.coreboot.org/c/coreboot/+/43373/1/src/southbridge/intel/bd82x... File src/southbridge/intel/bd82x6x/fadt.c:
https://review.coreboot.org/c/coreboot/+/43373/1/src/southbridge/intel/bd82x... PS1, Line 42: if (!c2_latency) { braces {} are not necessary for single statement blocks
https://review.coreboot.org/c/coreboot/+/43373/1/src/southbridge/intel/bd82x... PS1, Line 65: if (chip->docking_supported) { braces {} are not necessary for single statement blocks
https://review.coreboot.org/c/coreboot/+/43373/1/src/southbridge/intel/bd82x... PS1, Line 68: if (c2_latency < 100) { braces {} are not necessary for single statement blocks
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43373 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/43373/1/src/southbridge/intel/bd82x... PS1, Line 72: 1 use macro
https://review.coreboot.org/c/coreboot/+/43373/1/src/southbridge/intel/bd82x... PS1, Line 105: 0 use macro
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43373 )
Patch Set 1:
(2 comments)
use macro
Refer to the explanations I provided on CB:43372
use macro
Maxim Polyakov has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43373 )
Patch Set 1: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43373 )
Change-Id: I6ae78696b0fa2d91dd2c6de0a3ef28e08d85e93b Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43373 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Maxim Polyakov max.senia.poliak@gmail.com --- M src/southbridge/intel/bd82x6x/Makefile.inc A src/southbridge/intel/bd82x6x/fadt.c M src/southbridge/intel/bd82x6x/lpc.c 3 files changed, 137 insertions(+), 129 deletions(-)
Approvals: build bot (Jenkins): Verified Maxim Polyakov: Looks good to me, approved
