Attention is currently required from: Arthur Heymans, Julius Werner, Kapil Porwal.
Hello build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81968?usp=email
to look at the new patch set (#75).
Change subject: libpayload: Add x86_64 (64-bit) support ......................................................................
This patch introduces x86_64 (64-bit) support to the payload, building upon the existing x86 (32-bit) architecture. Files necessary for 64-bit compilation are now guarded by the `CONFIG_LP_ARCH_X86_64` Kconfig option.
BUG=b:242829490 TEST=Able to verify all valid combinations between coreboot and payload with this patch.
Payload Entry Point Behavior with below code.
+----------------+--------------------+----------------------------+ | LP_ARCH_X86_64 | Payload Entry Mode | Description | +----------------+--------------------+----------------------------+ | No | 32-bit | Direct protected mode init | +----------------+--------------------+----------------------------+ | Yes | 32-bit | Protected to long mode | +----------------+--------------------+----------------------------+ | Yes | 64-bit | Long mode initialization | +----------------+--------------------+----------------------------+
Change-Id: I69fda47bedf1a14807b1515c4aed6e3a1d5b8585 Signed-off-by: Subrata Banik subratabanik@google.com --- M payloads/libpayload/Kconfig M payloads/libpayload/Makefile M payloads/libpayload/Makefile.mk M payloads/libpayload/arch/x86/Makefile.mk M payloads/libpayload/arch/x86/exception.c A payloads/libpayload/arch/x86/exception_asm_64.S R payloads/libpayload/arch/x86/exec.c M payloads/libpayload/arch/x86/gdb.c A payloads/libpayload/arch/x86/head_64.S M payloads/libpayload/arch/x86/libpayload.ldscript A payloads/libpayload/arch/x86/pt.S M payloads/libpayload/arch/x86/string.c M payloads/libpayload/bin/lpgcc M payloads/libpayload/drivers/storage/ahci_common.c M payloads/libpayload/drivers/usb/uhci.c M payloads/libpayload/include/x86/arch/exception.h M payloads/libpayload/libc/Makefile.mk M payloads/libpayload/vboot/Makefile.mk 18 files changed, 687 insertions(+), 58 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/81968/75
