Attention is currently required from: Bill XIE, Felix Held, Fred Reitberger, Jason Glenesk, Julius Werner, Kyösti Mälkki, Matt DeVillier, Nico Huber, Patrick Georgi, Paul Menzel, Subrata Banik, Werner Zeh.
Hello Felix Held, Fred Reitberger, Jason Glenesk, Julius Werner, Kyösti Mälkki, Matt DeVillier, Nico Huber, Patrick Georgi, Paul Menzel, Subrata Banik, Werner Zeh, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/78623?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Nico Huber, Code-Review+2 by Subrata Banik, Verified+1 by build bot (Jenkins)
Change subject: Kconfig: Decrease default HEAP_SIZE from 1 MiB to 512 KiB ......................................................................
Commit 44a48ce7a46c ("Kconfig: Bring HEAP_SIZE to a common, large value") breaks S3 resume from TSEG stage cache on many platforms, including GM45 and Ivy Bridge, so limit it to 512 KiB.
HEAP_SIZE overrides greater than 0x80000 prior to the commit above are restored.
Please test this against other platforms before merging!
Tested: Setting it to 0x80000 results a working S3 resume on Thinkpad X200 and T430, with log in cbmem for S3 resume, while 0xa0000 breaks it. coreboot log during failed resume when (HEAP_SIZE >= 0xa0000) cannot be obtained from EHCI debug, while log in cbmem shows that ramstage is failed to be found in TSEG stage cache, as shown in https://ticket.coreboot.org/issues/512 .
Resolves: https://ticket.coreboot.org/issues/512 Signed-off-by: Bill XIE persmule@hardenedlinux.org Change-Id: Ib1de1eb8487df5bdf004e544d40667833a291515 --- M src/Kconfig M src/northbridge/amd/pi/Kconfig M src/soc/amd/picasso/Kconfig M src/soc/amd/stoneyridge/Kconfig 4 files changed, 14 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/23/78623/11
