Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13876
commit 0b658c58801957b12ef8f2008906293269d2d45b Author: Martin Roth martinroth@google.com Date: Wed Mar 2 12:16:13 2016 -0700
kconfig_lint: make sure if and endif statements are balanced
In Kconfig files, the 'if' and 'endif' statements need to match up. A file can't start an if statement that's completed in the next file.
Add a check as the files are being parsed to make sure that they match up correctly.
Change-Id: If51207ea037089ab84c768e5a868270468cf4c4f Signed-off-by: Martin Roth martinroth@google.com --- util/lint/kconfig_lint | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/util/lint/kconfig_lint b/util/lint/kconfig_lint index 38fa968..c955343 100755 --- a/util/lint/kconfig_lint +++ b/util/lint/kconfig_lint @@ -447,6 +447,7 @@ sub build_and_parse_kconfig_tree { my @inside_menu = (); # stack of menu names my $inside_choice = ""; my $configs_inside_choice; + my %fileinfo;
#start the tree off by loading the top level kconfig @config_to_parse = load_kconfig_file( $top_level_kconfig, "", 0, 0, "", 0 ); @@ -601,12 +602,14 @@ sub build_and_parse_kconfig_tree { my $expr = $1; push( @inside_if, $expr ); handle_expressions( $expr, $inside_config, $filename, $line_no ); + $fileinfo{$filename}{iflevel}++; }
# endif elsif ( $line =~ /^\s*endif/ ) { $inside_config = ""; pop(@inside_if); + $fileinfo{$filename}{iflevel}--; }
#range <symbol> <symbol> [if <expr>] @@ -665,6 +668,16 @@ sub build_and_parse_kconfig_tree { } push @wholeconfig, @parseline; } + + foreach my $file ( keys %fileinfo ) { + if ( $fileinfo{$file}{iflevel} > 0 ) { + show_error("$file has $fileinfo{$file}{iflevel} more 'if' statement(s) than 'endif' statements."); + } + elsif ( $fileinfo{$file}{iflevel} < 0 ) { + show_error( + "$file has " . ( $fileinfo{$file}{iflevel} * -1 ) . " more 'endif' statement(s) than 'if' statements." ); + } + } }
