Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/47710 )
Change subject: cpu/x86/sipi_vector: Use spinlock ......................................................................
Change-Id: I3ea5ea370dc75af3544ec903bd9b18399113dec1 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/cpu/x86/sipi_vector_c_handler.c 1 file changed, 6 insertions(+), 11 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/10/47710/1
diff --git a/src/cpu/x86/sipi_vector_c_handler.c b/src/cpu/x86/sipi_vector_c_handler.c index fa11748..47cd11a 100644 --- a/src/cpu/x86/sipi_vector_c_handler.c +++ b/src/cpu/x86/sipi_vector_c_handler.c @@ -6,11 +6,14 @@ #include <arch/cpu.h> #include <cpu/intel/microcode.h> #include <cpu/amd/mtrr.h> +#include <smp/spinlock.h>
asmlinkage void sipi_secondary_early_entry(struct sipi_params *const params, int cpu_num);
#define CR0_CLEAR_FLAGS_CACHE_ENABLE (CR0_CD | CR0_NW)
+DECLARE_SPIN_LOCK(microcode_lock) + static void sipi_update_microcode(struct sipi_params *params) { /* Determine if one should check microcode versions. */ @@ -25,23 +28,15 @@ return;
/* Determine if parallel microcode loading is allowed. */ - if (params->microcode_lock != 0xffffffff) { - - /* Protect microcode loading. */ - asm volatile( - "\tlock_microcode:\n" - "\tlock bts $0, %0\n" - "\tjc lock_microcode\n" - : "=m"(params->microcode_lock) - : "m"(params->microcode_lock)); - } + if (params->microcode_lock != 0xffffffff) + spin_lock(µcode_lock);
/* Load new microcode. */ intel_microcode_load_unlocked((void *)((uintptr_t)params->microcode_ptr));
/* Unconditionally unlock microcode loading. */ if (params->microcode_lock != 0xffffffff) - params->microcode_lock = 0; + spin_unlock(µcode_lock); }
static void sipi_set_mtrrs(const struct sipi_params *const params)
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47710 )
Patch Set 1: Code-Review+1
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47710 )
Patrick Rudolph has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/47710 )
Abandoned
patch series replaced by CB:49303
