Martin L Roth has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/71593 )
Change subject: src: Add and use POST_BOOTBLOCK_C_ENTRY ......................................................................
Add a notification for entering the bootblock C code. This was already present on one platform, but this patch defines that and uses it in all of the bootblock_c_entry() functions.
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: I45a86ece016e098ca42a31207fdedda5c49708d7 --- M src/commonlib/include/commonlib/console/post_codes.h M src/cpu/intel/car/bootblock.c M src/cpu/qemu-x86/bootblock.c M src/drivers/amd/agesa/bootblock.c M src/soc/amd/common/block/cpu/noncar/bootblock.c M src/soc/amd/stoneyridge/bootblock.c M src/soc/intel/alderlake/bootblock/bootblock.c M src/soc/intel/apollolake/bootblock/bootblock.c M src/soc/intel/braswell/bootblock/bootblock.c M src/soc/intel/cannonlake/bootblock/bootblock.c M src/soc/intel/denverton_ns/bootblock/bootblock.c M src/soc/intel/elkhartlake/bootblock/bootblock.c M src/soc/intel/icelake/bootblock/bootblock.c M src/soc/intel/jasperlake/bootblock/bootblock.c M src/soc/intel/meteorlake/bootblock/bootblock.c M src/soc/intel/quark/bootblock/bootblock.c M src/soc/intel/skylake/bootblock/bootblock.c M src/soc/intel/xeon_sp/bootblock.c 18 files changed, 70 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/93/71593/1
diff --git a/src/commonlib/include/commonlib/console/post_codes.h b/src/commonlib/include/commonlib/console/post_codes.h index d838815..7fbc60a 100644 --- a/src/commonlib/include/commonlib/console/post_codes.h +++ b/src/commonlib/include/commonlib/console/post_codes.h @@ -35,6 +35,13 @@ */ #define POST_RESET_VECTOR_CORRECT 0x01
+ +/** + * \brief Entry into bootblock_c_entry_bist or bootblock_c_entry + * + */ +#define POST_BOOTBLOCK_C_ENTRY 0x05 + /** * \brief Entry into protected mode * diff --git a/src/cpu/intel/car/bootblock.c b/src/cpu/intel/car/bootblock.c index c53379b..49fb86d 100644 --- a/src/cpu/intel/car/bootblock.c +++ b/src/cpu/intel/car/bootblock.c @@ -2,6 +2,7 @@
#include <arch/bootblock.h> #include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <cpu/x86/bist.h> #include <stdint.h>
@@ -9,6 +10,8 @@
asmlinkage void bootblock_c_entry_bist(uint64_t base_timestamp, uint32_t bist) { + post_code(POST_BOOTBLOCK_C_ENTRY); + saved_bist = bist; /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); diff --git a/src/cpu/qemu-x86/bootblock.c b/src/cpu/qemu-x86/bootblock.c index 1b46403e..514622f 100644 --- a/src/cpu/qemu-x86/bootblock.c +++ b/src/cpu/qemu-x86/bootblock.c @@ -1,12 +1,13 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <console/console.h> #include <cpu/x86/bist.h>
asmlinkage void bootblock_c_entry_bist(uint64_t base_timestamp, uint32_t bist) { - post_code(0x05); + post_code(POST_BOOTBLOCK_C_ENTRY);
/* Halt if there was a built in self test failure */ if (bist) { diff --git a/src/drivers/amd/agesa/bootblock.c b/src/drivers/amd/agesa/bootblock.c index df9876a..e287793 100644 --- a/src/drivers/amd/agesa/bootblock.c +++ b/src/drivers/amd/agesa/bootblock.c @@ -5,6 +5,7 @@ #include <amdblocks/amd_pci_mmconf.h> #include <amdblocks/biosram.h> #include <arch/bootblock.h> +#include <commonlib/console/post_codes.h> #include <cpu/amd/msr.h> #include <cpu/x86/mtrr.h> #include <cpu/x86/lapic.h> @@ -25,6 +26,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + enable_pci_mmconf(); set_early_mtrrs();
diff --git a/src/soc/amd/common/block/cpu/noncar/bootblock.c b/src/soc/amd/common/block/cpu/noncar/bootblock.c index 13bac18..d4a484e 100644 --- a/src/soc/amd/common/block/cpu/noncar/bootblock.c +++ b/src/soc/amd/common/block/cpu/noncar/bootblock.c @@ -3,6 +3,7 @@ #include <amdblocks/amd_pci_mmconf.h> #include <amdblocks/cpu.h> #include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <console/console.h> #include <cpu/cpu.h> #include <cpu/x86/tsc.h> @@ -12,6 +13,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + early_cache_setup(); write_resume_eip(); enable_pci_mmconf(); diff --git a/src/soc/amd/stoneyridge/bootblock.c b/src/soc/amd/stoneyridge/bootblock.c index f5451f85..f8a8dc2 100644 --- a/src/soc/amd/stoneyridge/bootblock.c +++ b/src/soc/amd/stoneyridge/bootblock.c @@ -14,6 +14,7 @@ #include <amdblocks/biosram.h> #include <amdblocks/iomap.h> #include <amdblocks/post_codes.h> +#include <commonlib/console/post_codes.h> #include <soc/pci_devs.h> #include <soc/cpu.h> #include <soc/southbridge.h> @@ -58,6 +59,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + enable_pci_mmconf(); amd_initmmio(); /* diff --git a/src/soc/intel/alderlake/bootblock/bootblock.c b/src/soc/intel/alderlake/bootblock/bootblock.c index b8086a4..44a95d7 100644 --- a/src/soc/intel/alderlake/bootblock/bootblock.c +++ b/src/soc/intel/alderlake/bootblock/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <intelblocks/fast_spi.h> #include <intelblocks/systemagent.h> #include <intelblocks/tco.h> @@ -9,6 +10,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/apollolake/bootblock/bootblock.c b/src/soc/intel/apollolake/bootblock/bootblock.c index c9b6d93..3630ed8 100644 --- a/src/soc/intel/apollolake/bootblock/bootblock.c +++ b/src/soc/intel/apollolake/bootblock/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <cpu/x86/pae.h> #include <device/pci.h> #include <device/pci_ops.h> @@ -40,6 +41,7 @@ asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { pci_devfn_t dev; + post_code(POST_BOOTBLOCK_C_ENTRY);
bootblock_systemagent_early_init();
diff --git a/src/soc/intel/braswell/bootblock/bootblock.c b/src/soc/intel/braswell/bootblock/bootblock.c index 545642f..c5ae330 100644 --- a/src/soc/intel/braswell/bootblock/bootblock.c +++ b/src/soc/intel/braswell/bootblock/bootblock.c @@ -3,6 +3,7 @@ #include <arch/io.h> #include <bootblock_common.h> #include <build.h> +#include <commonlib/console/post_codes.h> #include <console/console.h> #include <device/pci_ops.h> #include <fsp/util.h> @@ -17,6 +18,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/cannonlake/bootblock/bootblock.c b/src/soc/intel/cannonlake/bootblock/bootblock.c index a138ec4..0e12e91 100644 --- a/src/soc/intel/cannonlake/bootblock/bootblock.c +++ b/src/soc/intel/cannonlake/bootblock/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <intelblocks/fast_spi.h> #include <intelblocks/gpio.h> #include <intelblocks/gspi.h> @@ -13,6 +14,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/denverton_ns/bootblock/bootblock.c b/src/soc/intel/denverton_ns/bootblock/bootblock.c index 0846c8e..bdeeac3 100644 --- a/src/soc/intel/denverton_ns/bootblock/bootblock.c +++ b/src/soc/intel/denverton_ns/bootblock/bootblock.c @@ -2,6 +2,7 @@
#include <assert.h> #include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <device/pci.h> #include <device/pci_ops.h> #include <FsptUpd.h> @@ -48,6 +49,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); }; diff --git a/src/soc/intel/elkhartlake/bootblock/bootblock.c b/src/soc/intel/elkhartlake/bootblock/bootblock.c index cc0bb8f..5de1c54 100644 --- a/src/soc/intel/elkhartlake/bootblock/bootblock.c +++ b/src/soc/intel/elkhartlake/bootblock/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <console/console.h> #include <intelblocks/fast_spi.h> #include <intelblocks/systemagent.h> @@ -11,6 +12,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/icelake/bootblock/bootblock.c b/src/soc/intel/icelake/bootblock/bootblock.c index ef5ada6..160cf64 100644 --- a/src/soc/intel/icelake/bootblock/bootblock.c +++ b/src/soc/intel/icelake/bootblock/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/jasperlake/bootblock/bootblock.c b/src/soc/intel/jasperlake/bootblock/bootblock.c index b8086a4..44a95d7 100644 --- a/src/soc/intel/jasperlake/bootblock/bootblock.c +++ b/src/soc/intel/jasperlake/bootblock/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/meteorlake/bootblock/bootblock.c b/src/soc/intel/meteorlake/bootblock/bootblock.c index c7e1826..d4dac73 100644 --- a/src/soc/intel/meteorlake/bootblock/bootblock.c +++ b/src/soc/intel/meteorlake/bootblock/bootblock.c @@ -1,10 +1,13 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <soc/bootblock.h>
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/quark/bootblock/bootblock.c b/src/soc/intel/quark/bootblock/bootblock.c index 2e1a099..4fd83be 100644 --- a/src/soc/intel/quark/bootblock/bootblock.c +++ b/src/soc/intel/quark/bootblock/bootblock.c @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-only */ #include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <console/console.h> #include <cpu/x86/mtrr.h> #include <device/pci_def.h> @@ -65,6 +66,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + if (CONFIG(ENABLE_DEBUG_LED_BOOTBLOCK_ENTRY)) light_sd_led();
diff --git a/src/soc/intel/skylake/bootblock/bootblock.c b/src/soc/intel/skylake/bootblock/bootblock.c index 4b31f77..3dc86a3 100644 --- a/src/soc/intel/skylake/bootblock/bootblock.c +++ b/src/soc/intel/skylake/bootblock/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <cpu/cpu.h> #include <intelblocks/fast_spi.h> #include <intelblocks/systemagent.h> @@ -11,6 +12,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* Call lib/bootblock.c main */ bootblock_main_with_basetime(base_timestamp); } diff --git a/src/soc/intel/xeon_sp/bootblock.c b/src/soc/intel/xeon_sp/bootblock.c index 5ea09ac..e975b18 100644 --- a/src/soc/intel/xeon_sp/bootblock.c +++ b/src/soc/intel/xeon_sp/bootblock.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
#include <bootblock_common.h> +#include <commonlib/console/post_codes.h> #include <device/pci.h> #include <FsptUpd.h> #include <intelblocks/fast_spi.h> @@ -39,6 +40,8 @@
asmlinkage void bootblock_c_entry(uint64_t base_timestamp) { + post_code(POST_BOOTBLOCK_C_ENTRY); + /* * FSP-T does not respect its own API and trashes registers * coreboot uses to store its initial timestamp.
