Attention is currently required from: Martin Roth, Paul Fagerburg, Jan Dabros. Hello Patrick Georgi, Martin Roth, Paul Fagerburg, Jan Dabros,
https://review.coreboot.org/c/coreboot/+/51281
Change subject: tests/Makefile.inc: Enable support for multiple test groups ......................................................................
Until now output of all test groups run in single unit test were saved in the same file which caused Jenkins to fail because of existence of multiple root XML elements. Now each test group is saved to its own file containing its name at the end of the filename.
Signed-off-by: Jakub Czapiga jacz@semihalf.com Change-Id: I21ba512073bc8d8693daad8a9b86d5b076bea03f --- M tests/Makefile.inc 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/81/51281/2
