Attention is currently required from: Jason Glenesk, Martin Roth, Marshall Dawson, Karthik Ramasubramanian. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Furquan Shaikh, Patrick Georgi, Martin Roth, Marshall Dawson, Felix Held,
https://review.coreboot.org/c/coreboot/+/51924
Change subject: soc/amd/common: Handle power resume after power failure ......................................................................
Introduce a power management library to handle the power resume after power failure. Enable HAVE_POWER_STATE_AFTER_FAILURE config when this library is enabled.
BUG=b:183739671 TEST=Build Guybrush and Majolica mainboard.
Change-Id: Iea4ea57d747425fe6714d40ba6e60f2447febf28 Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- A src/soc/amd/common/block/include/amdblocks/pmlib.h A src/soc/amd/common/block/pm/Kconfig A src/soc/amd/common/block/pm/Makefile.inc A src/soc/amd/common/block/pm/pmlib.c 4 files changed, 77 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/51924/7
