Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/51440 )
Change subject: nb/intel/haswell: Decouple USB config from MRC ......................................................................
Change-Id: I4bc405213e9b0828d9ced18677335533c7dd381d Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/asrock/b85m_pro4/romstage.c M src/mainboard/asrock/h81m-hds/romstage.c M src/mainboard/google/beltino/romstage.c M src/mainboard/google/slippy/variants/falco/romstage.c M src/mainboard/google/slippy/variants/leon/romstage.c M src/mainboard/google/slippy/variants/peppy/romstage.c M src/mainboard/google/slippy/variants/wolf/romstage.c M src/mainboard/hp/folio_9480m/romstage.c M src/mainboard/intel/baskingridge/romstage.c M src/mainboard/lenovo/t440p/romstage.c M src/mainboard/msi/h81m-p33/romstage.c M src/mainboard/supermicro/x10slm-f/romstage.c M src/northbridge/intel/haswell/raminit.h M src/northbridge/intel/haswell/romstage.c 14 files changed, 52 insertions(+), 28 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/40/51440/1
diff --git a/src/mainboard/asrock/b85m_pro4/romstage.c b/src/mainboard/asrock/b85m_pro4/romstage.c index 1c17fcb..eb62594 100644 --- a/src/mainboard/asrock/b85m_pro4/romstage.c +++ b/src/mainboard/asrock/b85m_pro4/romstage.c @@ -25,7 +25,7 @@ spd_map[3] = 0xa6; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, @@ -43,7 +43,7 @@ { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { { 1, 0 }, { 1, 0 }, { 1, 1 }, diff --git a/src/mainboard/asrock/h81m-hds/romstage.c b/src/mainboard/asrock/h81m-hds/romstage.c index 16b1500..162b877 100644 --- a/src/mainboard/asrock/h81m-hds/romstage.c +++ b/src/mainboard/asrock/h81m-hds/romstage.c @@ -23,7 +23,7 @@ spd_map[2] = 0xa4; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, @@ -41,7 +41,7 @@ { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 0 }, { 1, 0 }, diff --git a/src/mainboard/google/beltino/romstage.c b/src/mainboard/google/beltino/romstage.c index dda2edc..f8a5959 100644 --- a/src/mainboard/google/beltino/romstage.c +++ b/src/mainboard/google/beltino/romstage.c @@ -46,7 +46,7 @@ spd_map[2] = 0xa4; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0064, 1, 0, /* P0: VP8 */ USB_PORT_MINI_PCIE }, @@ -66,7 +66,7 @@ USB_PORT_SKIP }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 0 }, /* P1; CN22 */ { 1, 1 }, /* P2; CN23 */ diff --git a/src/mainboard/google/slippy/variants/falco/romstage.c b/src/mainboard/google/slippy/variants/falco/romstage.c index 21a4ec6..e688760 100644 --- a/src/mainboard/google/slippy/variants/falco/romstage.c +++ b/src/mainboard/google/slippy/variants/falco/romstage.c @@ -25,7 +25,7 @@ } }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0064, 1, 0, /* P0: Port A, CN8 */ USB_PORT_BACK_PANEL }, @@ -45,7 +45,7 @@ USB_PORT_INTERNAL }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 0 }, /* P1; Port A, CN8 */ { 1, 0 }, /* P2; Port B, CN9 */ diff --git a/src/mainboard/google/slippy/variants/leon/romstage.c b/src/mainboard/google/slippy/variants/leon/romstage.c index 938590b..7ab867f 100644 --- a/src/mainboard/google/slippy/variants/leon/romstage.c +++ b/src/mainboard/google/slippy/variants/leon/romstage.c @@ -22,7 +22,7 @@ memcpy(peid->spd_data[1], peid->spd_data[0], SPD_LEN); }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, /* P0: Port A, CN10 */ USB_PORT_BACK_PANEL }, @@ -42,7 +42,7 @@ USB_PORT_SKIP }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 0 }, /* P1; Port A, CN10 */ { 1, 2 }, /* P2; Port B, CN11 */ diff --git a/src/mainboard/google/slippy/variants/peppy/romstage.c b/src/mainboard/google/slippy/variants/peppy/romstage.c index 02b47db..bfb24f1 100644 --- a/src/mainboard/google/slippy/variants/peppy/romstage.c +++ b/src/mainboard/google/slippy/variants/peppy/romstage.c @@ -39,7 +39,7 @@ } }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0150, 1, USB_OC_PIN_SKIP, /* P0: LTE */ USB_PORT_MINI_PCIE }, @@ -59,7 +59,7 @@ USB_PORT_SKIP }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 0 }, /* P1; Port A, CN6 */ { 0, USB_OC_PIN_SKIP }, /* P2; */ diff --git a/src/mainboard/google/slippy/variants/wolf/romstage.c b/src/mainboard/google/slippy/variants/wolf/romstage.c index 939d584..8d8df94 100644 --- a/src/mainboard/google/slippy/variants/wolf/romstage.c +++ b/src/mainboard/google/slippy/variants/wolf/romstage.c @@ -25,7 +25,7 @@ } }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, /* P0: Port A, CN10 */ USB_PORT_BACK_PANEL }, @@ -45,7 +45,7 @@ USB_PORT_SKIP }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 0 }, /* P1; Port A, CN10 */ { 1, 2 }, /* P2; Port B, CN11 */ diff --git a/src/mainboard/hp/folio_9480m/romstage.c b/src/mainboard/hp/folio_9480m/romstage.c index 496005d..ffef6d2 100644 --- a/src/mainboard/hp/folio_9480m/romstage.c +++ b/src/mainboard/hp/folio_9480m/romstage.c @@ -23,7 +23,7 @@ spd_map[2] = 0xa4; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0080, 1, USB_OC_PIN_SKIP, USB_PORT_BACK_PANEL }, /* dock */ { 0x0040, 1, USB_OC_PIN_SKIP, USB_PORT_BACK_PANEL }, /* left, EHCI debug */ @@ -35,7 +35,7 @@ { 0x0040, 1, USB_OC_PIN_SKIP, USB_PORT_BACK_PANEL }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { { 1, USB_OC_PIN_SKIP }, /* dock */ { 1, USB_OC_PIN_SKIP }, /* left */ { 1, USB_OC_PIN_SKIP }, /* right */ diff --git a/src/mainboard/intel/baskingridge/romstage.c b/src/mainboard/intel/baskingridge/romstage.c index dc1f50f..7e09ab1 100644 --- a/src/mainboard/intel/baskingridge/romstage.c +++ b/src/mainboard/intel/baskingridge/romstage.c @@ -49,7 +49,7 @@ spd_map[3] = 0xa6; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, /* P0: Back USB3 port (OC0) */ USB_PORT_BACK_PANEL }, @@ -81,7 +81,7 @@ USB_PORT_FRONT_PANEL }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 0 }, /* P1; */ { 1, 0 }, /* P2; */ diff --git a/src/mainboard/lenovo/t440p/romstage.c b/src/mainboard/lenovo/t440p/romstage.c index 7aca7c5..fd11d15 100644 --- a/src/mainboard/lenovo/t440p/romstage.c +++ b/src/mainboard/lenovo/t440p/romstage.c @@ -46,7 +46,7 @@ spd_map[2] = 0xa2; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, /* USB3 */ { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, /* USB3 */ @@ -64,7 +64,7 @@ { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { { 1, 0 }, { 1, 0 }, { 1, USB_OC_PIN_SKIP }, diff --git a/src/mainboard/msi/h81m-p33/romstage.c b/src/mainboard/msi/h81m-p33/romstage.c index 9bcb400..df7de43 100644 --- a/src/mainboard/msi/h81m-p33/romstage.c +++ b/src/mainboard/msi/h81m-p33/romstage.c @@ -23,7 +23,7 @@ spd_map[2] = 0xa4; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, @@ -41,7 +41,7 @@ { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { { 1, 0 }, { 1, 0 }, { 1, 1 }, diff --git a/src/mainboard/supermicro/x10slm-f/romstage.c b/src/mainboard/supermicro/x10slm-f/romstage.c index 36f79a3..e52dbb3 100644 --- a/src/mainboard/supermicro/x10slm-f/romstage.c +++ b/src/mainboard/supermicro/x10slm-f/romstage.c @@ -25,7 +25,7 @@ spd_map[3] = 0xa6; }
-const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS] = { +const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ { 0x0040, 1, 0, USB_PORT_INTERNAL }, { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, @@ -43,7 +43,7 @@ { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, };
-const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS] = { +const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS] = { /* Enable, OCn# */ { 1, 1 }, { 1, 1 }, diff --git a/src/northbridge/intel/haswell/raminit.h b/src/northbridge/intel/haswell/raminit.h index 6efea3e..5cf4566 100644 --- a/src/northbridge/intel/haswell/raminit.h +++ b/src/northbridge/intel/haswell/raminit.h @@ -6,9 +6,24 @@ #include <stdint.h> #include "pei_data.h"
+#define NUM_USB2_PORTS 14 +#define NUM_USB3_PORTS 6 + +struct usb2_port_config { + uint16_t length; + uint8_t enable; + uint8_t oc_pin; + uint8_t location; +} __packed; + +struct usb3_port_config { + uint8_t enable; + uint8_t oc_pin; +} __packed; + /* Mainboard-specific USB configuration */ -extern const struct usb2_port_setting mainboard_usb2_ports[MAX_USB2_PORTS]; -extern const struct usb3_port_setting mainboard_usb3_ports[MAX_USB3_PORTS]; +extern const struct usb2_port_config mainboard_usb2_ports[NUM_USB2_PORTS]; +extern const struct usb3_port_config mainboard_usb3_ports[NUM_USB3_PORTS];
/* Optional function to copy SPD data for on-board memory */ void copy_spd(struct pei_data *peid); diff --git a/src/northbridge/intel/haswell/romstage.c b/src/northbridge/intel/haswell/romstage.c index 48ba476..ae51558 100644 --- a/src/northbridge/intel/haswell/romstage.c +++ b/src/northbridge/intel/haswell/romstage.c @@ -71,8 +71,17 @@ .usb_xhci_on_resume = cfg->usb_xhci_on_resume, };
- memcpy(pei_data.usb2_ports, mainboard_usb2_ports, sizeof(mainboard_usb2_ports)); - memcpy(pei_data.usb3_ports, mainboard_usb3_ports, sizeof(mainboard_usb3_ports)); + for (size_t i = 0; i < NUM_USB2_PORTS; i++) { + pei_data.usb2_ports[i].length = mainboard_usb2_ports[i].length; + pei_data.usb2_ports[i].enable = mainboard_usb2_ports[i].enable; + pei_data.usb2_ports[i].over_current_pin = mainboard_usb2_ports[i].oc_pin; + pei_data.usb2_ports[i].location = mainboard_usb2_ports[i].location; + } + + for (size_t i = 0; i < NUM_USB3_PORTS; i++) { + pei_data.usb3_ports[i].enable = mainboard_usb3_ports[i].enable; + pei_data.usb3_ports[i].over_current_pin = mainboard_usb3_ports[i].oc_pin; + }
enable_lapic();
