Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/37395 )
Change subject: [WIP]cpu/x86/sipi: Add x86_64 support ......................................................................
Enter long mode on secondary APs.
Tested on Lenovo T410 with additional x86_64 patches.
Change-Id: I916dd8482d56c7509af9ad0d3b9c28bdc48fd0b1 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/cpu/x86/64bit/entry64.inc M src/cpu/x86/sipi_vector.S 2 files changed, 24 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/37395/1
diff --git a/src/cpu/x86/64bit/entry64.inc b/src/cpu/x86/64bit/entry64.inc index f726fab..7649f46 100644 --- a/src/cpu/x86/64bit/entry64.inc +++ b/src/cpu/x86/64bit/entry64.inc @@ -29,7 +29,12 @@ #endif
#include <cpu/x86/msr.h> +#if defined(__RAMSTAGE__) +#include <arch/ram_segs.h> +#else #include <arch/rom_segs.h> +#endif +
setup_longmode: /* Get page table address */ @@ -55,7 +60,12 @@ movl %eax, %cr0
/* use long jump to switch to 64-bit code segment */ +#if defined(__RAMSTAGE__) + ljmp $RAM_CODE_SEG64, $__longmode_start +#else ljmp $ROM_CODE_SEG64, $__longmode_start + +#endif .code64 __longmode_start:
diff --git a/src/cpu/x86/sipi_vector.S b/src/cpu/x86/sipi_vector.S index f75a1c9..e06baa2 100644 --- a/src/cpu/x86/sipi_vector.S +++ b/src/cpu/x86/sipi_vector.S @@ -204,11 +204,25 @@ mov %eax, %cr4 #endif
+#ifdef __x86_64__ +#define __RAMSTAGE__ 1 + /* entry64.inc preserves ebx. */ +#include <cpu/x86/64bit/entry64.inc> + + mov %rsi, %rdi /* cpu_num */ + + movl c_handler, %eax + call *%rax +#else /* c_handler(cpu_num), preserve proper stack alignment */ sub $12, %esp push %esi /* cpu_num */ + mov c_handler, %eax call *%eax +#endif + + halt_jump: hlt jmp halt_jump
Hello build bot (Jenkins), Patrick Georgi, Martin Roth,
Change subject: cpu/x86/sipi: Add x86_64 support ......................................................................
Tested on Lenovo T410 with additional x86_64 patches. Tested on HP Z220 with additional x86_64 patches.
Still boots on x86_32.
Change-Id: I916dd8482d56c7509af9ad0d3b9c28bdc48fd0b1 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/cpu/x86/64bit/entry64.inc M src/cpu/x86/Makefile.inc M src/cpu/x86/sipi_vector.S 3 files changed, 24 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/37395/4
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/37395 )
Patch Set 4: Code-Review+2
Patrick Rudolph has submitted this change. ( https://review.coreboot.org/c/coreboot/+/37395 )
Change-Id: I916dd8482d56c7509af9ad0d3b9c28bdc48fd0b1 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/37395 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz --- M src/cpu/x86/64bit/entry64.inc M src/cpu/x86/Makefile.inc M src/cpu/x86/sipi_vector.S 3 files changed, 24 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/cpu/x86/64bit/entry64.inc b/src/cpu/x86/64bit/entry64.inc index 65c0fdc..7025517 100644 --- a/src/cpu/x86/64bit/entry64.inc +++ b/src/cpu/x86/64bit/entry64.inc @@ -16,7 +16,12 @@ #endif
setup_longmode: /* Get page table address */ @@ -42,7 +47,12 @@ movl %eax, %cr0
diff --git a/src/cpu/x86/Makefile.inc b/src/cpu/x86/Makefile.inc index 2f789f7..0502c72 100644 --- a/src/cpu/x86/Makefile.inc +++ b/src/cpu/x86/Makefile.inc @@ -24,6 +24,7 @@ $(TARGET_STAGE)-srcs += $(SIPI_BIN).manual endif rmodules_$(ARCH-$(TARGET_STAGE)-y)-$(CONFIG_PARALLEL_MP) += sipi_vector.S +rmodules_$(ARCH-$(TARGET_STAGE)-y)-generic-ccopts += $($(TARGET_STAGE)-generic-ccopts)
$(SIPI_DOTO): $(call src-to-obj,rmodules_$(ARCH-$(TARGET_STAGE)-y),src/cpu/x86/sipi_vector.S) $(LD_rmodules_$(ARCH-$(TARGET_STAGE)-y)) -nostdlib -r -o $@ $^ diff --git a/src/cpu/x86/sipi_vector.S b/src/cpu/x86/sipi_vector.S index ba1ecb7..bda49cc 100644 --- a/src/cpu/x86/sipi_vector.S +++ b/src/cpu/x86/sipi_vector.S @@ -192,11 +192,24 @@ mov %eax, %cr4 #endif
+#ifdef __x86_64__ + /* entry64.inc preserves ebx. */ +#include <cpu/x86/64bit/entry64.inc> + + mov %rsi, %rdi /* cpu_num */ + + movl c_handler, %eax + call *%rax +#else /* c_handler(cpu_num), preserve proper stack alignment */ sub $12, %esp push %esi /* cpu_num */ + mov c_handler, %eax call *%eax +#endif + + halt_jump: hlt jmp halt_jump
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/37395 )
Patch Set 5:
Automatic boot test returned (PASS/FAIL/TOTAL): 6/1/7 "QEMU x86 q35/ich9" (x86_32) using payload TianoCore : SUCCESS : https://lava.9esec.io/r/16252 "QEMU x86 q35/ich9" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16251 "QEMU x86 i440fx/piix4" (x86_64) using payload SeaBIOS : FAIL : https://lava.9esec.io/r/16250 "QEMU x86 i440fx/piix4" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16249 "QEMU AArch64" using payload LinuxBoot_u-root_kexec : SUCCESS : https://lava.9esec.io/r/16248 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload TianoCore : FAIL : https://lava.9esec.io/r/16254 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload SeaBIOS : FAIL : https://lava.9esec.io/r/16253
